This chapter describes how Solaris Secure Shell works from the administrator's point of view and how it is configured. The following is a list of the reference information in this chapter.
The Solaris Secure Shell daemon (sshd) is normally started at boot from the /etc/init.d/sshd script. The daemon listens for connections from clients. ASolaris Secure Shell session begins when the user runs the ssh, scp, or sftp command. A new sshd daemon is forked for each incoming connection. The forked daemons handle key exchange, encryption, authentication, command execution, and data exchange with the client. These session characteristics are determined by client-side configuration files and server configuration files, and potentially command-line parameters. The client and server must authenticate themselves to each other. After successful authentication, the user can execute commands remotely and copy data between hosts.
The server-side behavior of the sshd daemon is controlled by keyword settings in the /etc/ssh/sshd_config file and potentially the command-line options when sshd is started. For example, sshd_config controls which types of authentication are permitted for accessing the server.
The behavior on the client side is controlled by the Solaris Secure Shell parameters in this order of precedence:
Command-line options
User's configuration file ($HOME/.ssh/config)
System-wide configuration file (/etc/ssh/ssh_config)
For example, a user can override a system-wide configuration Cipher that is set to blowfish by specifying -c 3des on the command line.
The steps in the authentication process for Solaris Secure Shell are as follows:
The client and server agree on a shared session key.
In v1, the remote host sends its host (RSA) key and a server (RSA) key to the client. Note that the server key is typically generated every hour and stored in memory only. The client checks that the remote host key is stored in the $HOME/.ssh/known_hosts file on the local host. The client then generates a 256 bit random number and encrypts it with the remote host's host key and server key. The encrypted random number is used as a session key to encrypt all further communications in the session.
In v2, the remote host uses DSA in its host key and does not generate a server key. Instead, the shared session key is derived through a Diffie-Hellman agreement.
The local and remote hosts authenticate each other.
In v1, the client can use .rhosts, .rhosts with RSA, RSA challenge-response, or password-based authentication. In v2, only .rhosts, DSA, and password-based authentication are permitted.
After authentication is complete, the user can use Solaris Secure Shell, generally by requesting a shell or executing a command. Through the ssh options, the user can make requests, such as allocating a pseudo-tty, forwarding X11 connections or TCP/IP connections, or enabling an ssh-agent over a secure connection. The basic components of a user session are as follows:
The user requests a shell or the execution of a command, which begins the session mode.
In this mode, data is sent or received through the terminal on the client side, and the shell or command on the server side.
The user program terminates.
All X11 forwarding and TCP/IP forwarding is stopped. Any X11 connections and TCP/IP connections that already exist remain open.
The server sends the command exit to the client, and both sides exit.
The characteristics of a Solaris Secure Shell session are controlled by configuration files, which can be overridden to a certain degree by options on the command line.
In most cases, the client-side characteristics of a Solaris Secure Shell session are governed by the system-wide configuration file, /etc/ssh/ssh_config, which is set up by the administrator. The settings in the system-wide configuration file can be overridden by the user's configuration in $HOME/.ssh/config. In addition, the user can override both configuration files on the command line.
The command line options are client requests and are permitted or denied on the server side by the /etc/ssh/sshd_config file (see ssh_config(4)). The configuration file keywords and command options are introduced in the following sections and are described in detail in the ssh(1), scp(1), sftp(1), and ssh_config(4) man pages. Note that in the two user configuration files, the Host keyword indicates a host or wildcard expression to which all following keywords up to the next Host keyword apply.
If it is useful to have different Solaris Secure Shell characteristics for different local hosts, the administrator can define separate sets of parameters in the /etc/ssh/ssh_config file to be applied according to host or regular expression. This task is done by grouping entries in the file by Host keyword. If the Host keyword is not used, the entries in the client configuration file apply to whichever local host a user is working on.
The authentication method is determined by setting one of the following keywords to “yes”:
DSAAuthentication
PasswordAuthentication
RhostsAuthentication
RhostsRSAAuthentication
The keyword UseRsh specifies that the rlogin and rsh commands be used, probably due to no Secure Shell support.
The Protocol keyword sets the Solaris Secure Shell protocol version to v1 or v2. You can specify both versions separated by a comma. The first version is tried and upon failure, the second version is used.
The IdentityFile keyword specifies an alternate file name to hold the user's private key.
The keyword Cipher specifies the v1 encryption algorithm, which might be blowfish or 3des. The keyword Ciphers specifies an order of preference for the v2 encryption algorithms: 3des-cbc, blowfish-cbc, and aes128–cbc. The commands ssh and scp have a -c option for specifying the encryption algorithm on the command line.
