Provides overview information for PPP
Provides planning information for PPP
Provides step-by-step instructions for setting up a dial-up PPP link
Provides step-by-step instructions for setting up a leased-line PPP link
Provides step-by-step instructions for setting up authentication on a PPP link
Provides step-by-step instructions for creating PPPoE tunnels to support PPP links over DSL equipment.
Provides instructions for PPP link maintenance and problem solving
Provides detailed reference information for working with PPP
Provides step-by-step instructions for migrating from the earlier Solaris PPP (asppp) to Solaris PPP 4.0
Provides background information on UUCP
Provides step-by-step instructions for setting up and troubleshooting UUCP
Provides reference material on UUCP database files, UUCP configuration files, UUCP shell scripts, and UUCP troubleshooting information
Solaris PPP 4.0 enables two computers in different physical locations to communicate with each other by using Point-to-Point Protocol (PPP) over a variety of media. The Solaris 9 operating environment includes Solaris PPP 4.0 as part of the base installation.
This chapter introduces Solaris PPP 4.0. Topics that are discussed include the following:
Solaris PPP 4.0 implements the Point-to-Point Protocol (PPP), a data link protocol, which is a member of the TCP/IP protocol suite. PPP describes how data is transmitted between two endpoint machines, over communications media such as telephone lines.
Since the early 1990s, PPP has been a widely used Internet standard for sending datagrams over a communications link. The PPP standard is described in RFC 1661 by the Point-to-Point Working Group of the Internet Engineering Task Force (IETF). PPP is commonly used when remote computers call an Internet service provider (ISP) or a corporate server that is configured to receive incoming calls.
Solaris PPP 4.0 is based on the publicly available Australian National University (ANU) PPP–2.4 and implements the PPP standard. Both asynchronous and synchronous PPP links are supported.
Various versions of standard PPP are available and in wide use throughout the Internet community. ANU PPP-2.4 is a popular choice for Linux, Tru64 UNIX,and all three major BSD variants:
FreeBSD
OpenBSD
NetBSD
Solaris PPP 4.0 brings the highly configurable features of ANU PPP-2.4 to machines that run the Solaris operating environment. Machines that run Solaris PPP 4.0 can easily set up PPP links to any machine that runs an implementation of standard PPP.
Some non-ANU-based PPP implementations that successfully interoperate with Solaris PPP 4.0 include the following:
Solaris PPP, also known as asppp, available with the Solaris 2.4 through Solaris 8 operating environments
SolsticeTM PPP 3.0.1
Microsoft Windows 98 DUN
Cisco IOS 12.0 (synchronous)
Solaris PPP 4.0 is the PPP implementation that is supported by the Solaris 9 operating environment. The Solaris 9 operating environment does not include the earlier asynchronous PPP (asppp) software. Asynchronous PPP configuration is discussed in the Solaris 8 System Administrator Collection at http://www.docs.sun.com.
If you currently use asppp, consider migrating to Solaris PPP 4.0. Note the following differences between the two Solaris PPP technologies:
Transfer modes
asppp supports asynchronous communications only. Solaris PPP 4.0 supports both asynchronous communications and synchronous communications.
Configuration process
Setting up asppp requires configuring the asppp.cf configuration file, three UUCP files, and the ifconfig command. Moreover, you have to preconfigure interfaces for all users who might log in to a machine.
Setting up Solaris PPP 4.0 requires defining options for the PPP configuration files, or issuing the pppd command with options. You can also use a combination of both the configuration file and command-line methods. Solaris PPP dynamically creates and removes interfaces. You do not have to directly configure PPP interfaces for each user.
Solaris PPP 4.0 features not available from asppp
MS-CHAPv1 and MS-CHAPv2 authentication
PPP over Ethernet (PPPoE) , to support ADSL bridges
PAM authentication
Plug-in modules
IPv6 addressing
Data compression that uses Deflate or BSD compress
If you are converting an existing asppp configuration to Solaris PPP 4.0, you can use the translation script that is provided with this release. For complete instructions, refer to How to Convert From asppp to Solaris PPP 4.0.
Many resources with information about PPP can be found in print and online. The following subsections give some suggestions.
For more information about widely used PPP implementations, including ANU PPP, refer to the following books:
Carlson, James. PPP Design, Implementation, and Debugging. 2nd ed. Addison-Wesley, 2000.
Sun, Andrew. Using and Managing PPP. O'Reilly & Associates, 1999.
Go to the following web sites for general information about PPP:
For a list of frequently asked questions (FAQ) and other information about pppd, go to the following site that is provided by the Internet Engineering group at Sun Microsystems, http://playground.sun.com/pppd.
For ANU PPP information, go to the PPP repository of Australian National University, http://.pserver.samba.org/cgi-bin/cvsweb/ppp/.
For technical information, FAQs, discussions about Solaris system administration, and earlier versions of PPP, go to Sun Microsystem's system administrators' resource, http://www.sun.com/bigadmin/home/index.html.
For modem configuration and advice on many different implementations of PPP, refer to Stokely Consulting's Web Project Management & Software Development web site: http://www.stokely.com/unix.serial.port.resource/ppp.slip.htm.
Some useful Internet RFCs about PPP include the following:
1661 and 1662, which describe the major features of the PPP protocol
1334, which describes authentication protocols, such as Password Authentication Protocol (PAP) and Challenge-Handshake Authentication Protocol (CHAP)
2516, an informational RFC that describes PPP over Ethernet (PPPoE)
To obtain copies of PPP RFCs, specify the number of the RFC on the IETF RFC web page at http://www.ietf.org/rfc.html .
For technical details about the Solaris PPP 4.0 implementation, refer to the following man pages:
You can find the PPP-related man pages at http://www.docs.sun.com or through the man command.This section introduces PPP configurations. The section also defines terms that are used in this guide.
Solaris PPP 4.0 supports a number of configurations.
Switched access, or dial-up, configurations
Hardwired, or leased-line configurations
The previous figure shows a basic PPP link. The link has the following parts:
Two machines, usually in separate physical locations, called peers. A peer could be a personal computer, engineering workstation, large server, or even a commercial router, depending on a site's requirements.
Serial interface on each peer. On Solaris machines, this interface could be cua, hih, or other interface, depending on whether you configure asynchronous or synchronous PPP.
Physical link, such as a serial cable, a modem connection, or a leased line from a network provider, such as a T1 or T3 line.
The most commonly used PPP configuration is the dial-up link. In a dial-up link, the local peer dials up the remote peer to establish the connection and run PPP. In the dial-up process, the local peer calls the remote peer's telephone number to initiate the link.
A common dial-up scenario includes a home computer that calls a peer at an ISP, configured to receive incoming calls. Another scenario is a corporate site where a local machine transmits data over a PPP link to a peer in another building.
In this guide, the local peer that initiates the dial-up connection is referred to as the dial-out machine. The peer that receives the incoming call is referred to as the dial-in server. This machine is actually the target peer of the dial-out machine and might or might not be a true server.
PPP is not a client-server protocol. Some PPP documents use the terms “client” and “server” to refer to telephone call establishment. A dial-in server is not a true server like a file server or name server. Dial-in server is a widely used PPP term because dial-in machines often “serve” network accessibility to more than one dial-out machine. Nevertheless, the dial-in server is the target peer of the dial-out machine.
The configuration for Location 1, the dial-out side of the link, is composed of the following elements:
Dial-out machine, typically a personal computer or workstation in an individual's home.
Serial interface on the dial-out machine. /dev/cua/a or /dev/cua/b is the standard serial interface for outgoing calls on machines that run Solaris software.
Asynchronous modem or ISDN terminal adapter (TA) that is connected to a telephone jack.
Telephone lines and services of a telephone company.
Telephone jack or similar connector, which is connected to the telephone network
Asynchronous modem or ISDN TA
Serial interface on the dial-in server, either ttya or ttyb for incoming calls
Dial-in server, which is connected to a network, such as a corporate intranet, or, in the instance of an ISP, the global Internet
External ISDN TAs have faster speeds than modems, but you configure TAs in basically the same way. The major difference in configuring an ISDN TA is in the chat script, which requires commands specific to the TA's manufacturer. Refer to Chat Script for External ISDN TA for information on chat scripts for ISDN TAs.
PPP configuration files on both the dial-out and dial-in peers contain instructions for setting up the link. The following process occurs as the dial-up link is initiated:
User or process on the dial-out machine runs the pppd command to start the link.
Dial-out machine reads its PPP configuration files. The dial-out machine then sends instructions over the serial line to its modem, including the phone number of the dial-in server.
Modem dials the phone number to establish a telephone connection with the modem on the dial-in server.
If necessary, the dial-out machine sends commands to the dial-in server to invoke PPP on the server.
Modem attached to the dial-in server begins link negotiation with the modem on the dial-out machine.
The series of text strings that the dial-out machine sends to the modem and dial-in server are contained in a file called a chat script.
When modem-to-modem negotiation completes, the modem on the dial-out machine reports “CONNECT.”
PPP on both peers enters Establish phase, where Link Control Protocol (LCP) negotiates basic link parameters and the use of authentication.
If necessary, the peers authenticate each other.
PPP's Network Control Protocols (NCPs) negotiate the use of network protocols, such as IPv4 or IPv6.
A hardwired, leased-line PPP configuration involves two peers that are connected by a link. This link consists of a switched or an unswitched digital service leased from a provider. Solaris PPP 4.0 works over any full-duplex, point-to-point leased-line medium. Typically, a company rents a hardwired link from a network provider to connect to an ISP or other remote site.
Both dial-up and leased-line links involve two peers that are connected by a communications medium. The next table summarizes the differences between the link types.
Leased Line |
Dial-up Line |
Always connected, unless a system administrator or power failure takes the leased-line down |
Initiated on demand, when a user tries to call a remote peer |
Uses synchronous communications |
Uses asynchronous communications |
Rented from a provider |
Uses existing telephone lines |
Requires synchronous units |
Uses less costly modems |
Requires specialized interfaces |
Uses standard serial interfaces that are included on most computers |
The leased-line link contains the following parts:
Two peers, each peer at one end of the link. Each peer might be a workstation or server. Often the peer functions as a router between its network or the Internet, and the opposite peer.
Synchronous interface on each peer. Some machines that run Solaris software require you to purchase a synchronous interface card, such as HSI/S, to connect to a leased line. Other machines, such as UltraSPARCTM workstations, have built-in synchronous interfaces.
CSU/DSU synchronous digital unit on each peer, which connects the synchronous port to the leased line.
A CSU might be built-in to the DSU, or owned by you, or leased from a provider, depending on your locale. The DSU gives the Solaris machine a standard synchronous serial interface. With Frame Relay, the Frame Relay Access Device (FRAD) performs the serial interface adaptation.
Leased line, providing switched or unswitched digital services. Some examples are SONET/SDH, Frame Relay PVC, and T1.
SONET is called an octet synchronous link. PPP uses a framing mechanism that is similar to asynchronous framing over a SONET line. PPP does not use the expected bit-synchronous protocol.
On most types of leased lines, peers do not actually dial each other. Rather, a company purchases a leased-line service to explicitly connect between two fixed locations. Sometimes the two peers at either end of the leased line are at different physical locations of the same company. Another scenario is a company that sets up a router on a leased line that is connected to an ISP.
Leased lines are less commonly used than dial-up links, though the hardwired links are easier to set up. Hardwired links do not require chat scripts. Authentication is often not used because both peers are known to each other when a line is leased. After the two peers initiate PPP over the link, the link stays active. A leased-line link remains active unless the line fails, or either peer explicitly terminates the link.
A peer on a leased line that runs Solaris PPP 4.0 uses most of the same configuration files that define a dial-up link.
The following process occurs to initiate communication over the leased line:
Each peer machine runs the pppd command as part of the booting process or another administrative script.
The peers read their PPP configuration files.
The peers negotiate communications parameters.
An IP link is established.
Authentication is the process of verifying that a user is who he or she claims to be. The UNIX login sequence is a simple form of authentication:
The login command prompts the user for a name and password.
login then attempts to authenticate the user by looking up the typed user name and password in the password database.
If the database contains the user name and password, then the user is authenticated and given access to the system. If the database does not contain the user name and password, the user is denied access to the system.
By default, Solaris PPP 4.0 does not demand authentication on machines that do not have a default route specified. Thus, a local machine without a default route does not authenticate remote callers. Conversely, if a machine does have a default route defined, by default the machine does authenticate remote callers.
You might use PPP authentication protocols to verify the identity of callers who are trying to set up a PPP link to your machine. Conversely, you must configure PPP authentication information if your local machine must call peers that authenticate callers.
The calling machine on a PPP link is considered the authenticatee because the caller must prove its identity to the remote peer. The peer is considered the authenticator. The authenticator looks up the caller's identity in the appropriate PPP files for the security protocol and authenticates or does not authenticate the caller.
You typically configure PPP authentication for a dial-up link. When the call begins, the dial-out machine is the authenticatee. The dial-in server is the authenticator. The server has a database in the form of a secrets file. This file lists all users who are granted permission to set up a PPP link to the server. Think of these users as trusted callers.
Some dial-out machines require remote peers to provide authentication information when responding to the dial-out machine's call. Then, their roles are reversed: the remote peer becomes the authenticatee and the dial-out machine the authenticator.
PPP 4.0 does not prevent authentication by leased-line peers, but authentication is not often used in leased-line links. The nature of leased-line contracts usually means that both participants on the ends of the line are known to each other. Both participants often are trusted. However, because PPP authentication is not that difficult to administer, you should seriously consider implementing authentication for leased lines.
The PPP authentication protocols are Password Authentication Protocol (PAP) and Challenge-Handshake Authentication Protocol (CHAP). Each protocol uses a secrets database that contains identification information, or security credentials, for each caller that is permitted to link to the local machine. For a detailed explanation of PAP, see Password Authentication Protocol (PAP). For a CHAP explanation, see Challenge-Handshake Authentication Protocol (CHAP).
Providing authentication on a PPP link is optional. Moreover, though authentication does verify that a peer is to be trusted, PPP authentication does not provide confidentiality of data. For confidentiality, use encryption software, such as IPsec, PGP, SSL, and the Solaris secure shell.
Solaris PPP 4.0 does not implement the PPP Encryption Control Protocol (ECP), which is described in RFC 1968.
Consider implementing PPP authentication in the following situations:
Your company accepts incoming calls from users over the public, switched telephone network.
Your corporate security policy requires remote users to provide authentication credentials when accessing your network through a corporate firewall or when engaging in secure transactions.
You want to authenticate callers against a standard UNIX password database, such as /etc/passwd, NIS, NIS+, LDAP, or PAM. Use PAP authentication for this scenario.
Your company's dial-in servers also provide the network's Internet connection. Use PAP authentication for this scenario.
The serial line is less secure than the password database on the machine or networks at either end of the link. Use CHAP authentication for this scenario.
Many network providers and individuals who are working at home use Digital Subscriber Line (DSL) technology to provide fast network access. To support DSL users, Solaris PPP 4.0 includes the PPP over Ethernet (PPPoE) feature. PPPoE technology enables multiple hosts to run PPP sessions over one Ethernet link to one or more destinations.
If one of the following factors applies to your situation, you should use PPPoE:
You support DSL users, possibly including yourself. Your DSL service provider might require users to configure a PPPoE tunnel to receive services over the DSL line.
Your site is an ISP that intends to offer PPPoE to customers.
PPPoE is a proprietary protocol from RedBack Networks. PPPoE is a discovery protocol, rather than another version of standard PPP. In a PPPoE scenario, a machine that initiates PPP communications first must locate, or discover, a peer that runs PPPoE. The PPPoE protocol uses Ethernet broadcast packets to locate the peer.
After the discovery process, PPPoE sets up an Ethernet-based tunnel from the initiating host, or PPPoE client, to the peer, the PPPoE access server.Tunneling is the practice of running one protocol on top of another protocol. Using PPPoE, Solaris PPP 4.0 tunnels PPP over Ethernet IEEE 802.2, both of which are data link protocols. The resulting PPP connection behaves like a dedicated link between the PPPoE client and the access server. For detailed information about PPPoE, see Creating PPPoE Tunnels for DSL Support.
Three participants are involved in a PPPoE configuration: a consumer, a telephone company, and a service provider, as the following figure shows.
As system administrator, you might assist consumers with their PPPoE configurations. One common type of PPPoE consumer is an individual who needs to run PPPoE over a DSL line. Another PPPoE consumer is a company that purchases a DSL line through which employees can run PPPoE tunnels, as illustrated in the previous figure.
The main reason for a corporate consumer to use PPPoE is to offer PPP communications through a high-speed DSL device to a number of hosts. Often, a single PPPoE client has an individual DSL modem. Or, a group of clients on a hub might share a DSL modem that is also connected to the hub by an Ethernet line.
DSL devices are technically bridges, not modems. However, because common practice is to refer to these devices as modems, this guide uses the term “DSL modem.”
PPPoE runs PPP over a tunnel on the Ethernet line that is connected to the DSL modem. That line is connected to a splitter, which, in turn connects to a telephone line.
The telephone company is the middle layer of the PPPoE scenario. The telephone company splits the signal that is received over the phone line by using a device that is called a Digital Subscriber Line Access Multiplexer (DSLAM). The DSLAM breaks out the signals onto separate wires, analog wires for telephone service, and digital wires for PPPoE. From the DSLAM, the digital wires extend the tunnel over an ATM data network to the ISP.
The ISP receives the PPPoE transmission from the ATM data network over a bridge. At the ISP, an access server that runs PPPoE functions as the peer for the PPP link. The access server is very similar in function to the dial-in server that was introduced in Figure 25–2, but the access server does not use modems. The access server converts the individual PPPoE sessions into regular IP traffic, for example Internet access.
If you are a system administrator for an ISP, you might be responsible for configuring and maintaining an access server.
The PPPoE tunnel is inherently insecure. You can use PAP or CHAP to provide user authentication for the PPP link that is running over the tunnel.
Setting up a PPP link involves a set of discrete tasks, which includes planning tasks and other activities that are not related to PPP. This chapter explains how to plan for the most common PPP links, for authentication, and for PPPoE.
