To determine the continuation or failure behavior from a module, you must select a control flag for each entry in the PAM configuration file, /etc/pam.conf. Each module in a stack can determine the success or failure of the request.
Continuation behavior defines if any following modules are checked. Depending on the response from a particular module, you can decide to skip any additional modules.
Failure behavior defines how error messages are logged or reported. Failures are either optional or required. A required failure causes that request to fail, even if other modules succeed. An optional failure does not always cause the request to fail.
Even though these flags apply to all module types, the following explanation assumes that these flags are being used for authentication modules. The control flags are as follows:
binding – With this control flag, if the module is successful and no preceding modules that are flagged as required have failed, then skip the remaining modules. If a failure is returned, record a required failure and continue processing the stack.
The binding control flag is like the required control flag, except that no additional module checking is done if the module is successful. A failure using this flag prevents the request from being successful, regardless of the response of any other modules. A success using this flag makes the request successful if no preceding required modules failed.
required – With this control flag, if the module is successful, record a required success and continue checking any following modules. If the module fails, and if this is the first required failure, save the error message and continue checking the stack. If this is not the first failure, then continue checking the stack.
The required control flag should be used when a particular module must succeed for the request to be successful. A failure when using this flag prevents the request from being successful, regardless of the response of any other modules. A success when using this flag does not mean that the request is successful. All of the responses from the other required modules in the stack must be successful for the request to succeed.
requisite – With this control flag, if the module is successful, record a required success and continue checking any following modules. If the module fails, record a required failure, return the error message of the first required failure, and skip any additional checking.
The requisite control flag is like the required control flag, except that no additional module checking is done if the module fails. A failure when using this flag prevents the request from being successful, regardless of the response of any other modules. A success when using this flag does not mean that the request is successful. All of the responses from the other required modules in the stack must be successful for the request to succeed.
optional – With this control flag, if the module is successful, record an optional success and continue checking the stack. If the module fails, record an optional failure and continue checking the stack.
The optional control flag should be used when successful authentication in the stack is enough for a user to be authenticated. This flag should only be used if this particular mechanism does not need to succeed. The success or failure of the request, is determined by any required failures or successes.
If your users need to have permission associated with a specific mechanism to get their work done, then you should not label the module as optional.
sufficient – With this control flag, if the module is successful, and no preceding modules that are flagged as required have failed, then skip the remaining modules. If the module fails, record an option failure and continue checking the stack.
The sufficient control flag is like the optional control flag, except that no additional module checking is done if the module succeeds. A success when using this flag makes the request successful if no preceding required modules failed. A failure when using this flag causes the request to fail if no other modules succeeded.
More information about these control flags is provided in the following section, which describes the default /etc/pam.conf file.
