The Solaris WBEM Services 2.5 daemon cannot locate providers that are written to the com.sun.wbem.provider interface or to the com.sun.wbem.provider20 interface. Even if you create a Solaris_ProviderPath instance for a provider that is written to these interfaces, the Solaris WBEM Services 2.5 daemon does not locate the provider.
Workaround: To enable the daemon to locate such a provider, stop and restart the Solaris WBEM Services 2.5 daemon.
# /etc/init.d/init.wbem stop # /etc/init.d/init.wbem start |
If you use the javax
API to develop
your provider, you do not need to stop and restart the Solaris WBEM Services
2.5 daemon. The Solaris WBEM Services 2.5 daemon dynamically recognizes javax
providers.
