This function retrieves attributes for the specified controller handle. The following list describes the currently defined attributes for this function:
typedef struct {
uint_t attr_direct_access_sizes;
uint_t attr_atomic_sizes;
size_t attr_page_size;
size_t attr_max_export_segment_size;
size_t attr_tot_export_segment_size;
ulong_t attr_max_export_segments;
size_t attr_max_import_map_size;
size_t attr_tot_import_map_size;
ulong_t attr_max_import_segments;
} rsmapi_controller_attr_t;
Return Values: Returns 0 if successful. Returns an error value otherwise.
Invalid controller handle
Bad address
