Use the flar command with the -i option to get information about archives you have already created. The syntax of the command is as follows:
flar -i:info [-l] [-k keyword] [-t [-p posn] [-b blocksize]] filename
Table 20-4 Command-Line Options for flar -i|
Option |
Description |
-k keyword |
Returns only the value of the keyword keyword. |
-l |
Lists all the files in the archive section. |
