System Administration Guide: Basic Administration
When to Use the format Utility
Disk drives are partitioned and labeled by the Solaris installation program when you install the Solaris release. You can use the format utility to do the following:
The main reason a system administrator uses the format utility is to divide a disk into disk slices. These steps are covered in Chapter 34, SPARC: Adding a Disk (Tasks) and Chapter 35, x86: Adding a Disk (Tasks).
See the following section for guidelines on using the format utility.
