IPv6 Administration Guide
How to Display IPv6 Name Service Information
In this procedure, you use the nslookup command to display IPv6 name service information.
  1. On the command line, type the following command:
    % /usr/sbin/nslookup
    The default server name and address appear, followed by the nslookup command angle bracket prompt.
  2. To see information about a particular host, type the following commands at the angle bracket prompt:
    >set q=any
    >host-name
  3. To see only AAAA records, type the following command at the angle bracket prompt:
    >set q=AAAA
  4. Quit the command by typing exit.
Example—Using nslookup to Display IPv6 Information
Default Server:  space1999.Eng.apex.COM
Address:  120.46.168.78
> set q=any
> vallejo
vallejo.ipv6.eng.apex.com      IPv6 address = fec0::9256:a00:fe12:528
vallejo.ipv6.eng.apex.com      IPv6 address = 2::9256:a00:fe12:528
> exit
