Before you configure the local peer, you might need to gather the items that are listed in the next table.
Table 30–4 Planning for a Leased-Line Link|
Information |
Action |
Device name of the interface |
Refer to the Interface card documentation. |
Configuration instructions for the synchronous interface card |
Refer to the Interface card documentation. You need this information to configure the HSI/S interface. You might not need to configure other types of interface cards. |
(Optional) IP address of the remote peer |
Refer to the service provider documentation. Alternatively, contact the system administrator of the remote peer. This information is needed only if the IP address is not negotiated between the two peers. |
(Optional) Name of the remote peer |
Refer to the service provider documentation. Alternatively, you can contact the system administrator of the remote peer. |
(Optional) Speed of the link |
(Optional) Compression that is used by the remote peer |
