The Edit Config File menu item in the Smartcards Management Console does not edit smart card configuration files that are located in /etc/smartcard/opencard.properties. If the menu item is selected, a warning is displayed which indicates not to continue unless requested by technical support.
Workaround: Do not use the Edit Config File menu item in the Smartcards Management Console. For information on smart card configuration, see the Solaris Smartcard Administration Guide.
