Solaris Flash archives contain at least three sections. The sections include sections that identify the archive and the actual files that were copied from the master system.
Archive Cookie section – The first section of a Solaris Flash archive contains a cookie that identifies the file as a Solaris Flash archive. The cookie must be present for an archive to be valid.
Archive Identification Section – The second section contains keywords with values that provide identification information about the archive. You are required to specify a name for the Solaris Flash archive. Other information that you can specify about the archive includes:
The author of the archive
The date that the archive was created
The name of the master system that you used to create the archive
For a list of keywords that describe the archive, see “Identification Section Keywords”.
User–Defined sections – Following the Archive Identification Section, you can define and insert sections. The Solaris Flash archive does not process any sections that you insert. For example, this section could contain a description of the archive or perhaps a script to check the integrity of an application.
In a User-Defined section, you can also define keywords. The Solaris Flash archive ignores user-defined keywords, but you can provide scripts or programs that process the Identification section and use these keywords.
The User-Defined section requires the following format.
Archive Files Section – The Archive Files Section contains the files that were saved from the master system.
You can use the flar command to retrieve information about the archive. For detailed instructions, refer to “Extracting Information From an Archive”.