The task chapters that follow Chapter 26, Planning for the PPP Link (Tasks) use sample configurations to illustrate how to set up a particular link. These sample configurations are introduced in this chapter.
Topics that are covered include the following:
PPP requires planning tasks before you actually can set up the link. Moreover, if you want to use a PPPoE tunneling, you first have to set up the PPP link and then provide tunneling. The following task map lists the large planning tasks that are discussed in this chapter. You might need to use only the general task for the link type to be configured. Or you might require the task for the link, authentication, and perhaps PPPoE.
Table 26–1 Task Map for PPP Planning
Task |
Description |
For Instructions |
Plan for a dial-up PPP link |
Gather information that is required to set up a dial-out machine or a dial-in server | |
Plan for a leased-line link |
Gather information that is required to set up a client on a leased line | |
Plan for authentication on the PPP link |
Gather information that is required to configure PAP or CHAP authentication on the PPP link | |
Plan for a PPPoE tunnel |
Gather information that is required to set up a PPPoE tunnel over which a PPP link can run |
Dial-up links are the most commonly used PPP links. This section includes the following information:
Planning information for a dial-up link
Explanation of the sample link to be used in Chapter 27, Setting Up a Dial-up PPP Link (Tasks)
Before you configure a dial-out machine, gather the information that is listed in the following table.
The planning information in this section does not include information to be gathered about authentication or PPPoE. For details on authentication planning, refer to Planning for Authentication on a Link. For PPPoE planning, refer to Planning for DSL Support Over a PPPoE Tunnel.
Information |
Action |
Maximum modem speed |
Refer to documentation that was provided by the modem manufacturer. |
Modem connection commands (AT commands) |
Name to use for dial-in server at the other end of the link |
Create any name that helps you identify the dial-in server. |
Login sequence that was required by dial-in server |
Contact the dial-in server's administrator or ISP documentation if dial-in server is at the ISP. |
Before you configure a dial-in server, gather the information that is listed in the following table.
Information |
Action |
User names of people who are permitted to call the dial-in server |
Obtain the names of the prospective users before you set up their home directories, as discussed in How to Configure Users of the Dial-in Server. |
Dedicated IP address for PPP communications |
Obtain an address from the individual at your company who is responsible for delegating IP addresses. |
The tasks to be introduced in Chapter 27, Setting Up a Dial-up PPP Link (Tasks) execute a small company's requirement to let employees work at home a few days a week. Some employees require the Solaris operating environment on their home machines. These workers also need to log in remotely to their work machines on the corporate intranet.
The tasks set up a basic dial-up link with the following features:
The dial-out machines are at the houses of employees who need to call the corporate intranet.
The dial-in server is a machine on the corporate intranet that is configured to receive incoming calls from employees.
UNIX-style login is used to authenticate the dial-out machine. Stronger Solaris PPP 4.0 authentication methods are not required by the company`s security policy.
The next figure shows the link that is set up in Chapter 27, Setting Up a Dial-up PPP Link (Tasks).
In this figure, a remote host dials out through its modem over telephone lines to Big Company's intranet. Another host is configured to dial out to Big Company but currently is inactive. The calls from remote users are answered in the order received by the modem that is attached to the dial-in server at Big Company. A PPP connection is established between the peers. The dial-out machine can then remotely log in to a host machine on the intranet.
Task |
For Information |
Set up a dial-out machine | |
Set up a dial-in machine | |
Get an overview of dial-up links | |
Get detailed information about PPP files and commands |
Setting up a leased-line link involves configuring the peer at one end of a switched or unswitched service leased from a provider.
Planning information for a leased-line link
Explanation of the sample link that is shown in Figure 26–2
When your company rents a leased-line link from a network provider, you typically configure only the system at your end of the link. The peer at the other end of the link is maintained by another administrator. This individual might be a system administrator at a remote location in your company or a system administrator at an ISP.
In addition to the link media, your end of the link requires the following hardware:
Synchronous interface for your system
Synchronous unit (CSU/DSU)
Your system
Some network providers include a router, synchronous interface, and a CSU/DSU as part of the customer premises equipment (CPE). However, necessary equipment varies, based on the provider and any governmental restrictions in your locale. The network provider can give you information about the unit that is needed, if this equipment is not provided with the leased line.
Before you configure the local peer, you might need to gather the items that are listed in the next table.
Table 26–4 Planning for a Leased-Line Link
Information |
Action |
Device name of the interface |
Refer to the Interface card documentation. |
Configuration instructions for the synchronous interface card |
Refer to the Interface card documentation. You need this information to configure the HSI/S interface. You might not need to configure other types of interface cards. |
(Optional) IP address of the remote peer |
Refer to the service provider documentation. Alternatively, contact the system administrator of the remote peer. This information is needed only if the IP address is not negotiated between the two peers. |
(Optional) Name of the remote peer |
Refer to the service provider documentation. Alternatively, you can contact the system administrator of the remote peer. |
(Optional) Speed of the link |
(Optional) Compression that is used by the remote peer |
The tasks in Chapter 28, Setting Up a Leased-Line PPP Link (Tasks) show how to implement the goal of a medium-sized organization (LocalCorp) to provide Internet access for its employees. Currently, the employees' computers are connected on a private corporate intranet.
LocalCorp requires speedy transactions and access to the many resources on the Internet. The organization signs a contract with Far ISP, a service provider, which allows LocalCorp to set up its own leased line to Far ISP. Then, LocalCorp leases a T1 line from Phone East, a telephone company. Phone East puts in the leased line between LocalCorp and Far ISP. Then, Phone East provides a CSU/DSU that is already configured to Local Corp.
The tasks set up a leased-line link with the following characteristics.
LocalCorp has set up a system as a gateway router, which forwards packets over the leased line to hosts on the Internet.
Far ISP also has set up a peer as a router to which leased lines from customers are attached.
In the figure, a router is set up for PPP at LocalCorp. The router connects to the corporate intranet through its hme0 interface. The second connection is through the machine's HSI/S interface (hih1) to the CSU/DSU digital unit. The CSU/DSU then connects to the installed leased line. The administrator at LocalCorp configures the HSI/S interface and PPP files. The administrator then types /etc/init.d/pppd to initiate the link between LocalCorp and FarISP.
Task |
For Information |
Set up a client on a leased line | |
Get an overview of leased lines |
This section contains planning information for providing authentication on the PPP link. Chapter 29, Setting Up PPP Authentication (Tasks) contains tasks for implementing PPP authentication at your site.
PPP offers two types of authentication, PAP, which is described in detail in Password Authentication Protocol (PAP) and CHAP, which is described in Challenge-Handshake Authentication Protocol (CHAP).
Before you set up authentication on a link, you must choose which authentication protocol best meets your site's security policy. Then, you set up the secrets file and PPP configuration files for the dial-in machines, or callers' dial-out machines, or both types of machines. For information on choosing the appropriate authentication protocol for your site, see Why Use PPP Authentication?.
Planning information for both PAP and CHAP authentication
Explanations of the sample authentication scenarios that are shown in Figure 26–3 and Figure 26–4
Setting up authentication at your site should be an integral part of your overall PPP strategy. Before implementing authentication, you should assemble the hardware, configure the software, and test the link.
Table 26–5 Prerequisites Before Configuring Authentication
Information |
For Instructions |
Tasks for configuring a dial-up link | |
Tasks for testing the link | |
Security requirements for your site |
Your corporate security policy. If you do not have a policy, setting up PPP authentication gives you an opportunity to create a security policy. |
Suggestions about whether to use PAP or CHAP at your site |
Why Use PPP Authentication?. For more detailed information about these protocols, refer to Authenticating Callers on a Link. |
This section contains the sample authentication scenarios to be used in the procedures in Chapter 29, Setting Up PPP Authentication (Tasks).
The tasks in Configuring PAP Authentication show how to set up PAP authentication over the PPP link. The procedures use as an example a PAP scenario that was created for the fictitious “Big Company” in Example—Configuration for Dial-up PPP.
Big Company wants to enable its users to work from home. The system administrators want a secure solution for the serial lines to the dial-in server. UNIX-style login that uses the NIS password databases has served Big Company's network well in the past. The system administrators want a UNIX-like authentication scheme for calls that come in to the network over the PPP link. So, the administrators implement the following scenario that uses PAP authentication.
The system administrators create a dedicated dial-in DMZ that is separated from the rest of the corporate network by a router. The term DMZ comes from the military term “demilitarized zone.” The DMZ is an isolated network that is set up for security purposes. The DMZ typically contains resources that a company offers to the public, such as web servers, anonymous FTP servers, databases, and modem servers. Network designers often place the DMZ between a firewall and a company's Internet connection.
The only occupants of the DMZ that is pictured in Figure 26–3 are the dial-in server myserver and the router. The dial-in server requires callers to provide PAP credentials, including user names and passwords, when setting up the link. Furthermore, the dial-in server uses the login option of PAP. Therefore, the callers' PAP user names and passwords must correspond exactly to their UNIX user names and passwords in the dial-in server's password database.
After the PPP link is established, the caller's packets are forwarded to the router. The router forwards the transmission to its destination on the corporate network or on the Internet.
The tasks in Configuring CHAP Authentication show how to set up CHAP authentication. The procedures use as an example a CHAP scenario to be created for the fictitious LocalCorp that was introduced in Example—Configuration for a Leased-Line Link.
LocalCorp provides connectivity to the Internet over a leased line to an ISP. The Technical Support department within LocalCorp generates heavy network traffic. Therefore, Technical Support requires its own, isolated private network. The department's field technicians travel extensively and need to access the Technical Support network from remote locations for problem-solving information. To protect sensitive information in the private network's database, remote callers must be authenticated in order to be granted permission to log in.
Therefore, the system administrators implement the following CHAP authentication scenario for a dial-up PPP configuration.
The only link from the Technical Support network to the outside world is the serial line to the dial-in server's end of the link. The system administrators configure the laptop computer of each field service representative for PPP with CHAP security, including a CHAP secret. The chap-secrets database on the dial-in server contains the CHAP credentials for all machines that are allowed to call in to the Technical Support network.
Task |
For Instructions |
Set up PAP authentication | |
Set up CHAP authentication | |
Learn details about PPP authentication |
Authenticating Callers on a Link and the pppd(1M) man page |
Some DSL providers require you to set up PPPoE tunneling for your site in order to run PPP over the providers' DSL lines and high-speed digital networks. For an overview of PPPoE, see Support for DSL Users Through PPPoE.
A PPPoE tunnel involves three participants: a consumer, a telephone company, and an ISP. You either configure PPPoE for consumers—PPPoE clients at your company or consumers in their homes—or on a server at an ISP.
This section contains planning information for running PPPoE on both clients and access servers. The following topics are covered:
Planning information for the PPPoE host and access server
Explanation of the PPPoE scenario that is introduced in Example—Configuration for a PPPoE Tunnel
Your preconfiguration activities depend on whether you configure the client side or server side of the tunnel. In either instance, you or your organization must contract with a telephone company. The telephone company provides the DSL lines for clients, and some form of bridging and possibly an ATM pipe for access servers. In most contracts, the telephone company assembles its equipment at your site.
PPPoE client implementations usually consist of the following equipment:
Personal computer or other system used by an individual
DSL modem, which is usually installed by the telephone company or Internet access provider
(Optional) A hub, if more than one client is involved, as is true for corporate DSL consumers
(Optional) A splitter, usually installed by the provider
Many different DSL configurations are possible, which depend on the user or corporation's needs and the services that are offered by the provider.
Table 26–6 Planning for PPPoE Clients
Information |
Action |
If setting up a home PPPoE client for an individual or yourself, get any setup information that is outside the scope of PPPoE. |
Ask the telephone company or ISP for any required setup procedures. |
If setting up PPPoE clients at a corporate site, get the names of users to get PPPoE client systems. If you configure remote PPPoE clients, you might be responsible for giving users information about adding home DSL equipment. |
Ask management at your company for a list of authorized users. |
Find out what interfaces are available on the PPPoE client. |
Run the ifconfig -a command on each machine for interface names. |
(Optional) Get the password for the PPPoE client. |
Ask users for passwords their preferred passwords. Or, assign passwords to the users. Note that this password is used for link authentication, not for UNIX login. |
Planning for a PPPoE access server involves working with the telephone company that provides your connection to its data service network. The telephone company installs its lines, often ATM pipes, at your site, and provides some sort of bridging into your access server. You need to configure the Ethernet interfaces that access the services that your company provides. For example, you need to configure interfaces for Internet access, as well as the Ethernet interfaces from the telephone company's bridge.
Table 26–7 Planning for a PPPoE Access Server
Information |
Action |
Interfaces that are used for lines from data service network |
Run the ifconfig -a command to identify interfaces. |
Types of services to provide from the PPPoE server |
Ask management, network planners for their requirements and suggestions. |
(Optional) Types of services to provide to the consumers |
(Optional) Host names and passwords for remote clients |
Ask network planners and other individuals at your site who are responsible for contract negotiations. The host names and passwords are used for PAP or CHAP authentication, not UNIX login. |
This section contains a sample PPPoE tunnel, which is used as an illustration for the tasks in Chapter 30, Setting Up a PPPoE Tunnel (Tasks). Though the illustration shows all participants in the tunnel, you only administer one end, either the client side or server side.
In the sample, MiddleCo wants to provide its employees with high-speed Internet access. MiddleCo buys a DSL package from Phone East, which, in turn, contracts with service provider Far ISP. Far ISP offers Internet and other IP services to customers who buy DSL from Phone East.
MiddleCo buys a package from Phone East that provides one DSL line for the site. The package includes a dedicated, authenticated connection to the ISP for MiddleCo's PPPoE clients. The system administrator cables the prospective PPPoE clients to a hub. Technicians from Phone East cable the hub to their DSL equipment.
To implement the business arrangement FarISP has with Phone East, the system administrator at FarISP configures the access server dslserve. This server has the following four interfaces:
le0 – Primary network interface that connects to the local network
hme0 – Interface through which FarISP provides Internet service for its customers
hme1 – Interface contracted by MiddleCo for authenticated PPPoE tunnels
hme2 – Interface contracted by other customers for their PPPoE tunnels
Task |
For Instructions |
Set up a PPPoE client | |
Set up a PPPoE access server | |
Get detailed information about PPPoE |
Creating PPPoE Tunnels for DSL Support and the pppoed(1M), pppoec(1M), and sppptun(1M) man pages |
This chapter explains the tasks for configuring the most common PPP link, the dial-up link. Major topics include the following:
You set up the dial-up PPP link by configuring modems, modifying network database files, and modifying the PPP configuration files that are described in Table 32–1.
The next table lists the major tasks to configure both sides of a dial-up PPP link. Typically, you configure only one end of the link, either the dial-out machine or dial-in server.
Table 27–1 Task Map for Setting Up the Dial-up PPP Link
Task |
Description |
For Instructions |
1. Gather preconfiguration information |
Gather data that is needed prior to setting up the link, such as peer host names, target phone numbers, and modem speed. | |
2. Configure the dial-out machine |
Set up PPP on the machine that makes the call over the link. | |
3. Configure the dial-in server |
Set up PPP on the machine that receives incoming calls. | |
4. Call the dial-in server |
Type the pppd command to initiate communications. |
The tasks in this section explain how to configure a dial-out machine. The tasks use as an example the dial- in-from-home scenario that was introduced in Figure 26–1. You can perform the tasks at your company before passing on the machine to a prospective user. Alternatively, you can instruct experienced users in the setup of their home machines. Anyone setting up a dial-out machine must have root permission for that machine.
Task |
Description |
For Instructions |
2. Configure the modem and serial port |
Set up the modem and serial port. |
How to Configure the Modem and Serial Port (Dial-out Machine) |
3. Configure the serial-line communication |
Configure the characteristics of the transmission across the serial line. | |
4. Define the conversation between the dial-out machine and the peer |
Gather communications data for use when you create the chat script. | |
5. Configure information about a particular peer |
Configure PPP options to call an individual dial-in server. | |
6. Call the peer |
Solaris PPP 4.0 provides template files. Each template contains common options for a particular PPP configuration file. The next table lists the sample templates that can be used for setting up a dial-up link, and their equivalent Solaris PPP 4.0 files.
Template File |
PPP Configuration File |
For Instructions |
/etc/ppp/options.tmpl |
/etc/ppp/options | |
/etc/ppp/options.ttya.tmpl |
/etc/ppp/options.ttyname | |
/etc/ppp/myisp-chat.tmpl |
File with the name of your choice to contain the chat script | |
/etc/ppp/peers/myisp.tmpl |
/etc/ppp/peers/peer-name |
If you decide to use one of the template files, be sure to rename the template to its equivalent PPP configuration file. The one exception is the chat file template /etc/ppp/myisp-chat.tmpl. You can give chat scripts any names that you want.
The first task for setting up a dial-out PPP machine is to configure the devices on the serial line: the modem and serial port.
Tasks that apply to a modem usually apply to an ISDN TA.
Before performing the next procedure, you must have done the following.
Installed the Solaris 9 operating environment on the dial-out machine
Determined the optimum modem speed
Decided which serial port to use on the dial-out machine
Obtained the root password for the dial-out machine
For planning information, see Table 26–2.
Program the modem.
Even though a variety of modem types is available, most modems are shipped with the correct settings for Solaris PPP 4.0. The following table lists basic settings for modems that use Solaris PPP 4.0.
Table 27–3 Modem Settings for Dial-up PPP
Parameter |
Setting |
DCD |
Follow carrier |
DTR |
Low so that the modem hangs up-puts the modem on-hook |
Flow Control |
RTS/CTS for full-duplex hardware flow control |
Attention Sequences |
Disable |
If you have problems in setting up the link and suspect that the modem is at fault, first consult the modem manufacturer's documentation. Also, a number of sites on the World Wide Web offer help with modem programming. Finally, you can find some suggestions for clearing modem problems in How to Diagnose Modem Problems.
Attach the modem cables to the serial port on the dial-out machine and to the telephone jack.
Become superuser on the dial-out machine.
