This procedures provides the steps to install a Solaris Flash archive by using a profile.
If you added locales to the profile, make sure that you have created a boot environment with additional disk space.
Log in as superuser.
Create a profile.
See Table 33–2 for a list of keywords that can be used in a Solaris Live Upgrade profile.
Type:
# luupgrade -f -n BE_name -s os_image_path -j profile_path |
-f |
Indicates to install an operating system from a Solaris Flash archive. |
-n BE_name |
Specifies the name of the boot environment that is to be upgraded. |
-s os_image_path |
Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory. |
-j profile_path |
Path to a profile that is configured for a flash installation. The profile must be in a directory on the local machine. |
The boot environment is ready to be activated.
In this example, an archive is installed on the second_disk boot environment. The -j option is used to access the profile. The boot environment is then ready to be activated. To create a profile, see “To Create a Profile to be Used by Solaris Live Upgrade”.
# luupgrade -f -n second_disk \ -s /net/installmachine/export/solarisX/OS_image \ -j /var/tmp/profile |
