System Administration Guide: Security Services
trailer Token
The two tokens, header and trailer, are special in that they distinguish the end points of an audit record and bracket all the other tokens. A header token begins an audit record. A trailer token ends an audit record. The trailer token is an optional token. The trailer token is added as the last token of each record only when the trail audit policy has been set.
If an audit record was generated with trailers turned on, the auditreduce command verifies that the trailer points back to the record header correctly. The trailer token supports backward seeks of the audit trail.
The trailer token has three fields:
The praudit command displays the trailer token as follows:
trailer,136
The following figure shows the format of a trailer token.
Figure 23–28 trailer Token Format
Diagram shows the format for a trailer token, which includes a Token ID, then a Pad number, then a Byte count.