Run admintool, as explained in “Setting Up Terminals and Modems with Serial Ports Tool” in System Administration Guide: Advanced Administration.
Click the port where you have attached the modem, either port a or port b.
The Modify Serial Port window is displayed.
Specify modem direction as dial-out only.
You can set up the modem as bidirectional, the default template for admintool. However, the dial-out-only choice is more secure against possible intruders.
You can set the baud rate and timeout from admintool. However, the pppd daemon ignores these settings.
Click Okay to convey the changes.
The procedures in this section show how to configure communications over the serial line of the dial-out machine. Before you can use these procedures, you must have configured the modem and serial port, as described in How to Configure the Modem and Serial Port (Dial-out Machine).
The next tasks show how to enable the dial-out machine to successfully initiate communications with the dial-in server. Communications are initiated as defined in the options in the PPP configuration files. You need to create the following files:
/etc/ppp/options
Chat script
Solaris PPP 4.0 provides templates for the PPP configuration files, which you can customize to suit your needs. Refer to Dial-up PPP Template Files for detailed information about these files.
Create a file that is called /etc/ppp/options with the following entry:
lock |
The /etc/ppp/options file is used for defining global parameters that apply to all communications by the local machine. The lock option enables UUCP-style locking of the form /var/spool/locks/LK.xxx.yyy.zzz.
If the dial-out machine does not have an /etc/ppp/options file, only the superuser can run the pppd command. However, the /etc/ppp/options can be empty.
For a complete description of /etc/ppp/options, refer to /etc/ppp/options Configuration File.
(Optional) Create a file that is called /etc/ppp/options.ttyname for defining how communications should be initiated from a specific serial port.
The next example shows an /etc/ppp/options.ttyname file for the port with the device name /dev/cua/a.
# vi /etc/ppp/options.cua.a crtscts |
The PPP option crtscts tells the pppd daemon to turn on hardware flow control for serial port a.
For more information about the /etc/ppp/options.ttyname file, go to /etc/ppp/options.ttyname Configuration File.
Set the modem speed, as described in How to Set the Modem Speed.
Before the dial-out machine can initiate a PPP link, you must collect information about the dial-in server to become the peer. Then, you use this information to create the chat script, which describes the actual conversation between the dial-out machine and the peer.
Determine the speed at which the dial-out machine's modem needs to run.
For more information, see Configuring the Modem Speed.
Obtain the following information from the dial-in server's site:
Server's telephone number
Authentication protocol that is used, if appropriate
Login sequence that is required by the peer for the chat script
Obtain the names and IP addresses of name servers at the dial-in server's site.
Put instructions for initiating calls to the particular peer in a chat script.
For example, you might create the following chat script, /etc/ppp/mychat, to call the dial-in server myserver.
SAY "Calling the peer\n" TIMEOUT 10 ABORT BUSY ABORT 'NO CARRIER' ABORT ERROR REPORT CONNECT "" AT&F1&M5S2=255 TIMEOUT 60 OK ATDT1-123-555-1234 CONNECT \c SAY "Connected; logging in.\n" TIMEOUT 5 ogin:--ogin: pppuser TIMEOUT 20 ABORT 'ogin incorrect' ssword: \qmypassword "% " \c SAY "Logged in. Starting PPP on peer system.\n" ABORT 'not found' "" "exec pppd" ~ \c |
You do not invoke the chat script directly. Rather, you use the file name of the chat script as an argument to the connect option, which invokes the script.
If a peer runs Solaris or a similar operating system, consider using the previous chat script as a template for your dial-out machines.
Update DNS databases by creating the following /etc/resolv.conf file:
domain bigcompany.com nameserver 10.10.111.15 nameserver 10.10.130.8 |
Specifies that the peer's DNS domain is bigcompany.com.
Lists the IP addresses of name servers at bigcompany.com.
For complete details on DNS implementation, refer to “DNS Administration (Reference)” in System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Edit the /etc/nsswitch.conf file to have the DNS database searched first for host information.
hosts: dns [NOTFOUND=return] files |
Create the /etc/ppp/peers directory, and then add a file for the peer.
For example, you would create the following file to define the dial-in server myserver:
# cd /etc/ppp # mkdir peers # cd peers # vi myserver /dev/cua/a 57600 noipdefault defaultroute idle 120 noauth connect "chat -U 'mypassword' -T 1-123-555-1213 -f /etc/ppp/mychat" |
Specifies that the device /dev/cua/a should be used as the serial interface for calls to myserver.
Defines the speed of the link.
Specifies that for transactions with peer myserver, the dial-out machine initially has an IP address of 0.0.0.0. myserver assigns an IP address to the dial-out machine for every dial-up session.
Indicates that the link must time out after an idle period of 120 seconds.
Specifies that the peer myserver does not need to provide authentication credentials when negotiating the connection with the dial-out machine.
Specifies the connect option and its arguments, including the phone number of the peer, and the chat script /etc/ppp/mychat with calling instructions.
Task |
For Instructions |
Configure another dial-out machine |
How to Configure the Modem and Serial Port (Dial-out Machine). |
Test modem connectivity by dialing out to another computer |
cu(1C) and tip(1) man pages. These utilities can help you test if your modem is properly configured. Also, use these utitlities to test if you can establish a connection with another machine. |
Get detailed information about the PPP configuration files | |
Begin configuring the dial-in server |
The tasks in this section are for configuring the dial-in server. The dial-in server is a peer machine that receives the call over the PPP link from the dial-out machine. The tasks show how to configure the dial-in server myserver that was introduced in Figure 26–1.
Task |
Description |
For Instructions |
Set up the modem and serial port. | |
3. Configure calling peer information |
Set up the user environments and PPP options for every dial-out machine that is permitted to call the dial-in server. | |
4. Configure the serial-line communication. |
How to Define Communications Over the Serial Line (Dial-in Server) |
The following procedure explains how to configure the modem and serial port on the dial-in server.
Before you do the next procedure, you must have completed the following activities on the peer dial-in server:
Program the modem, as instructed in the modem manufacturer's documentation.
For other suggestions, refer to How to Configure the Modem and Serial Port (Dial-out Machine).
Attach the modem to the serial port on the dial-in server.
Become superuser on the dial-in server.
Configure the serial port by using admintool, as described in “Setting Up Terminals and Modems with Serial Ports Tool” in System Administration Guide: Advanced Administration.
Use admintool to do the following:
The next procedure explains how to set the modem speed for a dial-in server. For suggestions on speeds to use with Sun Microsystems' computers, see Configuring the Modem Speed.
Log in to the dial-in server.
Use the tip command to reach the modem.
Instructions for using tip to set the modem speed are in the tip(1) man page.
Configure the modem for a fixed DTE rate.
Lock the serial port to that rate, using ttymon or admintool, as discussed in “Setting Up Terminals and Modems with Serial Ports Tool” in System Administration Guide: Advanced Administration.
Task |
For Instructions |
Configure another serial port and modem on the dial-in server | |
Configure information about users that call the dial-in server |
Part of the process of setting up a dial-in server involves configuring information about each known remote caller.
Before starting the procedures in this section, you must have done the following:
Obtained the UNIX user names for all users who are permitted to log in from remote dial-out machines.
Set up the modem and serial line, as described in How to Configure the Modem and Serial Port (Dial-in Server).
Dedicated an IP address to be assigned to incoming calls from remote users. Consider creating a dedicated incoming IP address if the number of potential callers exceeds the number of modems and serial ports on the dial-in server. For complete information about creating dedicated IP addresses, go to Creating an IP Addressing Scheme for Callers.
Create a new account on the dial-in server for each remote PPP user.
You can use admintool or the Solaris Management Console to create a new user. For instructions on creating a new user through Solaris Management Console, see “Setting Up User Accounts (Task Map)” in System Administration Guide: Basic Administration. For instructions on creating a new user through admintool, see admintool(1M).
The remaining steps show how to create an account by using admintool. You can use the same parameters for creating an account with Solaris Management Console.
Use the Add User template to create the new user.
For example, the next table shows how you might fill out PPP-related parameters for an account that is called pppuser for user1 on the dial-out machine myhome.
Template Parameter |
Value |
Definition |
User Name |
pppuser |
The user account name for the remote user. This account name should correspond to the account name that is given in the login sequence of the chat script. For example, pppuser is the account name that is found in the chat script in How to Create the Instructions for Calling a Peer. |
Login Shell |
/usr/bin/pppd |
The default login shell for the remote user. The login shell /usr/bin/pppd initially restricts the caller to a dedicated PPP environment. |
Create Home Dir Path |
/export/home/pppuser |
The home directory /export/home/pppuser is set when the caller successfully logs in to the dial-in server. |
Create for each caller a $HOME/.ppprc file that contains various options that are specific to the user's PPP session.
For example, you might create the following .ppprc file for pppuser.
# cd /export/home/pppuser # vi .ppprc noccp |
Task |
For Instructions |
Set up more users of the dial-in server | |
Configure communications over the dial-in server |
The next task shows how to enable the dial-in server to open communications with any dial-out machine. The options that are defined in the following PPP configuration files determine how communications are established.
/etc/ppp/options
Before you proceed, you should have done the following:
Configured the serial port and modem on the dial-in server, as described in How to Configure the Modem and Serial Port (Dial-in Server).
Configured information about the prospective users of the dial-in server, as described in How to Configure Users of the Dial-in Server.
Create the /etc/ppp/options file with the following entry.
nodefaultroute |
nodefaultroute indicates that no route is defined for the server.
If the dial-in server does not have an /etc/ppp/options file, only the superuser can run the pppd command. However, the /etc/ppp/options file can be empty.
Create the file /etc/options.ttyname to define how calls that are received over serial port ttyname should be handled.
The following /etc/options.ttya file defines how the dial-in server's serial port /dev/ttya should handle incoming calls.
:10.0.0.80 xonxoff |
If you have followed all the procedures in this chapter, you have completed the configuration of the dial-up link.
Task |
For Instructions |
cu(1C) andtip(1) man pages. These utilities can help you test if your modem is properly configured. Also, use these utilities to test if you can establish a connection with another machine. |
Configure more options for the dial-in server | |
Configure more dial-out machines | |
Have the remote machine call the dial-in server |
You establish a dial-up PPP link by having the dial-out machine call the dial-in server. You can instruct the dial-out machine to call the server by specifying the demand option in the local PPP configuration files. However, the most common method for establishing the link is for the user to run the pppd command on the dial-out machine.
Before you proceed to the next task, you should have done either or both of the following:
Set up the dial-out machine, as described in Configuring the Dial-out Machine
Set up the dial-in server, as described in Configuring the Dial-in Server
Log in to the dial-out machine by using your regular user account, not root.
Call the dial-in server by running the pppd command.
For example, the following command initiates a link between the dial-out machine and dial-in server myserver:
% pppd 57600 call myserver |
Starts the call by invoking the pppd daemon
Sets the speed of the line between host and modem
Invokes the call option of pppd. pppd then reads options in the file /etc/ppp/peers/myserver, which was created in How to Define the Connection With an Individual Peer
Contact a host on the server's network, for example, the host lindyhop that is shown in Figure 26–1:
ping lindyhop |
If the link is working correctly, the standard Telnet login sequence should be displayed in the terminal window. If the link is not working correctly, refer to Chapter 31, Fixing Common Problems (Tasks).
Terminate the PPP session:
% pkill -TERM -x pppd |
Task |
For Instructions |
Have users start working on their dial-out machines | |
Fix problems on the link | |
Learn more about the files and options that are used in this chapter |
This chapter explains how to configure a PPP link that uses a leased line between peers. Major sections include the following:
Leased-line links are relatively easy to set up, in comparison with dial-up links. In most instances, you do not have to configure the CSU/DSU, dialing services, or authentication. If you do need to configure the CSU/DSU, refer to the manufacturer's documentation for aid with this complex task.
The task map in the next table describes all the tasks that are involved in setting up the basic leased-line link.
Some types of leased lines do require the CSU/DSU to “dial” the address of the opposite peer. Some examples are Frame Relay that uses Switched Virtual Circuits (SVCs) or Switched 56 service.
Task |
Description |
For Instructions |
Gather data that is needed prior to setting up the link. | |
2. Set up the leased-line hardware |
Assemble the CSU/DSU and synchronous interface card. | |
3. Configure the interface card, if required |
Configure the interface script to be used when the leased line is brought up. | |
4. Configure information about the remote peer |
Define how communications between your local machine and the remote peer should work. | |
5. Start up the leased line |
Configure your machine to start up PPP over the leased line as part of the booting process. |
The task in this section involves configuring equipment that is required by the leased-line topology that is introduced in Example—Configuration for a Leased-Line Link. The synchronous devices that are required to connect to the leased line include the interface and modem.
Before you perform the next procedure, you must have the following items:
Working leased line that is installed at your site by the provider
Solaris 9 operating environment release installed on your system
Synchronous interface card of the type that is required by your system
Physically install the interface card into the local machine, if necessary.
Follow the instructions in the manufacturer's documentation.
Connect the cables from the CSU/DSU to the interface. If necessary, connect cables from the CSU/DSU to the leased-line jack or similar connector.
Configure the CSU/DSU, as instructed in the documentation from the manufacturer or network provider.
The provider from whom you rented the leased line might supply and configure the CSU/DSU for your link.
Configure the interface card, if necessary, as instructed in the interface documentation.
The configuration of the interface card involves the creation of a startup script for the interface. The router at LocalCorp in the leased-line configuration that is shown in Figure 26–2 uses an HSI/S interface card.
The following script hsi-conf starts up the HSI/S interface.
#!/bin/ksh /opt/SUNWconn/bin/hsi_init hih1 speed=1536000 mode=fdx loopback=no \ nrzi=no txc=txc rxc=rxc txd=txd rxd=rxd signal=no 2>&1 > /dev/null |
Indicates that HSI/S is the synchronous port used
Sets the speed of the CSU/DSU to 1536000
Task |
For Instructions |
Configure the local machine on the leased line |
The task in this section explains how to set up a router to function as the local peer on your end of a leased line. The task uses the leased line that was introduced in Example—Configuration for a Leased-Line Link as an example.
Before you perform the next procedure, you must have completed the following:
Set up and configured the synchronous devices for the link, as described in Configuring Synchronous Devices on the Leased Line
Obtained the root password for the local machine on the leased line
Set up the local machine to run as a router on the network(s) to use the services of the leased-line provider
Add an entry for the remote peer in the router's /etc/hosts file.
# vi /etc/hosts # # Internet host table # 127.0.0.1 localhost 192.168.130.10 local2-peer loghost 192.168.130.11 local1-net 10.0.0.25 farISP |
The sample /etc/hosts file is for the local router at the fictitious LocalCorp. Note the IP address and host name for the remote peer farISP at the service provider.
Create the file /etc/ppp/peers/peer-name to hold information about the provider's peer.
For the sample leased-line link, you create the file /etc/ppp/peers/farISP.
#vi /etc/ppp/peers/farISP init '/etc/ppp/conf_hsi' local /dev/hih1 sync noauth 192.168.130.10:10.0.0.25 nodefaultroute passive persist noccp nopcomp novj noaccomp |
The following table explains the options and parameters that are used in /etc/ppp/peers/farISP.
Create an initialization script that is called demand, which creates the PPP link as part of the booting process.
# cd /etc/ppp/ # vi demand if [ -f /var/run/ppp-demand.pid ] && /usr/bin/kill -s 0 `/bin/cat /var/run/ppp-demand.pid` then : else /usr/bin/pppd call farISP fi |
The demand script contains the pppd command for establishing a leased-line link. The following table explains the contents of $PPPDIR/demand.
Code Sample |
Explanation |
echo "Starting Solaris PPP 4.0\c" |
Displays “Starting Solaris PPP 4.0” during the booting process. |
if ps -e | grep '\<pppd\ > /dev/null 2>&1 ; then echo "\npppd daemon is still running" echo "or in the process of exiting" exit 0 |
Search for an already existing pppd daemon.
If pppd is found, then send out a message and exit the demand script. |
echo "\nEstablishing PPP session...\n" |
Display “Establishing PPP session” during booting. |
/usr/bin/pppd call farISP |
Run the pppd command by using the options that are in /etc/ppp/peers/farISP. |
The Solaris PPP 4.0 startup script /etc/rc2.d/S47pppd invokes the demand script as part of the Solaris booting process. The following lines in /etc/rc2.dS47pppd search for the presence of a file that is called $PPPDIR/demand.
if [ -f $PPPDIR/demand ]; then . $PPPDIR/demand fi |
If found, $PPPDIR/demand is executed. During the course of executing $PPPDIR/demand, the link is established.
If you have followed all the procedures in this chapter, you have completed the configuration of the leased-line link.
Task |
For Instructions |
Instruct users to start communicating with machines on the Internet or other network that is served by the remote peer |
Have users run telnet, ftp, rsh, or similar commands to reach machines outside the local network. |
Fixing Leased-Line Problems for troubleshooting information. |
This chapter contains tasks for setting up PPP authentication. Subjects that are covered include the following:
The procedures show how to implement authentication over a dial-up link because dial-up links are more likely to be configured for authentication than leased-line links. You can configure authentication over leased lines if authentication is required by your corporate security policy. For leased-line authentication, use the tasks in this chapter as guidelines.
If you want to use PPP authentication but are not sure which protocol to use, review the section Why Use PPP Authentication?. More detailed information about PPP authentication is in the pppd(1M) man page and in Authenticating Callers on a Link.
This section contains task maps to help you quickly access procedures for PPP authentication.
Table 29–1 Task Map for General PPP Authentication
Task |
For Instructions |
Configure PAP authentication | |
Configure CHAP authentication |
The tasks in this section explain how to implement authentication on a PPP link by using the Password Authentication Protocol (PAP). The tasks use the example that is shown in Example—PPP Authentication Configurations to illustrate a working PAP scenario for a dial-up link. Use the instructions as the basis for implementing PAP authentication at your site.
