System Administration Guide: Security Services
Example—Connecting to Hosts Outside a Firewall From the Command Line
The -o option to the ssh command lets you type any line that is permitted in an ssh configuration file. In this case, the proxy command specification from the previous task is used.
  1. Specify the proxy commands and hosts in a configuration file.
  2. Run the ssh command. Include a proxy command specification as an argument to the -o option. For example, type the following:
    % ssh -o'Proxycommand=/usr/lib/ssh/ssh-http-proxy-connect \
    -h myProxyServer -p 8080 myOutsideHost 22' myOutsideHost
    This command substitutes the HTTP proxy command for ssh, uses port 8080 and myProxyServer as the proxy server, and connects to port 22 on myOutsideHost.
