The following example demonstrates how you can use local port forwarding to receive mail securely from a remote server.
myLocalHost% ssh -L 9143:myRemoteHost:143 myRemoteHost |
This command forwards connections to port 9143 on myLocalHost to port 143, which is the IMAP v2 server port on myRemoteHost. When the user launches a mail application, the user needs to specify the local port number. An example that uses the dtmail command is shown in Figure 11–1.
Note that the term localhost in this case and in Example—Using Remote Port Forwarding to Communicate Outside of a Firewall refers to the keyword that designates the user's local host. The localhost keyword should not be confused with myLocalHost. The myLocalHost variable is the hypothetical host name that identifies a local host in the examples in this chapter.
