System Administration Guide: Security Services
ipc Token
The ipc token contains the System V IPC message/semaphore/shared-memory handle that is used by the caller to identify a particular IPC object. The ipc token has three fields:
The praudit command displays the ipc token as follows:
IPC,msg,3
Note –
The IPC object identifiers violate the context-free nature of the Solaris audit tokens. No global “name” uniquely identifies IPC objects. Instead, IPC objects are identified by their handles. The handles are valid only during the time that the IPC objects are active. However, the identification of IPC objects should not be a problem. The System V IPC mechanisms are seldom used, and the mechanisms all share the same audit class.
The following table shows the possible values for the IPC object type field. The values are defined in the /usr/include/bsm/audit.h file.
Table 23–7 Values for the IPC Object Type Field
Name
Value
Description
AU_IPC_MSG
1
IPC message object
AU_IPC_SEM
2
IPC semaphore object
AU_IPC_SHM
3
IPC shared-memory object
The following figure shows the format of an ipc token.
Figure 23–16 ipc Token Format
The preceding context describes the graphic.
