If you try to read an email message with many long lines in any of the Solaris 9 9/02 Unicode or UTF-8 locales, CDE Mailer (dtmail) appears to hang. The message does not display immediately.
Workaround: Choose one of the following workarounds.
Enlarge the dtmail Mailbox window to accommodate 132 columns.
Disable the Complex Text Layout feature by following these steps.
Become superuser.
Change directories to your system's locale directory.
# cd /usr/lib/locale/locale-name |
In the previous example, locale-name refers to the name of your system's Solaris 9 9/02 Unicode or UTF-8 locale.
Rename the locale layout engine category.
# mv LO_LTYPE LO_LTYPE- |
Rename the locale layout engine category to the original name (LO_LTYPE) before you apply any patches to the locale layout engine.
