When you create a Solaris Flash archive, some files and directories that are to be copied from the master system can be excluded. If you have excluded a directory, you can also restore specified files or subdirectories under that directory. For example, you could create an archive that excludes all files and directories in /a/aa/bb/c. The content of the /bb subdirectory could be included. The only content then would be in the /bb subdirectory.
Use the flar create file-exclusion options with caution. If you exclude some directories, others that you were unaware of might be left in the archive, such as system configuration files. The system would then be inconsistent and the installation would not work. Excluding directories and files is best used with data that can easily be removed without disrupting the system, such as large data files.
The following table lists the flar create command options that can exclude files and directories and restore files and subdirectories.
How Specified? |
Options That Exclude |
Options That Include |
Specify the name of the directory or file |
-x exclude_dir/filename |
-y include_dir/filename |
Use a file that contains a list |
-X list_filename -z list_filename |
-f list_filename -z list_filename |
For descriptions of these options, see Table 20–3.
For examples of customizing an archive, see “Creating an Archive Examples”.
