During a custom JumpStart installation, the JumpStart program attempts to match the system that is being installed to the rules in the rules.ok file. The JumpStart program reads the rules from the first rule through the last rule. A match occurs when the system that is being installed matches all of the system attributes that are defined in the rule. As soon as a system matches a rule, the JumpStart program stops reading the rules.ok file and begins to install the system, based on the matched rule's profile.
Table 26-2 IA: Task Map: Setting Up a System for a Custom JumpStart Installation|
Task |
Description |
For Instructions |
Determine if you need to preserve an existing operating system and user data |
If the existing operating system on the system uses the entire disk, you must preserve the existing operating system so it can co-exist with the Solaris 9 software. This decision determines how to specify the fdisk(1M) keyword in the system's profile. | |
Check if the system is supported |
Check the hardware documentation for system support in the Solaris 9 environment. |
Hardware manufacturer's documentation |
Check if the system has enough disk space for the Solaris 9 software |
Verify that you have planned enough space to install the Solaris software on your system. |
Chapter 5, Guidelines for Allocating Disk Space and Swap Space (Planning) |
(Optional) Preconfigure system configuration information |
You can use the sysidcfg file or the name service to preconfigure installation information for a system. If you preconfigure system information, the installation program does not prompt you to supply the information during the installation. |
Chapter 7, Preconfiguring System Configuration Information (Tasks) |
Prepare the system for custom JumpStart installation |
Create and validate a rules file and profile files. |
Chapter 23, Preparing Custom JumpStart Installations (Tasks) |
(Optional) Prepare optional custom JumpStart features |
If you are using begin scripts, finish scripts, or other optional features, prepare the scripts or files. |
Chapter 24, Using Optional Custom JumpStart Features (Tasks) and Chapter 25, Creating Custom Rule and Probe Keywords (Tasks) |
(Optional) Set up the system to install over the network |
To install a system from a remote Solaris 9 Intel Platform Edition DVD or Solaris 9 Software Intel Platform Edition CD image, you need to set up the system to boot and install from an install server or a boot server. |
Chapter 12, Preparing to Install From the Network With CD Media (Tasks) |
Install or upgrade |
Boot the system to initiate the installation or upgrade. |
“IA: To Perform an Installation or Upgrade With the Custom JumpStart Program” |