Before you perform the next procedures, you must have done the following:
Set up and tested the dial-up link between the dial-in server and dial-out machines that belong to trusted callers
Ideally, for dial-in server authentication, obtained superuser permission for the machine where the network password database is administered, for example, in LDAP, NIS, or local files
Obtained superuser authority for the local machine, either dial-in server or dial-out machine
Use the next task maps to quickly access PAP-related tasks for the dial-in server and trusted callers on dial-out machines.
Table 29–2 Task Map for PAP Authentication (Dial-in Server)
Task |
Description |
For Instructions |
Collect user names and other data that is needed for authentication. | |
2. Update the password database, if necessary |
Ensure that all potential callers are in the server's password database. | |
3. Create the PAP database |
Create security credentials for all prospective callers in /etc/ppp/pap-secrets. | |
4. Modify the PPP configuration files |
Add options specific to PAP to the /etc/ppp/options and /etc/ppp/peers/peer-name files. |
How to Add PAP Support to the PPP Configuration Files (Dial-in Server) |
Table 29–3 Task Map for PAP Authentication (Dial-out Machine)
Task |
Description |
For Instructions |
2. Create the PAP database for the trusted caller's machine |
Create the security credentials for the trusted caller and, if necessary, security credentials for other users who call the dial-out machine, in /etc/ppp/pap-secrets. |
How to Configure PAP Authentication Credentials for the Trusted Callers |
3. Modify the PPP configuration files |
How to Add PAP Support to the PPP Configuration Files (Dial-out Machine) |
To set up PAP authentication, you must do the following:
Create a PAP credentials database
Modify PPP configuration files for PAP support
This procedure modifies the /etc/ppp/pap-secrets file, which contains the PAP security credentials that are used to authenticate callers on the link. /etc/ppp/pap-secrets must exist on both machines on a PPP link.
The sample PAP configuration that was introduced in Figure 26–3 uses the login option of PAP. If you plan to use this option, you might also need to update your network's password database. For more information on the login option, refer to Using the login Option With /etc/ppp/pap-secrets.
Assemble a list of all potential trusted callers. Trusted callers are people to be granted permission to call the dial-in server from their remote machines.
Verify that each trusted caller already has a UNIX user name and password in the dial-in server's password database.
Verification is particularly important for the sample PAP configuration, which uses the login option of PAP to authenticate callers. If you choose not to implement login for PAP, the callers' PAP user names do not have to correspond with their UNIX user names. For information on standard /etc/ppp/pap-secrets, refer to /etc/ppp/pap-secrets File.
Do the following if a potential trusted caller does not have a UNIX user name and password:
Become superuser on the dial-in server, and edit the /etc/ppp/pap-secrets file.
Solaris PPP 4.0 provides a pap-secrets file in /etc/ppp that contains comments about how to use PAP authentication but no options. You can add the following options at the end of the comments.
# user1 myserver "" * user2 myserver "" * myserver user2 serverpass * |
To use the login option of /etc/ppp/pap-secrets, you must type the UNIX user name of each trusted caller. Wherever a set of double quotes (““) appears in the third field, the password for the caller is looked up in the server's password database.
The entry myserver * serverpass * contains the PAP user name and password for the dial-in server. In Figure 26–3, the trusted caller user2 requires authentication from remote peers. Therefore, myserver's /etc/ppp/pap-secrets file contains PAP credentials for use when a link is established with user2.
Task |
For Instructions |
Modify the PPP configuration files to support PAP authentication |
Modifying the PPP Configuration Files for PAP (Dial-in Server) |
Set up PAP authentication on the dial-out machines of trusted callers |
Configuring PAP Authentication for Trusted Callers (Dial-out Machines) |
The tasks in this section explain how to update any existing PPP configuration files to support PAP authentication on the dial-in server.
The procedure uses the PPP configuration files that were introduced in How to Define Communications Over the Serial Line (Dial-in Server) as examples.
Log in to the dial-in server as superuser.
Add authentication options to the /etc/ppp/options file.
For example, you would add the options in bold to an existing /etc/ppp/options file to implement PAP authentication:
lock idle 120 nodefaultroute name myserver auth require-pap user myserver remotename user2 login |
Sets myserver as the PAP name of the user on the local machine. If the login option is used, the PAP name must be the same as the user's UNIX user name in the password database.
States that the server must authenticate callers before establishing the link.
Defines user2 as a peer that requires authentication credentials from the local machine.
Specifies that the local machine must use the login option of PAP for authentication wherever login is called for in the /etc/ppp/pap-secrets file.
Create an /etc/ppp/options.ttyname file, as described in How to Define Communications Over the Serial Line.
Set up the $HOME/.ppprc file for each remote caller, as explained in How to Configure Users of the Dial-in Server.
Task |
For Instructions |
Configure PAP authentication credentials for trusted callers of the dial-in server |
This section contains tasks for setting up PAP authentication on the dial-out machines of trusted callers. As system administrator, you can set up PAP authentication on the systems before distribution to prospective callers. Or, if the remote callers already have their machines, you can give these callers the tasks in this section.
Configuring PAP for trusted callers involves two tasks:
Configuring the callers' PAP security credentials
Configuring the callers' dial-out machines to support PAP authentication
This procedure shows how to set up PAP credentials for two trusted callers, one of which requires authentication credentials from remote peers. The steps in the procedure assume that you, the system administrator, are creating the PAP credentials on the trusted callers' dial-out machines.
Become superuser on a dial-out machine.
Using the sample PAP configuration that was introduced in Figure 26–3, assume that the dial-out machine belongs to user1.
Modify the pap-secrets database for the caller.
Solaris PPP 4.0 provides an /etc/ppp/pap-secrets file that contains helpful comments but no options. You can add the following options to this /etc/ppp/pap-secrets file.
# user1 myserver pass1 * |
Note that user1's password pass1 is passed in readable ASCII form over the link. myserver is caller user1's name for the peer.
Become superuser on another dial-out machine.
Using the PAP authentication example, assume that this dial-out machine belongs to the caller user2.
You can add the next options to the end of the existing /etc/ppp/pap-secrets file.
# user2 myserver pass2 * myserver user2 serverpass * |
In this example, /etc/ppp/pap-secrets has two entries. The first entry contains the PAP security credentials that user2 passes to dial-in server myserver for authentication.
user2 requires PAP credentials from the dial-in server as part of link negotiation. Therefore, the /etc/ppp/pap-secrets also contains PAP credentials that are expected from myserver on the second line.
Because most ISPs do not supply authentication credentials, the previous scenario might be unrealistic for communications with an ISP.
Task |
Instructions |
Create PAP credentials for additional callers | |
Configure a dial-out machine to support PAP authentication |
The following tasks explain how to update existing PPP configuration files to support PAP authentication on the dial-out machines of trusted callers.
The procedure uses the following parameters to configure PAP authentication on the dial-out machine that belongs to user2, who was introduced in Figure 26–3. user2 requires incoming callers to authenticate, including calls from dial-in myserver.
This procedure uses the PPP configuration files that were introduced in How to Define Communications Over the Serial Line as examples. The procedure configures the dial-out machine that belongs to user2, as shown in Figure 26–3.
Log in to the dial-out machine as superuser.
Modify the /etc/ppp/options file.
The next /etc/ppp/options file contains options for PAP support, which are shown in bold.
#vi /etc/ppp/options lock nodefaultroute name user2 auth require-pap |
Sets user2 as the PAP name of the user on the local machine. If the login option is used, the PAP name must be the same as the user's UNIX user name in the password database.
States that the dial-out machine must authenticate callers before establishing the link.
Requires peers to provide PAP credentials when returning the call from the dial-out machine.
Create an /etc/ppp/peers/peer-name file for the remote machine myserver.
The next sample shows how to add PAP support to the existing /etc/ppp/peers/myserver file that was created in How to Define the Connection With an Individual Peer.
# cd /etc/ppp # mkdir peers # cd peers # vi myserver /dev/cua/a 57600 noipdefault defaultroute idle 120 user user2 remotename myserver connect "chat -U 'mypassword' -f /etc/ppp/mychat" |
The new options in bold add PAP requirements for peer myserver.
Defines user2 as the user name of the local machine
Defines myserver as a peer that requires authentication credentials from the local machine
Task |
For Instructions |
Test the PAP authentication setup by calling the dial-in server |
Procedures for calling the dial-in server, How to Call the Dial-in Server |
Learn more about PAP authentication |
The tasks in this section explain how to implement authentication on a PPP link by using the Challenge-Handshake Authentication Protocol (CHAP). The tasks use the example that is shown in Figure 26–4 to illustrate a working CHAP scenario for dialing up a private network. Use the instructions as the basis for implementing CHAP authentication at your site.
Obtained superuser permission for the local machine, either dial-in server or dial-out machine
Task |
Description |
For Instructions |
1. Assign CHAP secrets to all trusted callers |
Create, or have the callers create, their CHAP secrets | |
2. Create the chap-secrets database |
Add the security credentials for all trusted callers to the /etc/ppp/chap-secrets file | |
Add options specific to CHAP to the /etc/ppp/options and /etc/ppp/peers/peer-name files |
How to Add CHAP Support to the PPP Configuration Files (Dial-in Server) |
Table 29–5 Task Map for CHAP Authentication (Dial-out Machine)
Task |
Description |
For Instructions |
1. Create the CHAP database for the trusted caller's machine |
Create the security credentials for the trusted caller and, if necessary, security credentials for other users who call the dial-out machine, in /etc/ppp/chap-secrets. | |
2. Modify the PPP configuration files |
Add options specific to CHAP to the /etc/ppp/options file. |
How to Add CHAP Support to the PPP Configuration Files (Dial-out Machine) |
The first task in setting up CHAP authentication is modifying the /etc/ppp/chap-secrets file. This file contains the CHAP security credentials, including the CHAP secret, that are used to authenticate callers on the link.
UNIX or PAM authentication mechanisms do not work with CHAP. For example, you cannot use the PPP login option as described in How to Create a PAP Credentials Database (Dial-in Server). If your authentication scenario requires PAM or UNIX-style authentication, choose PAP instead.
The next procedure implements CHAP authentication for a dial-in server in a private network. The PPP link is the only connection to the outside world. The only callers who can access the network have been granted permission by managers of the network, possibly including the system administrator.
Assemble a list that contains the user names of all trusted callers. Trusted callers include all people who have been granted permission to call the private network.
Assign each user a CHAP secret.
Be sure to choose a good CHAP secret that is not easily guessed. No other restrictions are placed on the CHAP secret's contents.
The method for assigning CHAP secrets depends on your site's security policy. Either you have the responsibility for creating the secrets, or the callers must create their own secrets. If you are not responsible for CHAP secret assignment, be sure to get the CHAP secrets that were created by, or for, each trusted caller.
Become superuser on the dial-in server, and modify the /etc/ppp/chap-secrets file.
Solaris PPP 4.0 includes an /etc/ppp/chap-secrets file that contains helpful comments but no options. You can add the following options for the server CallServe at the end of the existing /etc/ppp/chap-secrets file.
account1 CallServe key123 * account2 CallServe key456 * |
key123 is the CHAP secret for trusted caller account1. key456 is the CHAP secret for trusted caller account2.
Task |
For Instructions |
Create CHAP credentials for additional trusted callers | |
Update the PPP configuration files to support CHAP |
Set up CHAP authentication on the dial-out machines of trusted callers |
Configuring CHAP Authentication for Trusted Callers (Dial-out Machines) |
The task in this section explains how to update existing PPP configuration files to support CHAP authentication on the dial-in server.
Add the options that are shown in bold for CHAP support.
# vi /etc/ppp/options lock nodefaultroute name CallServe auth require-chap |
Create the remaining PPP configuration files to support the trusted callers.
See How to Configure Users of the Dial-in Server and How to Define Communications Over the Serial Line (Dial-in Server).
Task |
For Instructions |
Configure CHAP authentication credentials for trusted callers |
This section contains tasks for setting up CHAP authentication on the dial-out machines of trusted callers. Depending on your site's security policy, either you or the trusted callers might be responsible for setting up CHAP authentication.
For remote callers to configure CHAP, ensure that the callers' local CHAP secrets match the callers' equivalent CHAP secrets in the dial-in server's /etc/ppp/chap-secrets file. Then give the callers the tasks in this section for configuring CHAP.
Configuring CHAP for trusted callers involves two tasks:
Creating the callers' CHAP security credentials
Configuring the callers' dial-out machines to support CHAP authentication
This procedure shows how to set up CHAP credentials for two trusted callers. The steps in the procedure assume that you, the system administrator, are creating the CHAP credentials on the trusted callers' dial-out machines.
Using the sample CHAP configuration in Example—Configuration Using CHAP Authentication, assume that the dial-out machine belongs to trusted caller account1.
Modify the chap-secrets database for caller account1.
Solaris PPP 4.0 includes an /etc/ppp/chap-secrets file that has helpful comments but no options. You can add the following options to the existing /etc/ppp/chap-secrets file.
# account1 CallServe key123 * |
CallServe is the name for the peer that account1 is trying to reach. key123 is the CHAP secret to be used for links between account1 and CallServer.
Assume that this machine belongs to caller account2.
Modify the /etc/ppp/chap-secrets database for caller account2.
# account2 CallServe key456 * |
Now, account2 has secret key456 as its CHAP credentials for use over links to peer CallServe.
Task |
For Instructions |
Create CHAP credentials on the dial-out machines of trusted callers | |
Configure a dial-out machine to support CHAP authentication |
How to Configure CHAP Authentication Credentials for the Trusted Callers |
The next task configures the dial-out machine that belongs to caller account1, which is introduced in Example—Configuration Using CHAP Authentication.
Ensure that the /etc/ppp/options file has the following options.
# vi /etc/ppp/options lock nodefaultroute |
Create an /etc/ppp/peers/peer-name file for the remote machine CallServe.
# mkdir /etc/ppp/peers # vi CallServe /dev/cua/a 57600 noipdefault defaultroute idle 120 user account1 connect "chat -U 'mypassword' -f /etc/ppp/mychat" |
The option user account1 sets account1 as the CHAP user name to be given to CallServe. For a description of the other options in the previous file, see the similar /etc/ppp/peers/myserver file in How to Define the Connection With an Individual Peer.
Task |
For Instructions |
Test CHAP authentication by calling the dial-in server | |
Learn more about CHAP authentication |
This chapter contains tasks for setting up the participants on either end of the PPPoE tunnel: the PPPoE client and PPPoE access server. Specific topics include the following:
The tasks use the scenario that was introduced in Planning for DSL Support Over a PPPoE Tunnel as an example. For an overview of PPPoE, refer to Support for DSL Users Through PPPoE.
The following tables list the major tasks for configuring PPPoE clients and the PPPoE access server. To implement PPPoE at your site, you need to set up only your end of the PPPoE tunnel, either the client side or access-server side.
Table 30–1 Task Map for Setting Up a PPPoE Client
Task |
Description |
For Instructions |
1. Configure an interface for PPPoE |
Define the Ethernet interface to be used for the PPPoE tunnel. | |
2. Configure information about the PPPoE access server |
Define parameters for the access server at the service provider end of the PPPoE tunnel. | |
3. Set up the PPP configuration files |
Define the PPP configuration files for the client, if you have not done so already. | |
4. Create the tunnel |
Call the access server. |
Table 30–2 Task Map for Setting Up a PPPoE Access Server
Task |
Description |
For Instructions |
2. Configure the services that the access server offers |
Describe the services that are provided so that these services can be “discovered” by prospective PPPoE clients. | |
4. (Optional) Restrict use of an interface |
Use PPPoE options and PAP authentication to restrict use of a particular Ethernet interface to certain clients. |
How to Restrict the Use of an Interface to Particular Clients |
To provide PPP to client systems over DSL, you must first configure PPPoE on the interface that is connected to the modem or hub. Then you need to change the PPP configuration files to define the access server on the opposite end of the PPPoE.
Before you set up the PPPoE client, you must have done the following:
Installed Solaris 8 Update 6 release or subsequent releases on the client machines to use the PPPoE tunnel
Contacted the service provider for information about its PPPoE access server
Had the telephone company or service provider assemble the devices that are used by the client machines. These devices include, for example, the DSL modem and the splitter, which the telephone company rather than you might assemble.
Become superuser on the PPPoE client.
Add the name of the Ethernet interface with the DSL connection to the /etc/ppp/pppoe.if file.
For example, you add the following entry to /etc/ppp/pppoe.if for a PPPoE client that uses hme0 as the network interface that is connected to the DSL modem.
hme0 |
For more information about /etc/ppp/pppoe.if, go to /etc/ppp/pppoe.if File.
Configure the interface for PPPoE use.
# /etc/init.d/pppd start |
(Optional) Verify that the interface is now plumbed for PPPoE.
# /usr/sbin/sppptun query hme0:pppoe hme0:pppoed |
You can also use the /usr/sbin/sppptun command to manually plumb interfaces for PPPoE. For instructions, refer to /usr/sbin/sppptun Command.
You define the access server in the /etc/ppp/peers/peer-name file. Many of the options that are used for the access server are also used to define the dial-in server in a dial-up scenario. For a detailed explanation of /etc/ppp/peers.peer-name, refer to /etc/ppp/peers/peer-name File.
Define the service provider's PPPoE access server in the /etc/ppp/peers/peer-name file.
For example, the following file, /etc/ppp/peers/dslserve, defines the access server dslserve at FarISP that is introduced in Example—Configuration for a PPPoE Tunnel.
# cat /etc/ppp/peers/dslserve sppptun plugin pppoe.so connect "/usr/lib/inet/pppoec hme0" noccp noauth user Red password redsecret noipdefault defaultroute |
For a definition of the options in this file, go to /etc/ppp/peers/peer-name File for Defining an Access Server Peer.
Modify the other PPP configuration files on the PPPoE client.
Configure /etc/ppp/options as described in the instructions for configuring a dial-out machine in Configuring the Dial-out Machine.
Create an /etc/ppp/options.sppptun file. /etc/ppp/options.sppptun defines PPP options for the serial port to which the interface that is plumbed for PPPoE is attached.
You can use any options that are available for the /etc/ppp/options.ttyname file that is described in /etc/ppp/options.ttyname Configuration File. You must name the file /etc/ppp/options.sppptun because sppptun is the specified device name in the pppd configuration.
