Use the following error messages and solutions to troubleshoot problems with multiterabyte UFS file systems.
mount: /dev/rdsk/c0t0d0s0 is not this fstype. |
You attempted to mount a UFS file system that is greater than 1 terabyte on a system running a Solaris release prior to the Solaris 9 8/03 release.
Mount a UFS file system that is greater than 1 terabyte on a system running the Solaris 9 8/03 or later release.
"File system was not set up with the multi-terabyte format." "Its size cannot be increased to a terabyte or more." |
You attempted to expand a file system that was not created with the newfs -T command.
Restore the UFS file system from a backup tape or copy it from a detached mirror. Then, re-create the file system as a multiterabyte UFS file system. Or, copy the file system and re-create it with the newfs -T command.
