To edit entries in the table, follow these instructions.
Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
For information about roles, refer to “Using Privileged Applications” in System Administration Guide: Security Services.
Display the alias entry.
# aliasadm -m alias |
Use the assigned alias name.
Edit the alias entry, as necessary.
# aliasadm -c alias expanded_alias [options comments] |
If necessary, edit the alias name.
If necessary, edit the expanded alias name.
If necessary, edit the option.
If necessary, edit the comment for this entry.
For more information, refer to the aliasadm(1M) man page, as well as Mail Alias Files.
Display the entry that you have edited and ensure that the entry is correct.
For more information, refer to the aliasadm(1M) man page.
