Format a disk
Any existing data is destroyed when you reformat a disk.
The need for formatting a disk drive has dropped as more and
more manufacturers ship their disk drives formatted and partitioned. You might
not need to use the format utility when you add a disk
drive to an existing system.
If a disk has been relocated and is displaying a lot of disk
errors, you can attempt to reformat it, which will automatically remap any
bad sectors.
How to Format a Disk
Replace a system disk
SPARC: How to Connect a System Disk and Boot
or x86: How to Connect a System Disk and Boot or if the system must be reinstalled, Solaris 9 Installation
Guide
Divide a disk into slices
SPARC: How to Create Disk Slices and Label a Disk
or x86: How to Create Disk Slices and Label a Disk
Add a secondary disk to an existing
system
SPARC: How to Connect a Secondary Disk and Boot
or x86: How to Connect a Secondary Disk and Boot
Repair a disk drive
Some customer sites prefer to replace rather than repair defective
drives. If your site has a repair contract with the disk drive manufacturer,
you might not need to use the format utility to repair
disk drives.
The repair of a disk drive usually means that a bad sector
is added to a defect list. New controllers remap bad sectors automatically
with no system interruption.
If the system has an older controller, you might need to remap
a bad sector and restore any lost data.
Repairing a Defective Sector