Ensure that all users can start PPP on the client.
# touch /etc/ppp/options |
Test if PPP can run over the DSL line.
# pppd debug updetach call dslserve |
dslserve is the name that is given to the access server at the ISP that is shown in Example—Configuration for a PPPoE Tunnel. The debug updetach option causes debugging information to display in a terminal window.
If PPP is running correctly, the terminal output shows the link becoming active. If PPP still does not run, try the following command to see if the servers are running correctly:
# /usr/lib/inet/pppoec -i hme0 |
Task |
For Instructions |
Configure another PPPoE client | |
Learn more about PPPoE | |
Have users of configured PPPoE clients begin running PPP over the DSL line |
Instruct the users to type pppd call ISP-server-name and then run an application or service. |
Troubleshoot PPPoE and PPP problems | |
Configure a PPPoE access server |
If your company is a service provider, you can offer Internet and other services to clients that reach your site through DSL connections. First, you must determine which interfaces on the server to involve in the PPPoE tunnel. Then, you define which services are made available to the users.
Become superuser on the access server.
Add the name of the Ethernet interfaces that are dedicated to the PPPoE tunnels to the /etc/ppp/pppoe.if file.
For example, you would use the following /etc/ppp/pppoe.if file for the access server dslserve that is shown in Example—Configuration for a PPPoE Tunnel.
# cat /etc/ppp/pppoe.if hme1 hme2 |
Configure the interfaces for PPPoE use.
(Optional) Verify that interfaces on the server are now plumbed for PPPoE.
# /usr/sbin/sppptun query hme1:pppoe hme1:pppoed hme2:pppoe hme2:pppoed |
The previous sample shows that interfaces hme1 and hme2 are currently plumbed for PPPoE. You can also use the /usr/sbin/sppptun command to manually plumb interfaces for PPPoE. For instructions, refer to /usr/sbin/sppptun Command.
Define global services that are provided by the access server in the /etc/ppp/pppoe file.
The following /etc/ppp/pppoe file lists the services that are provided by access server dslserve, which was shown in Figure 26–5.
device hme1,hme2 service internet pppd "proxyarp 192.168.1.1:" service debugging pppd "debug proxyarp 192.168.1.1:" |
In the file example, Internet service is announced for dslserve's Ethernet interfaces hme1 and hme2. Debugging is turned on for PPP links on the Ethernet interfaces.
Set up the PPP configuration files in the same way that you would for a dial-in server.
For steps to use, see Configuring Communications Over the Dial-in Server.
pppd also plumbs the interfaces that are listed in /etc/ppp/pppoe.if.
Modify /etc/ppp/pppoe, as needed.
Cause the pppoed daemon to recognize the new services.
# pkill -HUP pppoed |
The next procedure shows how to restrict an interface to a group of PPPoE clients. Before performing this task, you need to obtain the real Ethernet MAC addresses of the clients you are assigning to the interface.
Some systems allow you to change the MAC address on the Ethernet interface. You should view this ability as a convenience factor, not a security measure.
Using the example that is shown in Example—Configuration for a PPPoE Tunnel, these steps show how to reserve one of dslserve's interfaces, hme1, to clients at MiddleCo.
Configure the access server's interfaces, as shown in How to Configure the Access Server's Interfaces for PPPoE.
Define services, as shown in How to Provide Services to Clients of the Access Server.
Create entries for clients in the server's /etc/ethers database.
Here is a sample entry for clients Red, Blue, and Yellow.
8:0:20:1:40:30 redether 8:0:20:1:40:10 yellowether 8:0:20:1:40:25 blueether |
The sample assigns the symbolic names redether, yellowether, and blueether to the Ethernet addresses of clients Red, Yellow, and Blue. The assignment of symbolic names to the MAC addresses is optional.
Restrict services that are provided on a specific interface by defining the following information in the /etc/ppp/pppoe.device file.
In this file, device is the name of the device to be defined.
# vi /etc/ppp/pppoe.hme1 service internet pppd "name dslserve-hme1" clients redether,yellowether,blueether |
dslserve-hme1 is the access server's name, which is used in matching entries in the pap-secrets file. The clients option restricts the use of interface hme1 to clients with the symbolic Ethernet names redether, yellowether, and blueether.
If you did not define symbolic names for client's MAC addresses in /etc/ethers, you can use the numeric addresses as arguments to the clients option. Wildcards are allowed.
For example, you can specify the numeric address clients 8:0:20:*:*:*. This address allows access only to clients that are listed in /etc/ethers with MAC addresses that begin with the number 8:0:20.
Create the /etc/ppp/pap-secrets file for the access server:
# Red dslserve-hme1 redpasswd * Blue dslserve-hme1 bluepasswd * Yellow dslserve-hme1 yellowpassd * |
The entries are the PAP names and passwords of clients that are allowed to run PPP over dslserve's hme1 interface.
For more information on PAP authentication, see Configuring PAP Authentication.
Task |
For Instructions |
Configure a PPPoE client | |
Configure PAP authentication for a client |
Configure PAP authentication on a server |
This chapter contains information for troubleshooting common problems that occur with Solaris PPP 4.0. The following topics are covered:
The sources PPP Design, Implementation, and Debugging by James Carlson and the Australian National University's web site also have detailed advice for PPP troubleshooting. For more information, see Professional Reference Books About PPP and Web Sites About PPP.
Use the following task map to quickly access advice and solutions for common PPP problems.
Table 31–1 Task Map for Troubleshooting PPP
Task |
Definition |
For Instructions |
Obtain diagnostic information about the PPP link |
Use PPP diagnostic tools to get output for troubleshooting | |
Obtain debugging information for the PPP link |
Use the pppd debug command to generate output for troubleshooting | |
Troubleshoot general problems with the network layer |
Identify and fix PPP problems that are network-related by using a series of checks | |
Troubleshoot general communications problems |
Identify and fix communications problems that affect the PPP link | |
Troubleshoot configuration problems |
Identify and fix problems in the PPP configuration files | |
Troubleshoot modem-related problems |
Identify and fix modem problems | |
Troubleshoot chat script-related problems |
Identify and fix chat script problems on a dial-out machine | |
Troubleshoot serial-line speed problems |
Identify and fix line speed problems on a dial-in server | |
Troubleshoot common problems for leased lines |
Identify and fix performance problems on a leased line | |
Troubleshoot problems related to authentication |
Identify and fix problems related to the authentication databases | |
Troubleshoot problem areas for PPPoE |
Use PPP diagnostic tools to obtain output for identifying and fixing PPPoE problems |
PPP links generally have three major areas of failure:
Failure of the link to be established
Poor performance of the link during regular usage
Problems that can be traced to the networks on either side of the link
This section explains how to obtain diagnostic information from pppd and its associated log files. The remaining sections in this chapter describe common problems with PPP that you can discover and fix with the aid of the PPP troubleshooting tools.
The next procedure shows how to view the current operation of a link on the local machine.
Become superuser on the local machine.
Run pppd with the serial device configured for PPP as the argument:
# pppd /dev/ttyname debug updetach |
# pppd /dev/cua/b debug updetach have route to 0.0.0.0/0.0.0.0 via 172.21.0.4 serial speed set to 230400 bps Using interface sppp0 Connect: sppp0 <--> /dev/cua/b sent [LCP ConfReq id=0x7b <asyncmap 0x0> <magic 0x73e981c8> <pcomp> <accomp>] rcvd [LCP Ident id=0x79 magic=0x0 "ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22)"] Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22) rcvd [LCP ConfRej id=0x7b <asyncmap 0x0>] sent [LCP Ident id=0x7c magic=0x0 "ppp-2.4.0b1 (Sun Microsystems, Inc., Nov 15 2000 09:38:33)" sent [LCP ConfReq id=0x7d <magic 0x73e981c8> <pcomp> <accomp>] rcvd [LCP ConfAck id=0x7d <magic 0x73e981c8> <pcomp> <accomp>] rcvd [LCP ConfAck id=0x78 <magic 0xdd4ad820> <pcomp> <accomp>] sent [LCP ConfAck id=0x78 <magic 0xdd4ad820> <pcomp> <accomp>] sent [LCP Ident id=0x7e magic=0x73e981c8 "ppp-2.4.0b1 (Sun Microsystems, Inc., Nov 15 2000 09:38:33)"] sent [IPCP ConfReq id=0x3d <addr 0.0.0.0> <compress VJ 0f 01>] rcvd [LCP Ident id=0x7a magic=0xdd4ad820 "ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22)"] Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Dec 6 2000 09:36:22) rcvd [IPCP ConfReq id=0x92 <addr 10.0.0.1> <compress VJ 0f 01> sent [IPCP ConfAck id=0x92 <addr 10.0.0.1> <compress VJ 0f 01> rcvd [IPCP ConfNak id=0x3d <addr 10.0.0.2>]] sent [IPCP ConfReq id=0x3e <addr 10.0.0.2> <compress VJ 0f 01>] rcvd [IPCP ConfAck id=0x3e <addr 10.0.0.2> <compress VJ 0f 01>] local IP address 10.0.0.2 remote IP address 10.0.0.1 |
# pppd /dev/se_hdlc1 default-asyncmap debug updetach pppd 2.4.0b1 (Sun Microsystems, Inc., Oct 24 2001 07:13:18) started by root, uid 0 synchronous speed appears to be 0 bps init option: '/etc/ppp/peers/syncinit.sh' started (pid 105122) Serial port initialized. synchronous speed appears to be 64000 bps Using interface sppp0 Connect: sppp0 <--> /dev/se_hdlc1 sent [LCP ConfReq id=0xe9 <magic 0x474283c6><pcomp> <accomp>] rcvd [LCP ConfAck id=0xe9 <magic 0x474283c6><pcomp> <accomp>] rcvd [LCP ConfReq id=0x22 <magic 0x8e3a53ff><pcomp> <accomp>] sent [LCP ConfReq id=0x22 <magic 0x8e3a53ff><pcomp> <accomp>] sent [LCP Ident id=0xea magic=0x474283c6 "ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44)"] sent [IPCP ConfReq id=0xf7 <addr 0.0.0.0> <compress VJ Of o1>]] sent [CCP ConfReq id=0x3f <deflate 15> <deflate(old#) 15> <bsd v1 15>] rcvd [LCP Ident id=0x23 magic=0x8e3a53ff "ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44)"] Peer Identification: ppp-2.4.0b1 (Sun Microsystems, Inc., Oct 22 2001 14:31:44) rcvd [IPCP ConfReq id=0x25 <addr 10.0.0.1> <compress VJ Of 01>] sent [IPCP ConfAck id=0x25 <addr 10.0.0.1> <compress VJ Of 01>] rcvd [CCP ConfReq id=0x3 <deflate 15> <deflate(old#) 15 <bsd v1 15>] sent [CCP ConfAck id=0x3 <deflate 15> <deflate(old#) 15 <bsd v1 15>] rcvd [IPCP ConfNak id=0xf8 <addr 10.0.0.2>] rcvd [IPCP ConfReq id=0xf7 <addr 10.0.0.2> <compress VJ Of 01>] rcvd [CCP ConfAck id=0x3f <deflate 15> <deflate(old#) 15 <bsd v1 15>] Deflate (15) compression enabled rcvd [IPCP ConfAck id=0xf8 <addr 10.0.0.2> <compress VJ Of 01>] local IP address 10.0.0.2 remote IP address 10.0.0.1 |
The next task shows how to use the pppd command to obtain debugging information.
You only need to perform step 1 through step 3 once for each host. Thereafter, you can proceed to step 4 to turn on debugging for the host.
Create a log file to hold output from pppd.
% touch /var/log/pppdebug |
Add the following syslog facilities for pppd in /etc/syslog.conf.
daemon.debug;local2.debug /var/log/pppdebug |
Restart syslogd.
% pkill -HUP -x syslogd |
Turn on debugging for calls to a particular peer by using the following syntax of pppd.
% pppd debug call peer-name |
peer-name must be the name of a file in the /etc/ppp/peers directory.
View the contents of the log file.
% tail -f /var/log/pppdebug |
For an example of a log file, see Example 31–3.
If the PPP link becomes active but few hosts on the remote network are reachable, a network problem could be indicated. This section explains how to isolate and fix network problems that affect a PPP link.
Become superuser on the local machine. Then shut down the problematic link.
Disable any optional protocols in the configuration files by adding the following options to your PPP configuration:
noccp novj nopcomp noaccomp default-asyncmap |
These options provide the simplest uncompressed PPP that is available. Try to invoke these options as arguments to pppd on the command line. If you can reach the previously unreachable hosts, add the options in either of the following places.
/etc/ppp/peers/peer-name, after the call option
/etc/ppp/options, ensuring that the options apply globally
Call the remote peer. Then enable debugging features.
Obtain verbose logs from the chat program by using the -v option of chat.
For example, use the following format in any PPP configuration file:
connect 'chat -v -f /etc/ppp/chatfile' |
Try to re-create the problem by using Telnet or other applications to reach the remote hosts.
Observe the debugging logs. If you still cannot reach remote hosts, the PPP problem might be network-related.
Verify that the IP addresses of the remote hosts are registered Internet addresses.
Some organizations assign internal IP addresses that are known within the local network but cannot be routed to the Internet. If the remote hosts are within your company, you must set up a name-to-address translation (NAT) server or proxy server to reach the Internet. If the remote hosts are not within your company, you should report the problem to the remote organization.
Examine the routing tables.
Check the routing tables on both the local machine and the peer.
Check the routing tables for any routers that are in the path from the peer to the remote system. Also check the routing tables for any routers on the path back to the peer.
Ensure that the intermediate routers have not been misconfigured. Often the problem can be found in the path back to the peer.
(Optional) If the machine is a router, check the optional features.
# ndd -set /dev/ip ip_forwarding 1 |
For more information about ndd, refer to the ndd(1M) man page.
Check the statistics that are obtained from netstat -s and similar tools.
For complete details on netstat, refer to the netstat(1M) man page.
Run statistics on the local machine.
Call the peer.
Observe the new statistics that are generated by netstat -s.
You can use the messages that are generated by netstat -s to fix the network problems that are shown in the next table.
Table 31–2 Common Network Problems That Affect PPP
Message |
Problem |
Solution |
IP packets not forwardable |
The local host is missing a route. |
Add the missing route to the local host's routing tables. |
ICMP input destination unreachable |
ICMP time exceeded |
Two routers are forwarding the same destination address to each other, causing the packet to bounce back and forth until the time-to-live (TTL) value is exceeded. |
Use traceroute to find the source of the routing loop, and then contact the administrator of the router in error. For information about traceroute, refer to the traceroute(1M) man page. |
Add the missing route to the local host's routing table. |
Check the DNS configuration.
A faulty name service configuration causes applications to fail because IP addresses cannot be resolved.
You can find information for fixing name service problems in “DNS Troubleshooting (Reference)” in System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Communications problems occur when the two peers cannot successfully establish a link. Sometimes these problems are actually negotiation problems that are caused by incorrectly configured chat scripts. This section contains information for clearing communications problems. For clearing negotiation problems that are caused by a faulty chat script, see Table 31–5.
Become superuser on the local machine. Then call the peer.
You might need to obtain debugging information from the peer in order to fix certain communications problems.
Check the resulting logs for the communications problems in the next table.
Table 31–3 General Communications Problems That Affect PPP
Symptom |
Problem |
Solution |
too many Configure-Requests |
One peer cannot hear the other peer. |
Check for the following problems:
The pppd debug output shows that LCP starts, but higher-level protocols fail or show CRC errors. |
The asynchronous control character map (ACCM) is incorrectly set. |
Use the default-async option to set the ACCM to the standard default of FFFFFFFF. First try to use default-async as an option to pppd on the command line. If the problem clears, then add default-async to /etc/ppp/options or to /etc/ppp/peers/peer-name after the call option. |
The pppd debug output shows that IPCP comes up but terminates immediately. |
IP addresses might be incorrectly configured. |
The link exhibits very poor performance. |
The modem might be incorrectly configured, with flow-control configuration errors, modem setup errors, and incorrectly configured DTE rates. |
Check the modem configuration. Adjust the configuration, if necessary. |
Some PPP problems can be traced to problems in the PPP configuration files. This section contains information for isolating and fixing general configuration problems.
Check the resulting log for the configuration problems that are listed in the next table.
Table 31–4 Common PPP Configuration Problems
Symptom |
Problem |
Solution |
pppd debug output contains the error message “Could not determine remote IP address.” |
The /etc/ppp/peers/peer-name file does not have an IP address for the peer. The peer does not provide an IP address during link negotiation. |
Supply an IP address for the peer on the pppd command line or in /etc/ppp/peers/peer-name by using the following format: :10.0.0.10 |
pppd debug output shows that CCP data compression has failed. The output also indictes that the link is dropped. |
The peers' PPP compression configurations might be in conflict. |
Disable CCP compression by adding the noccp option to /etc/ppp/options on one of the peers. |
Modems can be major problem areas for a dial-up link. The most common indicator of problems with the modem configuration is no response from the peer. However, you might have difficulties when determining if a link problem is indeed the result of modem configuration problems.
For basic modem troubleshooting suggestions, refer to “Troubleshooting Terminal and Modem Problems” in System Administration Guide: Advanced Administration. Modem manufacturers' documentation and web sites also contain solutions for problems with their particular equipment. This section contains more suggestions for isolating and fixing modem problems.
The following steps help determine whether a faulty modem configuration causes link problems.
Call the peer with debugging turned on, as explained in How to Turn on PPP Debugging.
Display the resulting /var/log/pppdebug log.
Either of the following symptoms in the output can indicate a faulty modem configuration:
No “recvd” messages have come from the peer.
The output contains LCP messages from the peer, but the link fails with too many LCP Configure Requests messages that are sent by the local machine.
These messages indicate that the local machine can hear the peer, but the peer cannot hear the local machine.
The link terminates with a SIGHUP signal.
Use ping to send packets of various sizes over the link.
For complete details about ping, refer to the ping(1M) man page.
If small packets are received but larger packets are dropped, modem problems are indicated.