The known host files (/etc/ssh/ssh_known_hosts and $HOME/.ssh/known_hosts) contain the public keys for all hosts with which the client can communicate by using Solaris Secure Shell. The GlobalKnownHostsFile keyword specifies an alternate file instead of /etc/ssh/ssh_known_hosts. The UserKnownHostsFile keyword specifies an alternate to $HOME/.ssh/known_hosts.
The StrictHostKeyChecking keyword requires new hosts to be added manually to the known hosts file, and refuses any host whose public key has changed or whose public key is not in the known hosts file. The keyword CheckHostIP enables the IP address for hosts in the known host files to be checked, in case a key has been changed due to DNS spoofing.
The LocalForward keyword specifies a local TCP/IP port to be forwarded over a secure channel to a specified port on a remote host. The GatewayPorts keyword enables remote hosts to connect to local forwarded ports.
The command ssh enables port forwarding through these options:
-L, which specifies the local port to be forwarded to the specified port on the remote host
-R, which specifies a remote port to be forwarded to the local host and specified port
The ForwardX11 keyword redirects X11 connections to the remote host with the DISPLAY environment variable set. The XAuthLocation keyword specifies the location of the xauth program.
The NumberOfPasswordPrompts keyword specifies how many times the user is prompted for a password before Solaris Secure Shell quits. The ConnectionAttempts keyword specifies how many tries (at one try per second) are made before Solaris Secure Shell either quits or falls back to rsh if the FallBackToRsh keyword is set.
The Compression keyword enables compression of transmitted data. The CompressionLevel keyword sets a level of 1 to 9, trading off between speed and amount of compression.
User specifies an alternate user name. Hostname specifies an alternate name for a remote host. ProxyCommand specifies an alternate command name for starting Solaris Secure Shell. Any command that can connect to your proxy server can be used. The command should read from its standard input and write to its standard output.
Batchmode disables password prompts, which is useful for scripts and other batch jobs.
KeepAlive enables messages to indicate network problems due to host crashes. LogLevel sets the verbosity level for ssh messages.
EscapeChar defines a single character that is used as a prefix for displaying special characters as plain text.
The server-side characteristics of a Solaris Secure Shell session are governed by the /etc/ssh/sshd_config file, which is set up by the administrator.
Permitted authentication methods are indicated by theses keywords:
DSAAuthentication
RSAAuthentication
HostKey and HostDSAKey identify files that hold host public keys when the default file name is not used. KeyRegenerationInterval defines how often the server key is regenerated.
Protocol specifies the version. Ciphers specifies the encryption algorithms for v2. ServerKeyBits defines the number of bits in the server's key.
AllowTCPForwarding specifies whether TCP forwarding is permitted.
GatewayPorts allows remote hosts to connect to ports forwarded for the client. Port specifies the port number that sshd listens on. ListenAddress designates a specific local address that sshd listens to. If there is no ListenAddress specification, sshd listens to all addresses by default.
X11Forwarding allows X11 forwarding. X11DisplayOffset specifies the first display number that is available for forwarding. This keyword prevents sshd from interfering with real X11 servers. XAuthLocation specifies the location of the xauth program.
KeepAlive displays messages regarding broken connections and host crashes. LogLevel sets the verbosity level of messages from sshd. SyslogFacility provides a facility code for messages that are logged from sshd.
The AllowGroups, AllowUsers, DenyGroups, and DenyUsers keywords control which users can or cannot use ssh.
The LoginGraceTime, MaxStartups, PermitRootLogin, and PermitEmptyPasswords keywords set controls on users who are logging in. StrictModes causes sshd to check file modes and ownership of the user's files and home directory before login. UseLogin specifies whether login is used for interactive login sessions. Turning this keyword on should not be necessary and is not recommended for the Solaris environment.
Subsystem configures a file transfer daemon for using sftp.
Each host that needs to talk to another host securely must have the server's public key stored in the local host's /etc/ssh/ssh_known_hosts file. Although it is most convenient to update the /etc/ssh/ssh_known_hosts files by a script, this practice is heavily discouraged because it opens a major security vulnerability.
The /etc/ssh/ssh_known_hosts file should only be distributed by a secure mechanism as follows:
Over a secure connection such as Solaris Secure Shell, IPsec, or kerberized ftp from a known and trusted machine
At system install time
To avoid the possibility of an intruder gaining access by inserting bogus public keys into a known_hosts file, you should use the jumpstart server as the known and trusted source of the ssh_known_hosts file. The ssh_known_hosts file can be distributed during installation and by regularly running scripts on the individual hosts that pull in the latest version by using scp. This approach is secure because each host already has the public key of the jumpstart server.
The following table shows the important Solaris Secure Shell files and the suggested UNIX permissions.
Table 12–1 Solaris Secure Shell Files
The following table summarizes the major Solaris Secure Shell commands.
Table 12–2 Solaris Secure Shell Commands
