The following table lists the keyboard shortcuts that you can use from any part of the desktop.
Keys |
Function |
Alt+F1 |
Open the Main Menu at the location of your mouse pointer. You can customize this keyboard shortcut. |
Alt+F2 |
Open the Run Program dialog. You can customize this keyboard shortcut. |
Print Screen |
Take a screenshot of the entire screen. You can customize this keyboard shortcut. |
Alt+Print Screen |
Take a screenshot of the window that currently has focus. You can customize this keyboard shortcut. |
F1 |
If the focused desktop element is an application window or dialog, this keyboard shortcut opens the online help for the application. |
Ctrl+ F1 |
If the focused desktop element is a panel or application window, this keyboard shortcut switches the display of tooltips for the window or panel objects on and off. |
Shift+ F10 |
Open a popup menu for the desktop element that has focus, if a popup menu exists. |
