In this procedure, you use the nslookup command to display PTR records for DNS IPv6.
On the command line, type the following command:
% /usr/sbin/nslookup |
The default server name and address display, followed by the nslookup command angle bracket prompt.
To see the PTR records, type the following command at the angle bracket prompt:
>set q=PTR |
Quit the command by typing exit.
% /usr/sbin/nslookup Default Server: space1999.Eng.apex.COM Address: 120.46.168.78 > set q=PTR > 8.2.5.0.2.1.e.f.f.f.0.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0.ip6.int 8.2.5.0.2.1.e.f.f.f.0.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0.ip6.int name = vallejo.ipv6.Eng.apex.COM ip6.int nameserver = space1999.Eng.apex.COM > exit |
