Use the following procedure to expand a UFS file system to greater than 1 terabyte in size. This procedure assumes that the newfs -T option was used initially to create the UFS file system.
Become superuser.
Identify the size of the current disk or volume.
For example, the following volume is 800 gigabytes.
# metastat d98
d98: Concat/Stripe
Size: 1677754368 blocks (800 GB)
Stripe 0:
Device Start Block Dbase Reloc
c0t1d0s4 0 No Yes
Stripe 1:
c3t7d0s4 0 No Yes
Increase the volume to greater than 1 terabyte.
For example:
# metattach d98 c1t1d0s4
d98: component is attached
# metastat d98
d98: Concat/Stripe
Size: 2516631552 blocks (1.2 TB)
Stripe 0:
c0t1d0s4 0 No Yes
Stripe 1:
c3t7d0s4 0 No Yes
Stripe 2:
c1t1d0s4 0 No Yes
Expand the UFS file system for the disk or volume to greater than 1 terabyte.
For example:
growfs -v /dev/md/rdsk/d98
/usr/lib/fs/ufs/mkfs -G /dev/md/rdsk/d98 2516631552
/dev/md/rdsk/d98: 2516631552 sectors in 68268 cylinders of 144 tracks,
256 sectors
1228824.0MB in 2731 cyl groups (25 c/g, 450.00MB/g, 448 i/g)
super-block backups (for fsck -F ufs -o b=#) at:
32, 921888, 1843744, 2765600, 3687456, 4609312, 5531168, 6453024, 7374880,
8296736,
Initializing cylinder groups:
super-block backups for last 10 cylinder groups at:
2507714848, 2508636704, 2509558560, 2510480416, 2511402272, 2512324128,
2513245984, 2514167840, 2515089696, 2516011552,
Mount and verify the expanded file system.
For example:
# mount /dev/md/dsk/d98 /datadir # df -h /datadir Filesystem size used avail capacity Mounted on /dev/md/dsk/d98 1.2T 64M 1.2T 1% /datadir |
