The ipc_perm token contains a copy of the System V IPC access information. This token is added to audit records that are generated by IPC shared-memory events, IPC semaphore events, and IPC message events. The ipc_perm token has eight fields:
A token ID that identifies this token as an ipc_perm token
The user ID of the IPC owner
The group ID of the IPC owner
The user ID of the IPC creator
The group ID of the IPC creator
The access modes of the IPC
The sequence number of the IPC
The IPC key value
The praudit command displays the ipc_perm token as follows:
IPC perm,root,wheel,root,wheel,0,0,0x00000000 |
The values are taken from the ipc_perm structure that is associated with the IPC object. The following figure shows the format of an ipc_perm token.