Check for errors on interface sppp0:
% netstat -ni Name Mtu Net/Dest Address Ipkts Ierrs Opkts Oerrs Collis Queue lo0 8232 127.0.0.0 127.0.0.1 826808 0 826808 0 0 0 hme0 1500 172.21.0.0 172.21.3.228 13800032 0 1648464 0 0 0 sppp0 1500 10.0.0.2 10.0.0.1 210 0 128 0 0 0 |
If interface errors increase over time, the modem configuration might have problems.
Chat scripts are trouble-prone areas for dial-up links. This section contains a procedure for obtaining debugging information from chat and suggestions for clearing common problems.
Become superuser on the dial-out machine.
Edit the /etc/ppp/peers/peer-name file for the peer to be called.
Add -v as an argument to the chat command that is specified in connect option.
connect "/usr/bin/chat -v -f /etc/ppp/chat-script-name" |
View chat script errors in the file /etc/ppp/connect-errors.
The following is the main error that is seen with chat.
Oct 31 08:57:13 deino chat[107294]: [ID 702911 local2.info] expect (CONNECT) Oct 31 08:57:58 deino chat[107294]: [ID 702911 local2.info] alarm Oct 31 08:57:58 deino chat[107294]: [ID 702911 local2.info] Failed |
The example shows timeout while waiting for a (CONNECT)string. When chat fails, you get the following message from pppd:
Connect script failed |
The next table lists common chat script errors and suggestions for fixing the errors.
Table 31–5 Common Chat Script Problems
Dial-in servers can experience problems because of to conflicting speed settings. The next procedure helps you to isolate the cause of the link problem to conflicting serial-line speeds.
The following behaviors cause speed problems:
You invoked PPP through a program such as /bin/login and specified the speed of the line.
You started PPP from mgetty and accidentally supplied the bit rate.
Log in to the dial-in server. Call the peer with debugging enabled.
If you need instructions, see How to Turn on PPP Debugging.
Check the output for the following message:
LCP too many configure requests |
Check if PPP is invoked through a program such as /bin/login and the line speed that was set.
In such a situation, pppd changes the originally configured line speed to the speed that is specified in /bin/login.
Check if a user started PPP from the mgetty command and accidentally specified a bit rate.
This action also causes serial-line speeds to conflict.
Fix the conflicting serial-line speed problem as follows:
The most common problem with leased lines is poor performance. In most situations, you need to work with the telephone company to fix the problem.
Table 31–6 Common Leased-Line Problems
Symptom |
Problem |
Solution |
The link does not start. |
CSU biopolar violations (CSU BPVs) can be the cause. One end of the link is set up for AMI lines. The other end is set up for ESF bit 8 zero substitute (B8Zs). |
If you are in the United States or Canada, you can directly fix this problem from the menu of the CSU/DSU. Check the CSU/DSU manufacturer's documentation for details. In other locales, the provider might be responsible for fixing CSU BPVs. |
The link has poor performance. |
The pppd debug output shows CRC errors when sustained traffic is on the link. Your line might have a clocking problem, caused by misconfigurations between the telephone company and your network. |
Contact the telephone company to ensure that “loop clocking” is in use. On some unstructured leased lines, you might have to supply clocking. North American users should use loop clocking.
Symptom |
Problem |
Solution |
pppd debug output shows the message Peer is not authorized to use remote address address. |
You are using PAP authentication, and the IP address for the remote peer is not in the /etc/ppp/pap-secrets file. |
Add an asterisk (*) after the entry for the peer in the /etc/ppp/pap-secrets file. |
pppd debug output shows that LCP starts but terminates shortly afterward. |
The password might be incorrect in the database for the particular security protocol. |
Check the password for the peer in the /etc/ppp/pap-secrets or /etc/ppp/chap-secrets file. |
You can use PPP and standard UNIX utilities to identify problems with PPPoE. This section explains how to obtain debugging information for PPPoE. The section also contains suggestions for fixing PPPoE-related problems.
When you suspect that PPPoE is the cause of problems on a link, use the following diagnostic tools to obtain troubleshooting information.
Become superuser on the machine that runs the PPPoE tunnel, either PPPoE client or PPPoE access server.
Turn on debugging, as explained in the procedure How to Turn on PPP Debugging.
View the contents of the log file /var/log/pppdebug.
The following example shows part of a log file that was generated for a link with a PPPoE tunnel.
Sep 6 16:28:45 enyo pppd[100563]: [ID 702911 daemon.info] Plugin pppoe.so loaded. Sep 6 16:28:45 enyo pppd[100563]: [ID 860527 daemon.notice] pppd 2.4.0b1 (Sun Microsystems, Inc., Sep 5 2001 10:42:05) started by troot, uid 0 Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.debug] connect option: '/usr/lib/inet/pppoec -v hme0' started (pid 100564) Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.info] Serial connection established. Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.info] Using interface sppp0 Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.notice] Connect: sppp0 <--> /dev/sppptun Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.debug] /etc/ppp/pap-secrets is apparently empty Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.debug] /etc/ppp/chap-secrets is apparently empty Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.debug] sent [LCP ConfReq id=0xef <mru 1492> asyncmap 0x0 <magic 0x77d3e953><pcomp><acomp> Sep 6 16:28:46 enyo pppd[100563]: [ID 702911 daemon.debug] rcvd [LCP ConfReq id=0x2a <mru 1402> asyncmap 0x0 <magic 0x9985f048><pcomp><acomp |
If the debugging output does not help you isolate the problem, continue with this procedure.
Get diagnostic messages from PPPoE.
# pppd connect "/usr/lib/inet/pppoec -v interface-name" |
pppoec sends diagnostic information to the stderr. If you run pppd in the foreground, the output appears on the screen. If pppd runs in the background, the output is sent to /etc/ppp/connect-errors.
The next example shows the messages that are generated as the PPPoE tunnel is negotiated.
Connect option: '/usr/lib/inet/pppoec -v hme0' started (pid 100564) /usr/lib/inet/pppoec: PPPoE Event Open (1) in state Dead (0): action SendPADI (2) /usr/lib/inet/pppoec: Sending PADI to ff:ff:ff:ff:ff:ff: 18 bytes /usr/lib/inet/pppoec: PPPoE State change Dead (0) -> InitSent (1) /usr/lib/inet/pppoec: Received Active Discovery Offer from 8:0:20:cd:c1:2/hme0:pppoed /usr/lib/inet/pppoec: PPPoE Event rPADO+ (5) in state InitSent (1): action SendPADR+ (5) /usr/lib/inet/pppoec: Sending PADR to 8:0:20:cd:c1:2: 22 bytes /usr/lib/inet/pppoec: PPPoE State change InitSent (1) -> ReqSent (3) /usr/lib/inet/pppoec: Received Active Discovery Session-confirmation from 8:0:20:cd:c1:2/hme0:pppoed /usr/lib/inet/pppoec: PPPoE Event rPADS (7) in state ReqSent (3): action Open (7) /usr/lib/inet/pppoec: Connection open; session 0002 on hme0:pppoe /usr/lib/inet/pppoec: PPPoE State change ReqSent (3) -> Convers (4) /usr/lib/inet/pppoec: connected |
If the diagnostic messages do not help you isolate the problem, continue with this procedure.
Run snoop. Then save the trace to a file.
For information about snoop, refer to the snoop(1M) man page.
# snoop -o pppoe-trace-file |
View the snoop trace file.
# snoop -i pppoe-trace-file -v pppoe |
ETHER: ----- Ether Header ----- ETHER: ETHER: Packet 1 arrived at 6:35:2.77 ETHER: Packet size = 32 bytes ETHER: Destination = ff:ff:ff:ff:ff:ff, (broadcast) ETHER: Source = 8:0:20:78:f3:7c, Sun ETHER: Ethertype = 8863 (PPPoE Discovery) ETHER: PPPoE: ----- PPP Over Ethernet ----- PPPoE: PPPoE: Version = 1 PPPoE: Type = 1 PPPoE: Code = 9 (Active Discovery Initiation) PPPoE: Session Id = 0 PPPoE: Length = 12 bytes PPPoE: PPPoE: ----- Service-Name ----- PPPoE: Tag Type = 257 PPPoE: Tag Length = 0 bytes PPPoE: PPPoE: ----- Host-Uniq ----- PPPoE: Tag Type = 259 PPPoE: Tag Length = 4 bytes PPPoE: Data = Ox00000002 PPPoE: . . . ETHER: ----- Ether Header ----- ETHER: ETHER: Packet 5 arrived at 6:35:2.87 ETHER: Packet size = 60 bytes ETHER: Destination = 8:0:20:78:f3:7c, Sun) ETHER: Source = 0:2:fd:39:7f:7, ETHER: Ethertype = 8864 (PPPoE Session) ETHER: PPPoE: ----- PPP Over Ethernet ----- PPPoE: PPPoE: Version = 1 PPPoE: Type = 1 PPPoE: Code = 0 (PPPoE Session) PPPoE: Session Id = 24383 PPPoE: Length = 20 bytes PPPoE: PPP: ----- Point-to-Point Protocol ----- PPP: PPP-LCP: ----- Link Control Protocol ----- PPP-LCP: PPP-LCP: Code = 1 (Configure Request) PPP-LCP: Identifier = 80 PPP-LCP: Length = 18 |
This chapter provides detailed conceptual information about Solaris PPP 4.0. Topics include the following:
Solaris PPP 4.0 contains a large set of options, which you use to define your PPP configuration. You use these options in the PPP configuration files, or on the command line, or by using a combination of files and command-line options. This section contains detailed information about the use of PPP options in configuration files and as arguments to PPP commands.
Solaris PPP 4.0 configuration is very flexible.You can define PPP options in the following places:
PPP commands that are issued on the command line
A combination of both places
The next table lists the PPP configuration files and commands.
Table 32–1 Summary of PPP Configuration Files and Commands
File or Command |
Definition |
For Information |
/etc/ppp/options |
A file that contains characteristics that apply by default to all PPP links on the system, for example, whether the machine requires peers to authenticate themselves. If this file is absent, non-root users are prohibited from using PPP. | |
/etc/ppp/options.ttyname |
A file that describes the characteristics of all communications over the serial port ttyname. | |
Directory that usually contains information about peers with which a dial-out machine connects. Files in this directory are used with the call option of the pppd command. |
Specifying Information for Communicating With the Dial-in Server |
A file that contains characteristics of the remote peer peer-name. Typical characteristics include the remote peer's phone number and chat script for negotiating the link with the peer. | ||
A file that contains the necessary security credentials for Password Authentication Protocol (PAP) authentication. | ||
A file that contains the necessary security credentials for Challenge-Handshake Authentication Protocol (CHAP) authentication. | ||
File in the home directory of a PPP user, most often used with dial-in servers. This file contains specific information about each user's configuration. | ||
Command and options for initiating a PPP link and describing its characteristics. |
Refer to the pppd(1M) man page for details on the PPP files. pppd (1M) also includes comprehensive descriptions of all options that are available to the pppd command. Sample templates for all the PPP configuration files are available in /etc/ppp.
All Solaris PPP 4.0 operations are handled by the pppd daemon, which starts when a user runs the pppd command. When a user calls a remote peer, the following occurs:
The pppd daemon parses the following:
/etc/ppp/options
$HOME/.ppprc
Any files that are opened by the file or call option in /etc/ppp/options and $HOME/.ppprc
pppd scans the command line to determine the device in use. The daemon does not yet interpret any options that are encountered.
pppd tries to discover the serial device to use by using the following criteria:
If a serial device is specified on the command line, or a previously processed configuration file, pppd uses the name of that device.
If no serial device is named, then pppd searches for the notty, pty, or socket option on the command line. If one of these options is specified, pppd assumes that no device name exists.
Otherwise, if pppd discovers that standard input is attached to a tty, then the name of the tty is used.
If pppd still cannot find a serial device, pppd terminates the connection and issues an error.
pppd then checks for the existence of the /etc/ppp/options.ttyname file. If the file is found, pppd parses the file.
pppd processes any options on the command line.
pppd negotiates the Link Control Protocol (LCP) to set up the link.
(Optional) If authentication is required, pppd reads /etc/ppp/pap-secrets or /etc/ppp/chap-secrets to authenticate the opposite peer.
The file /etc/ppp/peers/peer-name is read when the pppd daemon encounters the option call peer-name on the command line or in the other configuration files.
Solaris PPP 4.0 configuration includes the concept of privileges. Privileges determine the precedence of configuration options, particularly when the same option is invoked in more than one place. An option that is invoked from a privileged source takes precedence over the same option that is invoked from a non-privileged source.
The only privileged user is superuser (root), with the UID of zero. All other users are not privileged.
The following configuration files are privileged regardless of their ownership:
/etc/ppp/options
The file $HOME/.ppprc is owned by the user. Options that are read from $HOME/.ppprc and from the command line are privileged only if the user who is invoking pppd is root.
Arguments that follow the file option are privileged.
Some options require the invoking user or source to be privileged in order to work. Options that are invoked on the command line are assigned the privileges of the user who is running the pppd command. These options are not privileged unless the user who is invoking pppd is root.
Option |
Status |
Explanation |
domain |
Privileged |
Requires privileges for use. |
linkname |
Privileged |
noauth |
Privileged |
nopam |
Privileged |
pam |
Privileged |
plugin |
Privileged |
privgroup |
Privileged |
allow-ip addresses |
Privileged |
name hostname |
Privileged |
plink |
Privileged |
noplink |
Privileged |
plumbed |
Privileged |
proxyarp |
Becomes privileged if noproxyarp has been specified |
Cannot be overridden by an unprivileged use. |
Privileged if nodefaultroute is set in a privileged file or by a privileged user |
Cannot be overridden by an unprivileged user. |
disconnect |
Privileged if set in a privileged file or by a privileged user |
bsdcomp |
The non-privileged user cannot specify a code size that is larger than the privileged user has specified. |
deflate |
connect |
init |
pty |
welcome |
ttyname |
Not privileged if set in a non-privileged file |
Opened with root permissions regardless of who invokes pppd.
Opened with the privileges of the user who invokes pppd. |
You use the /etc/ppp/options file to define global options for all PPP communications on the local machine. /etc/ppp/options is a privileged file. /etc/ppp/options should be owned by root, although pppd does not enforce this rule. Options that you define in /etc/ppp/options have precedence over definitions of the same options in all other files and the command line.
Typical options that you might use in /etc/ppp/options include the following:
lock– Enables UUCP-style file locking
noauth – Indicates that the machine does not authenticate callers
The Solaris PPP 4.0 software does not include a default /etc/ppp/options file. pppd does not require the /etc/ppp/options file to work. If a machine does not have an /etc/ppp/options file, only root can run pppd on that machine.
You must create /etc/ppp/options by using a text editor, as shown in How to Define Communications Over the Serial Line. If a machine does not require global options, you can create an empty /etc/ppp/options file. Then, both root and regular users can run pppd on the local machine.
The /etc/ppp/options.tmpl contains helpful comments about the /etc/ppp/options file plus three common options for the global /etc/ppp/options file.
lock nodefaultroute noproxyarp |
Option |
Definition |
lock |
Enables UUCP-style file locking |
nodefaultroute |
Specifies that no default route is defined |
noproxyarp |
Disallows proxyarp |
To use /etc/ppp/options.tmpl as the global options file, rename /etc/ppp/options.tmpl to /etc/ppp/options. Then, modify the file contents as needed by your site.
Example /etc/ppp/options |
For Instructions |
For a dial-out machine | |
For a dial-in server |
How to Define Communications Over the Serial Line (Dial-in Server) |
For PAP support on a dial-in server |
For PAP support on a dial-out machine |
For CHAP support on a dial-in server |
You can configure the characteristics of communications on the serial line in the /etc/ppp/options.ttyname file. /etc/ppp/options.ttyname is a privileged file that is read by pppd after parsing any existing /etc/ppp/options and existing $HOME/.ppprc files. Otherwise, pppd reads /etc/ppp/options.ttyname after parsing /etc/ppp/options.
ttyname is used for both dial-up and leased-line links. ttyname represents a particular serial port on a machine, such as cua/a or cua/b, where a modem or ISDN TA might be attached.
When naming the /etc/ppp/options.ttyname file, replace the slash (/) in the device name with a dot (.) . For example, the options file for device cua/b should be named /etc/ppp/options.cua.b.
Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. Your server might have only one serial line for PPP. Furthermore, the server requires few options. In this instance, you can specify any required options in another configuration file or on the command line.
For a dial-up link, you might choose to create individual /etc/ppp/options.ttyname files for every serial port on a dial-in server with a modem attached. Typical options include the following:
IP address required by the dial-in server
Set this option if you require incoming callers on serial port ttyname to use a particular IP address. Your address space might have a limited number of IP addresses that are available for PPP in comparison to the number of potential callers. In this situation, consider assigning an IP address to each serial interface that is used for PPP on the dial-in server. This assignment implements dynamic addressing for PPP.
asyncmap map_value
The asyncmap option maps control characters that cannot be received over the serial line by the particular modem or ISDN TA. When the xonxoff option is used, pppd automatically sets an asyncmap of 0xa0000.
map_value states, in hexadecimal format, the control characters that are problematic.
init "chat -U -f /etc/ppp/mychat"
The init option tells the modem to initialize communications over the serial line by using the information in the chat —U command. The modem uses the chat string in the file /etc/ppp/mychat.
Security parameters that are listed in the pppd(1m) man page
For a dial-out system, you can create an /etc/ppp/options.ttyname file for the serial port with the modem, or choose not to use /etc/ppp/options.ttyname.
Solaris PPP 4.0 does not require an /etc/ppp/options.ttyname file to work correctly. A dial-out machine might have only one serial line for PPP. Furthermore, the dial-out machine might require few options. You can specify any required options in another configuration file or on the command line.
The /etc/ppp/options.ttya.tmpl file contains helpful comments about the /etc/ppp/options.tty-name file. The template contains three common options for the /etc/ppp/options.tty-name file.
