Solaris 9 (SPARC Platform Edition) 9/02 Release Notes
Veritas Volume Manager Might Fail on Systems Running Solaris 9 9/02 Operating Environment (4642114)
If you try to perform various tasks with Veritas Volume Manager on a system that is running the Solaris 9 9/02 operating environment, the vxddladm addjob or vxddladm addsupport utilities might core dump.
Workaround: Follow these steps.
  1. Become superuser.
  2. Verify that the /var/ld/ld.config file and /usr/bin/crle utility exist on the system.
  3. Type the following commands in a terminal window.
     # /usr/bin/cp /var/ld/ld.config /var/ld/ld.config.save
     # /usr/bin/crle -E LD_LIBRARY_PATH=/usr/lib
     # appropriate-vxddladm-command
     # /usr/bin/mv /var/ld/ld.config.save /var/ld/ld.config
