Solaris 9 (SPARC Platform Edition) 9/02 Release Notes
Unlocking CDE Screenlock Removes Kerberos Version 5 Credentials (4674474)
If you unlock a locked CDE session, all your cached Kerberos version 5 (krb5) credentials might be removed. The result is you might not be able to access various system utilities. This problem occurs under the following conditions.
If this problem occurs, the following error message is displayed.
lock screen: PAM-KRB5 (auth): Error verifying TGT with host/host-name:
Permission denied in replay cache code
Workaround: Add the following non-pam_krb5 dtsession entries to the /etc/pam.conf file.
dtsession auth requisite pam_authtok_get.so.1
dtsession auth required  pam_unix_auth.so.1
With these entries in the /etc/pam.conf file, the pam_krb5 module does not run by default.