38400 asyncmap 0xa0000 :192.168.1.1 |
Option |
Definition |
38400 |
Use this baud rate for port ttya. |
asyncmap 0xa0000 |
Assign the asyncmap value of 0xa0000 so that the local machine can communicate with broken peers. |
:192.168.1.1 |
Assign the IP address 192.168.1.1 to all peers that are calling in over the link. |
To use /etc/ppp/options.ttya.tmpl at your site, rename /etc/ppp/options.tmpl to /etc/ppp/options.ttya-name. Replace ttya-name with the name of the serial port with the modem. Then modify the file contents as needed by your site.
Example /etc/ppp/options.ttyname |
For Instructions |
This section contains detailed information on setting up users on the dial-in server.
The $HOME/.ppprc file is intended for users who are configuring preferred PPP options. As administrator, you can also configure $HOME/.ppprc for users.
The options in $HOME/.ppprc are privileged only when the user who is invoking the file is privileged.
When a caller uses the pppd command to initiate a call, the .ppprc file is the second file that is checked by the pppd daemon.
See Setting Up Users of the Dial-in Server for instructions on setting up $HOME/.ppprc on the dial-in server.
The $HOME/.ppprc is not needed on the dial-out machine for Solaris PPP 4.0 to work correctly.
You do not need to have a $HOME/.ppprc on a dial-out machine, except for special circumstances. Create one or more .ppprc files if you do the following:
Allow multiple users with differing communications needs to call remote peers from the same machine. In such an instance, create individual .ppprc files in the home directories of each user who must dial out.
Need to specify options that control problems specific to your link, such as disabling Van Jacobson compression. See James Carlson's PPP Design, Implementation, and Debugging and the pppd(1M) man page for assistance in troubleshooting link problems.
Because the .ppprc file is most often used when configuring a dial-in server, refer to How to Configure Users of the Dial-in Server for configuration instructions for .ppprc.
To communicate with a dial-in server, you need to gather information about the server. Then edit a few files. Most significantly, you must configure the communications requirements of all dial-in servers that the dial-out machine needs to call. You can specify options about a dial-in server, such as an ISP phone number, in the /etc/ppp/options.ttyname file. However, the optimum place to configure peer information is in /etc/ppp/peers/peer-name files.
The /etc/ppp/peers/peer-name file is not needed on the dial-out machine for Solaris PPP 4.0 to work correctly.
Use the /etc/ppp/peers/peer-name file to provide information for communicating with a particular peer. /etc/ppp/peers/peer-name allows ordinary users to invoke preselected privileged options that users are not allowed to set.
For example, a non-privileged user cannot override the noauth option if noauth is specified in the /etc/ppp/peers/peer-name file. Suppose the user wants to set up a link to peerB, which does not provide authentication credentials. As superuser, you can create a /etc/ppp/peers/peerB file that includes the noauth option. noauth indicates that the local machine does not authenticate calls from peerB.
The pppd daemon reads /etc/ppp/peers/peer-name when pppd encounters the following option:
call peer-name |
You can create a /etc/ppp/peers/peer-name file for each target peer with which the dial-out machine needs to communicate. This practice is particularly convenient for permitting ordinary users to invoke special dial-out links without needing root privileges.
Typical options that you specify in /etc/ppp/peers/peer-name include the following:
Supply user_name to the dial-in server, as the login name of the dial-out machine, when authenticating with PAP or CHAP.
Use peer-name as the name of the dial-in machine. remotename is used in conjunction with PAP or CHAP authentication when scanning the /etc/ppp/pap-secrets or /etc/ppp/chap-secrets files.
Open communication to the dial-in server, by using the instructions in the chat script.
Do not authenticate the peer peer-name when initiating communications.
Set the initial IP address that is used in negotiating with the peer to 0.0.0.0. Use noipdefault when setting up a link to most ISPs to help facilitate IPCP negotiation between the peers.
Install a default IPv4 route when IP is established on the link.
See the pppd(1M) ) man page for more options that might apply to a specific target peer.
The /etc/ppp/peers/myisp.tmpl file contains helpful comments about the /etc/ppp/peers/peer-name file. The template concludes with common options that you might use for an /etc/ppp/peers/peer-name file:
connect "/usr/bin/chat -f /etc/ppp/myisp-chat" user myname remotename myisp noauth noipdefault defaultroute updetach noccp |
Option |
Definition |
connect "/usr/bin/chat -f /etc/ppp/myisp-chat" |
Call the peer by using the chat script /etc/ppp/myisp-chat. |
user myname |
Use this account name for the local machine. myname is the name for this machine in the peer's /etc/ppp/pap-secrets file. |
remotename myisp |
Recognize myisp as the name of the peer in the local machine's /etc/ppp/pap-secrets file. |
noauth |
Do not require calling peers to provide authentication credentials. |
noipdefault |
Do not use a default IP address for the local machine. |
defaultroute |
Use the default route that is assigned to the local machine. |
updetach |
Log errors in the PPP log files, rather than on the standard output. |
noccp |
Do not use CCP compression. |
To use /etc/ppp/peers/myisp.tmpl at your site, rename /etc/ppp/peers/myisp.tmpl to /etc/ppp/peers/.peer-name. Replace peer-name with the name of the peer to be called. Then modify the file contents as needed by your site.
Example /etc/ppp/peers/peer-name |
For Instructions |
For a local machine on a leased line | |
To support PAP authentication on a dial-out machine |
How to Add PAP Support to the PPP Configuration Files (Dial-out Machine) |
To support CHAP authentication on a dial-out machine |
To support PPPoE on a client system |
This section contains information about configuring modems.
A major issue in modem configuration is designating the speed at which the modem should operate. The following guidelines apply to modems that are used with Sun Microsystems computers:
Older SPARC systems – Check the hardware documentation that accompanies the system. Many SPARCstationTM machines require modem speed not to exceed 38400 bps.
UltraSPARCTM machines – Set the modem speed to 115200 bps, which is useful with modern modems and fast enough for a dial-up link. If you plan to use a dual-channel ISDN TA with compression, you need to increase the modem speed. The limit on an UltraSPARC is 460800 bps for an asynchronous link.
For a dial-out machine, set the modem speed in the PPP configuration files, such as /etc/ppp/peers/peer-name, or by specifying the speed as an option for pppd.
For a dial-in server, you need to set the speed by using the ttymon facility or admintool, as described in Configuring Devices on the Dial-in Server.
The dial-out machine and its remote peer communicate across the PPP link by negotiating and exchanging various instructions. When configuring a dial-out machine, you need to determine what instructions are required by the local and remote modems. Then you create a file that is called a chat script that contains these instructions. This section discusses information about configuring modems and creating chat scripts.
Each remote peer that the dial-out machine needs to connect to probably requires its own chat script.
Chat scripts are typically used only on dial-up links. Leased-line links do not use chat scripts unless the link includes an asynchronous interface that requires startup configuration.
The contents of the chat script are determined by the requirements of your modem model or ISDN TA, and the remote peer. These contents appear as a set of expect-send strings. The dial-out machine and its remote peers exchange the strings as part of the communications initiation process.
An expect string contains characters that the dial-out host machine expects to receive from the remote peer to initiate conversation. A send string contains characters that the dial-out machine sends to the remote peer after receiving the expect string.
Information in the chat script usually includes the following:
Modem commands, often referred to as AT commands, which enable the modem to transmit data over the telephone
Phone number of the target peer
This phone number might be the number that is required by your ISP, or a dial-in server at a corporate site, or an individual machine.
Time-out value, if required
Login sequence that is expected from the remote peer
Login sequence that is sent by the dial-out machine
This section contains chat scripts that you can use as a reference for creating your own chat scripts. The modem manufacturer's guide and information from your ISP and other target hosts contain chat requirements for the modem and your target peers. In addition, numerous PPP web sites have sample chat scripts.
The following is a basic chat script that you can use as a template for creating your own chat scripts.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" AT&F1M0&M5S2=255 SAY "Calling myserver\n" TIMEOUT 60 OK "ATDT1-123-555-1212" ogin: pppuser ssword: \q\U % pppd |
Script Contents |
Explanation |
ABORT BUSY |
Abort transmission if the modem receives this message from the opposite peer. |
ABORT 'NO CARRIER' |
Abort transmission if the modem reports ABORT 'NO CARRIER' when dialing. The cause for this message is usually a dialing or modem negotiation failure. |
REPORT CONNECT |
Gather the CONNECT string from the modem. Print the string. |
TIMEOUT 10 |
Set initial timeout to 10 seconds. The modem's response should be immediate. |
"" AT&F1M0&M5S2=255 |
M0 – Turn off the speaker during connect. &M5 – Make the modem require error control. S2=255 – Disable the TIES “+++” break sequence. |
SAY "Calling myserver\n" |
Display the message “Calling myserver” on the local machine. |
TIMEOUT 60 |
Reset the timeout to 60 seconds to allow more time for link negotiation. |
OK "ATDT1-123-555-1212" |
Call the remote peer by using the phone number 123-555-1212. |
ogin: pppuser |
Log in to the peer by using UNIX-style login. Supply the user name pppuser. |
ssword: \q\U |
\q – Do not log if debugging with the –v option. \U – Insert in this location the contents of the string that follows –U, which is specified on the command line. Usually, the string contains the password. |
% pppd |
Wait for the % shell prompt, and run the pppd command. |
Solaris PPP 4.0 includes the /etc/ppp/myisp-chat.tmpl, which you can modify for use at your site. /etc/ppp/myisp-chat.tmpl is similar to the basic modem chat script except that the template does not include a login sequence.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" "AT&F1" OK "AT&C1&D2" SAY "Calling myisp\n" TIMEOUT 60 OK "ATDT1-123-555-1212" CONNECT \c |
Script Contents |
Explanation |
ABORT BUSY |
ABORT 'NO CARRIER |
REPORT CONNECT |
TIMEOUT 10 |
"" "AT&F1" |
Reset the modem to factory defaults. |
OK "AT&C1&D2" |
Reset the modem so that, for &C1, DCD from the modem follows carrier. If the remote side hangs up the phone for some reason, then the DCD drops. For &D2, DTR high-to-low transition causes the modem to go “on-hook” or hang up. |
SAY "Calling myisp\n" |
Display the message “Calling myisp” on the local machine. |
TIMEOUT 60 |
CONNECT \c |
Wait for the CONNECT message from the opposite peer's modem. |
Use the next chat script as a template for calling an ISP from a dial-out machine with a U.S. Robotics Courier modem.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" AT&F1M0&M5S2=255 SAY "Calling myisp\n" TIMEOUT 60 OK "ATDT1-123-555-1212" CONNECT \c \r \d\c SAY "Connected; running PPP\n" |
The following table describes the contents of the chat script.
Script Contents |
Explanation |
ABORT BUSY |
REPORT CONNECT |
TIMEOUT 10 |
"" AT&F1M0M0M0M0&M5S2=255 |
TIMEOUT 60 |
CONNECT \c |
\r \d\c |
Wait until the end of the CONNECT message. |
SAY “Connected; running PPP\n” |
Display the informative message “Connected; running PPP” on the local machine. |
The next chat script is a basic script that is enhanced for calling a remote Solaris peer or other UNIX-type peer. This chat script is used in How to Create the Instructions for Calling a Peer.
SAY "Calling the peer\n" TIMEOUT 10 ABORT BUSY ABORT 'NO CARRIER' ABORT ERROR REPORT CONNECT "" AT&F1&M5S2=255 TIMEOUT 60 OK ATDT1-123-555-1234 CONNECT \c SAY "Connected; logging in.\n" TIMEOUT 5 ogin:--ogin: pppuser TIMEOUT 20 ABORT 'ogin incorrect' ssword: \qmypassword "% " \c SAY "Logged in. Starting PPP on peer system.\n" ABORT 'not found' "" "exec pppd" ~ \c |
Script Contents |
Explanation |
TIMEOUT 10 |
ABORT BUSY |
ABORT ERROR |
REPORT CONNECT |
"" AT&F1&M5S2=255 |
TIMEOUT 60 |
OK ATDT1-123-555-1234 |
CONNECT \c |
SAY "Connected; logging in.\n" |
Display the informative message “Connected; logging in,” to give the user status. |
TIMEOUT 5 |
Change the timeout to enable quick display of the login prompt. |
ogin:--ogin: pppuser |
Wait for the login prompt. If the prompt is not received, send a RETURN and wait. Then, send the user name pppuser to the peer. The sequence that follows is referred to by most ISPs as the PAP login. However, the PAP login is not related in any way to PAP authentication. |
TIMEOUT 20 |
Change the timeout to 20 seconds to allow for slow password verification. |
ssword: \qmysecrethere |
Wait for the password prompt from the peer. When the prompt is received, send the password \qmysecrethere. The \q prevents the password from being written to the system log files. |
"% " \c |
Wait for a shell prompt from the peer. The chat script uses the C shell. Change this value if the user prefers to log in with a different shell. |
SAY "Logged in. Starting PPP on peer system.\n" |
Display the informative message “Logged in. Starting PPP on peer system” to give the user status. |
ABORT 'not found' |
Abort the transmission if the shell encounters errors. |
"" "exec pppd" |
Start pppd on the peer. |
~ \c |
Wait for PPP to start on the peer. |
Starting PPP right after the CONNECT \c is often called a PAP login by ISPs, though the PAP login is actually not part of PAP authentication.
The phrase ogin:--ogin: pppuser instructs the modem to send the user name pppuser in response to the login prompt from the dial-in server. pppuser is a special PPP user account name that was created for remote user1 on the dial-in server. For instructions on creating PPP user accounts on a dial-in server, refer to How to Configure Users of the Dial-in Server.
The following chat script is for calling from a dial-out machine with a ZyXEL omni.net. ISDN TA.
SAY "Calling the peer\n" TIMEOUT 10 ABORT BUSY ABORT 'NO CARRIER' ABORT ERROR REPORT CONNECT "" AT&FB40S83.7=1&K44&J3X7S61.3=1S0=0S2=255 OK ATDI18882638234 CONNECT \c \r \d\c SAY "Connected; running PPP\n" |
The following table explains the parameters of the chat script.
Script Contents |
Explanation |
SAY "Calling the peer" |
Display this message on the screen of the dial-out machine. |
TIMEOUT 10 |
Set the initial timeout to 10 seconds. |
ABORT BUSY |
ABORT ERROR |
REPORT CONNECT |
"" AT&FB40S83.7= 1&K44&J3X7S61.3=1 S0=0S2=255 |
The letters in this line have the following meaning:
OK ATDI18882638234 |
Make an ISDN call. For multi-link, the second call is placed to the same telephone number, which is normally what is required by most ISPs. If the remote peer requires a different second phone number, append “+nnnn.”. nnnn represents the second phone number. |
CONNECT \c |
\r \d\c |
Refer to the chat(1M) man page for descriptions of options and other detailed information about the chat script. For an explanation of expect-send strings, refer to UUCP Chat Script Field.
A number of web sites offer sample chat scripts and assistance in creating the chat scripts.
The PPP Frequently Asked Questions (FAQ) available from Australian National University posts URL.
You call chat scripts by using the connect option. You can use connect "chat ..." in any PPP configuration file or on the command line.
Chat scripts are not executable, but the program that is invoked by connect must be executable. You might use the chat utility as the program to be invoked by connect. In this instance, if you store the chat script in an external file through the –f option, then your chat script file is not executable.
The chat program that is described in chat(1m) executes the actual chat script. The pppd daemon invokes the chat program whenever pppd encounters the connect "chat ..." option.
You can use any external program, such as Perl or Tcl, to create advanced chat scripts. Solaris PPP 4.0 provides the chat utility as a convenience.
Create the chat script as an ASCII file.
Invoke the chat script in any PPP configuration file by using the following syntax:
connect 'chat -f /etc/ppp/chatfile' |
The -f flag indicates that a file name is to follow. /etc/ppp/chatfile represents the name of the chat file.
Give read permission for the external chat file to the user who runs the pppd command.
The chat program always runs with the user's privileges, even if the connect 'chat ...' option is invoked from a privileged source. Thus, a separate chat file that is read with the -f option must be readable by the invoking user. This privilege can be a security problem if the chat script contains passwords or other sensitive information.
If the chat script that is needed for a particular peer is long or complicated, consider creating the script as a separate file. External chat files are easy to maintain and to document. You can add comments to the chat file by preceding the comments with the hash (#) sign.
The procedure How to Create the Instructions for Calling a Peer shows the use of a chat script that is contained in an external file.
You can place the entire chat script conversation on a single line, similar to the following:
connect 'chat "" "AT&F1" OK ATDT5551212 CONNECT "\c"' |
You can create a chat file that is an executable script to be run automatically when the dial-up link is initiated. Thus you can run additional commands during link initiation, such as stty for parity settings, besides the commands that are contained in a traditional chat script.
This executable chat script logs in to an old-style UNIX system that requires 7 bits with even parity. The system then changes to 8 bits with no parity when running PPP.
#!/bin/sh chat "" "AT&F1" OK "ATDT555-1212" CONNECT "\c" stty evenp chat ogin: pppuser ssword: "\q\U" % "exec pppd" stty -evenp |
Use your text editor to create an executable chat program, such as the previous example.
Make the chat program executable.
# chmod +x /etc/ppp/chatprogram |
Invoke the chat program.
connect /etc/ppp/chatprogram |
Chat programs do not have to be located within the /etc/ppp file system. You can store chat programs in any location.
This section explains how the PPP authentication protocols work and explains the databases that are associated with the authentication protocols.
PAP authentication is somewhat similar in operation to the UNIX login program, though PAP does not grant shell access to the user. PAP uses the PPP configuration files and PAP database in the form of the /etc/ppp/pap-secrets file for setting up authentication. PAP also uses /etc/ppp/pap-secrets for defining PAP security credentials. These credentials include a peer name, a “user name” in PAP parlance and a password. PAP credentials also contain related information for each caller who is permitted to link to the local machine. The PAP user names and passwords can be identical to or different from the UNIX user names and passwords in the password database.
