If you have a boot server, make sure you have shared the install server installation image and started the appropriate daemons. See Step 6.
On the install server or boot server, become superuser.
If you use the NIS, NIS+, DNS, or LDAP name service, verify that the following information about the system to be installed has been added to the name service.
Host name
IP address
Ethernet address
For more information on name services, see System Administration Guide: Naming and Directory Services (DNS, NIS, NIS+, and LDAP).
Change to the Tools directory on the Solaris 9 DVD image:
# cd /install_dir_path/Solaris_9/Tools |
install_dir_path |
Specifies the path to the Tools directory |
Set up the client system so it can be installed from the network.
# ./add_install_client [[-d]] [[-s install_server:install_dir_path]] \ [[-c jumpstart_server:jumpstart_dir_path]] [[-p sysid_server:path]] \ [[-t boot_image_path]] client_name platform_group |
-d |
Specifies that the client is to use DHCP to obtain the network install parameters. |
-s install_server:install_dir_path |
Specifies the name and path to the install server.
-c jumpstart_server:jumpstart_dir_path |
Specifies a JumpStart directory for custom JumpStart installations. jumpstart_server is the host name of the server on which the JumpStart directory is located. jumpstart_dir_path is the absolute path to the JumpStart directory. |
-p sysid_server:path |
Specifies the path to the sysidcfg file for preconfiguring system information. sysid_server is either a valid host name or an IP address for the server that contains the file. path is the absolute path to the directory containing the sysidcfg file. |
-t boot_image_path |
Specifies the path to an alternate boot image if you want to use a boot image other than the one in the Tools directory on the Solaris 9 net installation image, CD, or DVD. |
client_name |
Is the name of the system to be installed from the network. This name is not the host name of the install server. |
platform_group |
Is the platform group of the system to be installed. For more information, see Chapter 39, Platform Names and Groups (Reference). |
The following example illustrates how to add an install client when you are using DHCP to set installation parameters on the network. The install client is named basil, which is an UltraTM 5 system. The file system /export/home/s9dvdsparc/Solaris_9/Tools contains the add_install_client command.
install_server# cd /export/home/s9dvdsparc/Solaris_9/Tools install_server# ./add_install_client -d basil sun4u |
The following example illustrates how to add an install client that is on the same subnet as the install server. The install client is named basil, which is an UltraTM 5 system. The file system /export/home/s9dvdsparc/ contains the add_install_client command.
install_server# cd /export/home/s9dvdsparc/Solaris_9/Tools install_server# ./add_install_client basil sun4u |
The following example illustrates how to add an install client to a boot server. The install client is named rose, which is an UltraTM 5 system. Run the command on the boot server. The -s option is used to specify an install server that is named rosemary, which contains a Solaris 9 DVD image in /export/home/s9dvdsparc.
boot_server# cd /export/home/s9dvdsparc/Solaris_9/Tools boot_server# ./add_install_client -s rosemary:/export/home/s9dvdsparc rose sun4u |
