The generic /etc/pam.conf file specifies the following actions:
When the login command is run, authentication must succeed for the pam_authtok_get, pam_dhkeys, pam_auth_unix, and the pam_dial_auth modules.
For the rlogin command, authentication through the pam_authtok_get, pam_dhkeys, and pam_auth_unix modules must succeed if authentication through pam_rhost_auth fails.
The sufficient control flag indicates that for the rlogin command, the successful authentication that is provided by the pam_rhost_auth module is sufficient. The next entry is ignored.
Most of the other commands that require authentication require successful authentication through the pam_authtok_get, pam_dhkeys, and pam_auth_unix modules.
For the rsh command, authentication through the pam_rhost_auth module is flagged as sufficient. No other authentication is required if authentication through the pam_rhost_auth module succeeds.
The OTHER service name allows a default to be set for any other commands that require authentication and are not included in the file. The OTHER option simplifies administration of the file, since many commands that are using the same module can be covered by using only one entry. Also, the OTHER service name, when used as a “catch-all,” can ensure that each access is covered by one module. By convention, the OTHER entry is included at the bottom of the section for each module type.
Normally, the entry for the module_path is “root-relative.” If the file name that you enter for module_path does not begin with a slash (/), the path /usr/lib/security/$ISA precedes the file name. A full path name must be used for modules that are located in other directories. The values for the module_options can be found in the man pages for the module. For example, the UNIX module is covered in the pam_unix(5) man page.
login auth required pam_authtok_get.so.1 login auth required pam_dhkeys.so.1 login auth required pam_unix_auth.so.1 login auth required pam_dial_auth.so.1 |
In this example, the login service specifies authentication through all four authentication modules. A login command fails if any one of the modules returns an error.
