Solaris オペレーティング環境の 4 つのスイッチファイルを、以下に示します。
# # /etc/nsswitch.nisplus: # # An example file that could be copied over to /etc/nsswitch.conf; # it uses NIS+ (NIS Version 3) in conjunction with files. # # "hosts:" and "services:" in this file are used only if the # /etc/netconfig file has a "-" for nametoaddr_libs of "inet" # transports. # the following two lines obviate the "+" entry in /etc/passwd # and /etc/group. passwd: files nisplus group: files nisplus # consult /etc "files" only if nisplus is down. hosts: nisplus [NOTFOUND=return] files # Uncomment the following line, and comment out the above, to use # both DNS and NIS+. You must also set up the /etc/resolv.conf # file for DNS name server lookup. See resolv.conf(4). # hosts: nisplus dns [NOTFOUND=return] files services: nisplus [NOTFOUND=return] files networks: nisplus [NOTFOUND=return] files protocols: nisplus [NOTFOUND=return] files rpc: nisplus [NOTFOUND=return] files ethers: nisplus [NOTFOUND=return] files netmasks: nisplus [NOTFOUND=return] files bootparams: nisplus [NOTFOUND=return] files publickey: nisplus netgroup: nisplus automount: files nisplus aliases: files nisplus sendmailvars: files nisplus |
# # /etc/nsswitch.nis: # # An example file that could be copied over to /etc/nsswitch.conf; # it uses NIS (YP) in conjunction with files. # # "hosts:" and "services:" in this file are used only if the # /etc/netconfig file has a "-" for nametoaddr_libs of "inet" # transports. # # the following two lines obviate the "+" entry in /etc/passwd # and /etc/group. passwd: files nis group: files nis # consult /etc "files" only if nis is down. hosts: nis [NOTFOUND=return] files networks: nis [NOTFOUND=return] files protocols: nis [NOTFOUND=return] files rpc: nis [NOTFOUND=return] files ethers: nis [NOTFOUND=return] files netmasks: nis [NOTFOUND=return] files bootparams: nis [NOTFOUND=return] files publickey: nis [NOTFOUND=return] files netgroup: nis automount: files nis aliases: files nis # for efficient getservbyname() avoid nis services: files nis sendmailvars: files |
# # /etc/nsswitch.files: # # An example file that could be copied over to /etc/nsswitch.conf; # it does not use any naming service. # # "hosts:" and "services:" in this file are used only if the # /etc/netconfig file has a "-" for nametoaddr_libs of "inet" # transports. passwd: files group: files hosts: files networks: files protocols: files rpc: files ethers: files netmasks: files bootparams: files publickey: files # At present there isn't a 'files' backend for netgroup; # the system will figure it out pretty quickly, and will notuse # netgroups at all. netgroup: files automount: files aliases: files services: files sendmailvars: files |
# # /etc/nsswitch.ldap: # # An example file that could be copied over to /etc/nsswitch.conf; it # uses LDAP in conjunction with files. # # "hosts:" and "services:" in this file are used only if the # /etc/netconfig file has a "-" for nametoaddr_libs of "inet" transports. # the following two lines obviate the "+" entry in /etc/passwd and /etc/group. passwd: files ldap group: files ldap hosts: ldap [NOTFOUND=return] files networks: ldap [NOTFOUND=return] files protocols: ldap [NOTFOUND=return] files rpc: ldap [NOTFOUND=return] files ethers: ldap [NOTFOUND=return] files netmasks: ldap [NOTFOUND=return] files bootparams: ldap [NOTFOUND=return] files publickey: ldap [NOTFOUND=return] files netgroup: ldap automount: files ldap aliases: files ldap # for efficient getservbyname() avoid ldap services: files ldap sendmailvars: files |
