Log in as superuser.
Type:
# luupgrade -f -n BE_name -s os_image_path -a archive |
-f |
Indicates to install an operating system from a Solaris Flash archive. |
-n BE_name |
Specifies the name of the boot environment that is to be installed with an archive. |
-s os_image_path |
Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory. |
-a archive |
Path to the Solaris Flash archive when the archive is available on the local file system. The operating system image versions specified with the -s option and the -a option must be identical. |
In this example, an archive is installed on the second_disk boot environment. The archive is located on the local system. The operating systems versions for the -s and -a options are both Solaris 9 releases. All files are overwritten on second_disk except shareable files.
# luupgrade -f -n second_disk \ -s /net/installmachine/export/solaris9/OS_image \ -a /net/server/archive/solaris9 |
The boot environment is ready to be activated.
