If the system is part of a network, ensure that an Ethernet connector or similar network adapter is attached to your system.
If you want to install a system that is connected through a tip(1) line, ensure that your window display is at least 80 columns wide and 24 rows long.
To determine the current dimensions of your tip window, use the stty(1) command.
If you are using a profile diskette, insert the profile diskette into the system's diskette drive.
The profile diskette contains a copy of the Solaris 9 Device Configuration Assistant in addition to profile information. If you are using PXE network boot to boot the system over the network, you must configure your system so that the system boots from the network and not from the diskette.
If you are using the system's DVD-ROM or CD-ROM drive to install the Solaris 9 software, insert the Solaris 9 Intel Platform Edition DVD or the Solaris 9 Software 1 of 2 Intel Platform Edition CD in the drive.
Decide how to boot the system.
If you boot from the Solaris 9 DVD or the Solaris 9 Installation CD, insert the disc. Your system's BIOS must support booting from a DVD or CD.
If you boot from the network, use Pre-boot eXecution Environment (PXE) network boot. The system must support PXE. Enable the system to use PXE by using the systems's BIOS setup tool or the network adapter's configuration setup tool.
If you boot from a Diskette – Use the profile diskette that you inserted into the drive in Step 3 or insert the Solaris 9 Device Configuration Assistant Intel Platform Edition diskette into the system's diskette drive.
You can copy the Device Configuration Assistant software to a diskette by the following methods:
Copy the software to a diskette from the Solaris 9 Intel Platform Edition DVD or Solaris 9 Software 2 of 2 Intel Platform Edition CD by using the procedure in Appendix E, IA: Preparing to Boot From the Solaris 9 Device Configuration Assistant or the Network (Tasks).
Download and copy the software to a diskette from the Solaris Developer Connection at http://soldc.sun.com/support/drivers/dca_diskettes.
If the system is off, turn the system on. If the system is on, reboot the system.
The Device Configuration Assistant identifies the system's devices.
On the Boot Solaris screen, select the device from which to boot the system. Select DVD, CD, Net, or Disk.
At the prompt, perform one of the following:
Select the type of installation you want to perform:
1 Solaris Interactive
2 Custom JumpStart
Enter the number of your choice followed by the <ENTER> key.
If you enter anything else, or if you wait for 30 seconds,
an interactive installation will be started.
To select the custom JumpStart method, perform one of the following actions:
If you do not type 2 or type a boot command within 30 seconds, the Solaris suninstall program begins. You can stop the timer by typing any key on the command line.
Type 2 and press Enter.
To specify the location of the custom JumpStart configuration files, type the following command:
b install [[url:ask]] [[dhcp]] [[nowin]] |
If you did not preconfigure system information in the sysidcfg file, when prompted, answer the questions about system configuration.
Follow the instructions on the screen to install the software.
When the JumpStart program finishes installing the Solaris software, the system reboots automatically.
After the installation is finished, installation logs are saved in a file. You can find the installation logs in the following directories:
/var/sadm/system/logs
/var/sadm/install/logs