The PAP database is implemented in the /etc/ppp/pap-secrets file. Machines on both sides of the PPP link must have properly configured PAP credentials in their /etc/ppp/pap-secrets files for successful authentication. The caller (authenticatee) supplies credentials in the user and password columns of the /etc/ppp/pap-secrets file or in the obsolete +ua file. The server (authenticator) validates these credentials against information in /etc/ppp/pap-secrets, through the UNIX passwd database, or in the PAM facility.
The /etc/ppp/pap-secrets file has the following syntax.
Table 32–5 Syntax of /etc/ppp/pap-secrets
Caller |
Server |
Password |
IP Addresses |
myclient |
ISP-server |
mypassword |
The parameters have the following meaning.
PAP user name of the caller. Often, this name is identical to the caller's UNIX user name, particularly if the dial-in server uses the login option of PAP.
Name of the remote machine, often a dial-in server.
Caller's PAP password.
IP address that is associated with the caller. Use an asterisk (*) to indicate any IP address.
PAP passwords are sent over the link in the clear, that is, in readable ASCII format. For the caller (authenticatee), the PAP password must be stored in the clear in any of the following locations:
In /etc/ppp/pap-secrets
In another external file
In a named pipe through the pap-secrets @ feature
As an option to pppd, either on the command line or in a PPP configuration file
Through the +ua file
On the server (authenticator), the PAP password can be hidden by doing one of the following:
Specifying papcrypt and using passwords that are hashed by crypt(3C) in the pap-secrets file.
Specifying the login option to pppd and omitting the password from the pap-secrets file by placing double quotes ("") in the password column. In this instance, authentication is done through the UNIX passwd database or the pam(3pam) mechanism.
PAP authentication occurs in the following sequence.
The caller (authenticatee) calls the remote peer (authenticator) and provides its PAP user name and password as part of link negotiation.
The peer verifies the identity of the caller in its/etc/ppp/pap-secrets file. If the peer uses the login option of PAP, the peer verifies the caller's user name and password in its password database.
If authentication is successful, the peer continues link negotiation with the caller. If authentication fails, the link is dropped.
(Optional) If the caller authenticates responses from remote peers, the remote peer must send its own PAP credentials to the caller. Thus, the remote peer becomes the authenticatee and the caller the authenticator.
The original caller reads its own /etc/ppp/pap-secrets to verify the identity of the remote peer.
If the original caller does require authentication credentials from the remote peer, Step 1 and Step 4 happen in parallel.
If the peer is authenticated, negotiation continues. Otherwise, the link is dropped.
Negotiation between caller and peer continues until the link is successfully established.
You can add the login option for authenticating PAP credentials to any PPP configuration file. When login is specified, for example, in /etc/ppp/options, pppd verifies that the caller's PAP credentials exist in the Solaris password database. The following table shows the format of a /etc/ppp/pap-secrets file with the login option.
Table 32–6 /etc/ppp/pap-secrets With login Option
Caller |
Server |
Password |
IP Addresses |
joe |
sally |
sue |
The parameters have the following meanings.
Names of all authorized callers.
Asterisk, which indicates that any server name is valid. The name option is not required in the PPP configuration files.
Double quotes, which indicate that any password is valid.
If a password is in this column, then the password from the peer must match both the PAP password and the UNIX passwd database.
Asterisk, which indicates that any IP address is allowed.
CHAP authentication uses the notion of the challenge and response, which means that the peer (authenticator) challenges the caller (authenticatee) to prove its identity. The challenge includes a random number and a unique ID that is generated by the authenticator. The caller must use the ID, random number, and its CHAP security credentials to generate the proper response (handshake) to send to the peer.
CHAP security credentials include a CHAP user name and a CHAP “secret.” The chat secret is an arbitrary string that is known to both the caller and the peer before they negotiate a PPP link. You configure CHAP security credentials in the CHAP database, /etc/ppp/chap-secrets.
The CHAP database is implemented in the /etc/ppp/chap-secrets file. Machines on both sides of the PPP link must have each others' CHAP credentials in their /etc/ppp/chap-secrets files for successful authentication.
Unlike PAP, the shared secret must be in the clear on both peers. You cannot use crypt, PAM, or the PPP login option with CHAP.
The /etc/ppp/chap-secrets file has the following syntax.
Table 32–7 Syntax of /etc/ppp/chap-secrets
Caller |
Server |
CHAP secret |
IP Addresses |
myclient |
myserver |
secret5748 |
The parameters have the following meanings:
CHAP user name of the caller. This name can be the same as or different from the caller's UNIX user name.
Caller's CHAP secret.
Unlike PAP passwords, CHAP secrets are never sent over the link. Rather, CHAP secrets are used when the local machines compute the response.
CHAP authentication occurs in the following sequence.
Two peers that are about to initiate communications agree on a secret to be used for authentication during negotiation of a PPP link.
The administrators of both machines add the secret, CHAP user names, and other CHAP credentials to the /etc/ppp/chap-secrets database of their respective machines.
The caller (authenticatee) calls the remote peer (authenticator).
The authenticator generates a random number and an ID, and sends this data to the authenticatee as a challenge.
The authenticatee looks up the peer's name and secret in its /etc/ppp/chap-secrets database.
The authenticatee calculates a response by applying the MD5 computational algorithm to the secret and the peer's random number challenge. Then the authenticatee sends the results as its response to the authenticator.
The authenticator looks up the authenticatee's name and secret in its /etc/ppp/chap-secrets database.
The authenticator calculates its own figure by applying MD5 to the number that was generated as the challenge and the secret for the authenticatee in /etc/ppp/chap-secrets.
The authenticator compares its results with the response from the caller. If the two numbers are the same, the peer has successfully authenticated the caller, and link negotiation continues. Otherwise the link is dropped.
Consider creating one or more IP addresses for all incoming calls instead of assigning a unique IP address to each remote user. Dedicated IP addresses are particularly important if the number of potential callers exceeds the number of serial ports and modems on the dial-in server. You can implement a number of different scenarios, depending on your site's needs. Moreover, the scenarios are not mutually exclusive.
Dynamic addressing involves the assignment to each caller of the IP address that is defined in /etc/ppp/options.ttyname. Dynamic addressing occurs on a per-serial port basis. When a call arrives over a serial line, the caller receives the IP address in the /etc/ppp/options.ttyname file for the call's serial interface.
For example, suppose a dial-in server has four serial interfaces that provide dial-up service to incoming calls:
For serial port term/a, create the file /etc/ppp/options.term.a with the following entry:
:10.1.1.1 |
For serial port term/b, create the file /etc/ppp/options.term.b with the following entry:
:10.1.1.2 |
For serial port term/c, create the file /etc/ppp/options.term.c with the following entry:
:10.1.1.3 |
For serial port term/d, create the file /etc/ppp/options.term.d with the following entry:
:10.1.1.4 |
The advantages of dynamic addressing include the following:
You can track PPP network usage down to the serial port.
You can assign a minimum number of IP addresses for PPP use.
You can administer IP filtering in a more simplified fashion.
If your site implements PPP authentication, you can assign specific, static IP addresses to individual callers. In this scenario, every time a dial-out machine calls the dial-in server, the caller receives the same IP address.
You implement static addresses in either the pap-secrets or chap-secrets database. Here is a sample /etc/ppp/pap-secrets file that defines static IP addresses.
Caller |
Server |
Password |
IP Addresses |
joe |
myserver |
joepasswd |
10.10.111.240 |
sally |
myserver |
sallypasswd |
10.10.111.241 |
sue |
myserver |
suepasswd |
10.10.111.242 |
Here is a sample /etc/ppp/chap-secrets file that defines static IP addresses.
Caller |
Server |
CHAP secret |
IP Addresses |
account1 |
myserver |
secret5748 |
10.10.111.244 |
account2 |
myserver |
secret91011 |
10.10.111.245 |
If you are using either PAP or CHAP authentication, you can assign IP addresses to callers by the sppp unit number. The next table shows an example of this usage.
Caller |
Server |
Password |
IP Addresses |
myclient |
ISP-server |
mypassword |
10.10.111.240/28+ |
The plus sign (+) indicates that the unit number is added to the IP address. Addresses 10.10.111.240 through 10.10.111.255 are assigned to remote users. sppp0 gets IP address 10.10.111.240. sppp1 gets IP address 10.10.111.241, and so on.
By using PPPoE, you can provide PPP over high-speed digital services to multiple clients that are using one or more DSL modems. PPPoE implements these services by creating an Ethernet tunnel through three participants, the enterprise, the telephone company, and the service provider.
For an overview and description of how PPPoE works, see PPPoE Overview.
For tasks for setting up PPPoE tunnels, see Chapter 30, Setting Up a PPPoE Tunnel (Tasks).
This section contains detailed information about PPPoE commands and files, which is summarized in the next table.
Table 32–8 PPPoE Commands and Configuration Files
File or Command |
Description |
For Instructions |
/etc/ppp/pppoe |
A file that contains characteristics that are applied by default to all tunnels that were set up by PPPoE on the system | |
/etc/ppp/pppoe.device |
A file that contains characteristics of a particular interface that is used by PPPoE for a tunnel | |
/etc/ppp/pppoe.if |
File that lists the Ethernet interface over which the tunnel that is set up by PPPoE runs | |
/usr/sbin/sppptun |
Command for configuring the Ethernet interfaces that are involved in a PPPoE tunnel | |
/usr/lib/inet/pppoed |
Command and options for using PPPoE to set up a tunnel |
The interfaces that are used at either end of the PPPoE tunnel must be configured before the tunnel can support PPP communications. Use /usr/sbin/sppptun and /etc/ppp/pppoe.if files for this purpose. You must use these tools to configure Ethernet interfaces on all Solaris PPPoE clients and PPPoE access servers.
The /etc/ppp/pppoe.if file lists the names of all Ethernet interfaces on a host to be used for the PPPoE tunnels. This file is processed during system boot when the interfaces that are listed are plumbed for use in PPPoE tunnels.
You need to explicitly create /etc/ppp/pppoe.if. Type the name of one interface to be configured for PPPoE on each line.
The following example shows an /etc/ppp/pppoe.if file for a server that offers three interfaces for PPPoE tunnels.
# cat /etc/ppp/pppoe.if hme1 hme2 hme3 |
PPPoE clients usually have only one interface that is listed in /etc/ppp/pppoe.if.
You can use the /usr/sbin/sppptun command to manually plumb and unplumb the Ethernet interfaces to be used for PPPoE tunnels. By contrast, /etc/ppp/pppoe.if is only read when the system boots. These interfaces should correspond to the interfaces that are listed in /etc/ppp/pppoe.if.
sppptun plumbs the Ethernet interfaces that are used in PPPoE tunnels in a manner that is similar to the ifconfig command. Unlike ifconfig, you must plumb interfaces twice to support PPPoE because two Ethernet protocol numbers are involved.
The basic syntax for sppptun is as follows:
# /usr/sbin/sppptun plumb pppoed device-name device-name:pppoed # /usr/sbin/sppptun plumb pppoe device-name device-name:pppoe |
The first time that you issue the sppptun command, the discovery protocol pppoed is plumbed on the interface. The second time that you run sppptun, the session protocol pppoe is plumbed. sppptun prints the name of the interface that was just plumbed. You use this name to unplumb the interface, when necessary.
For more information, refer to thesppptun(1M) man page.
The following sample shows how to manually plumb an interface for PPPoE by using /usr/sbin/sppptun.
# /usr/sbin/sppptun plumb pppoed hme0 hme0:pppoed # /dev/sppptun plumb pppoe hme0 hme0:pppoe |
This sample shows how to list the interfaces on an access server that was plumbed for PPPoE.
/usr/sbin/sppptun query hme0:pppoe hme0:pppoed hme1:pppoe hme1:pppoed hme2:pppoe hme2:pppoed |
This sample shows how to unplumb an interface.
# sppptun unplumb hme0:pppoed # sppptun unplumb hme0:pppoe |
A service provider that offers DSL services or support to customers can use an access server that is running Solaris PPPoE. The PPPoE access server and client do function in the traditional client-server relationship. This relationship is similar to the relationship of the dial-out machine and dial-in server on a dial-up link. One PPPoE system initiates communications and one PPPoE system answers. By contrast, the PPP protocol has no notion of the client-server relationship. PPP considers both systems equal peers.
The commands and files that set up a PPPoE access server include the following:
The pppoed daemon accepts broadcasts for services from prospective PPPoE clients. Additionally, pppoed negotiates the server side of the PPPoE tunnel and runs pppd, the PPP daemon, over that tunnel.
You configure pppoed services in the /etc/ppp/pppoe and /etc/ppp/pppoe.device files. If /etc/ppp/pppoe exists when the system boots, pppoed runs automatically. You can also explicitly run the pppoed daemon on the command line by typing /usr/lib/inet/pppoed.
The /etc/ppp/pppoe file describes the services that are offered by an access server plus options that define how PPP runs over the PPPoE tunnel. You can define services for individual interfaces, or globally, that is, for all interfaces on the access server. The access server sends the information in the /etc/ppp/pppoe file in response to a broadcast from a potential PPPoE client.
The following is the basic syntax of /etc/ppp/pppoe:
global-options service service-name service-specific-options device interface-name |
Sets the default options for the /etc/ppp/pppoe file. These options can be any options that are available through pppoed or pppd. For complete lists of options, see the man pages pppoed(1M) and pppd(1M).
For example, you must list the Ethernet interfaces that are available for the PPPoE tunnel as part of global options. If you do not define devices in /etc/ppp/pppoe, the services are not offered on any interface.
To define devices as a global option, use the following form:
device interface <,interface> |
Starts the definition of the service service-name. service-name is a string that can be any phrase that is appropriate to the services that are provided.
Lists the PPPoE and PPP options specific to this service.
Specifies the interface where the previously listed service is available.
For additional options to /etc/ppp/pppoe, refer to the pppoed(1M) and pppd(1M) man pages.
A typical /etc/ppp/pppoe file might resemble the following.
device hme1,hme2,hme3 service internet pppd "name internet-server" service intranet pppd "192.168.1.1:" service debug device hme1 pppd "debug name internet-server" |
In this file, the following values apply.
Three interfaces on the access server to be used for PPPoE tunnels.
Advertises a service that is called internet to prospective clients. The provider that offers the service also determines how internet is defined. For example, a provider might interpret internet to mean various IP services, as well as access to the Internet.
Sets the command-line options that are used when the caller invokes pppd. The option "name internet-server" gives the name of the local machine, the access server, as internet-server.
Advertises another service that is called intranet to prospective clients.
Sets the command-line options that are used when the caller invokes pppd. When the caller invokes pppd, 192.168.1.1 is set as the IP address for the local machine, the access server.
Advertises a third service, debugging, on the interfaces that are defined for PPPoE.
Restricts debugging to PPPoE tunnels to hme1.
Sets the command-line options that are used when the caller invokes pppd, in this instance, PPP debugging on internet-server, the local machine.
The /etc/ppp/pppoe.device file describes the services that are offered on one interface of a PPPoE access server. /etc/ppp/pppoe.device also includes options that define how PPP runs over the PPPoE tunnel. /etc/ppp/pppoe.device is an optional file, which operates exactly like the global /etc/ppp/pppoe. However, if /etc/ppp/pppoe.device is defined for an interface, its parameters have precedence for that interface over the global parameters that are defined in /etc/ppp/pppoe.
The basic syntax of /etc/ppp/pppoe.device is as follows:
service service-name service-specific-options service another-service-name service-specific-options |
The only difference between this syntax and the syntax of /etc/ppp/pppoe is that you cannot use the device option that is shown in /etc/ppp/pppoe File.
pppoe.so is the PPPoE shared object file that must be invoked by PPPoE access servers and clients. This file limits MTU and MRU to 1492, filters packets from the driver, and negotiates the PPPoE tunnel, along with pppoed. On the access server side, pppoe.so is automatically invoked by the pppd daemon.
This section contains samples of all files that are used to configure an access server. The access server is multihomed. The server is attached to three subnets: green, orange, and purple. pppoed runs as root on the server, which is the default.
PPPoE clients can access the orange and purple networks through interfaces hme0 and hme1. Clients log in to the server by using the standard UNIX login. The server authenticates the clients by using PAP.
The green network is not advertised to clients. The only way clients can access green is by directly specifying “green-net” and supplying CHAP authentication credentials. Moreover, only clients joe and mary are allowed to access the green network by using static IP addresses.
service orange-net device hme0,hme1 pppd "require-pap login name orange-server orange-server:" service purple-net device hme0,hme1 pppd "require-pap login name purple-server purple-server:" service green-net device hme1 pppd "require-chap name green-server green-server:" nowildcard |
This sample describes the services that are available from the access server. The first service section describes the services of the orange network.
service orange-net device hme0,hme1 pppd "require-pap login name orange-server orange-server:" |
The service section for the purple network is identical to the service section of the orange network except for the network and server names.
The next section describes the services of the green network:
For this access server scenario just discussed, you might set up the following /etc/ppp/options file.
auth proxyarp nodefaultroute name no-service # don't authenticate otherwise |
The option name no-service overrides the server name that is normally searched for during PAP or CHAP authentication. The server's default name is found in the /usr/bin/hostname file. The name option in the previous example changes the server's name to no-service. The name no-service is not likely to be found in a pap or chap-secrets file. This action prevents a random user from running pppd and overriding the auth and name options that are set in /etc/ppp/options. pppd then fails because no secrets can be found for the client with a server name of no-service.
The access server scenario uses the following /etc/hosts file.
172.16.0.1 orange-server 172.17.0.1 purple-server 172.18.0.1 green-server 172.18.0.2 joes-pc 172.18.0.3 marys-pc |
Here is the /etc/ppp/pap-secrets file that is used for PAP authentication for clients that attempt to access the orange and purple networks.
* orange-server "" 172.16.0.2/16+ * purple-server "" 172.17.0.2/16+ |
Here is the /etc/ppp/chap-secrets file that is used for CHAP authentication. Note that only clients joe and mary are listed in the file.
joe green-server "joe's secret" joes-pc mary green-server "mary's secret" marys-pc |
To run PPP over a DSL modem, a machine must become a PPPoE client. You have to plumb an interface to run PPPoE, and then use the pppoec utility to “discover” the existence of an access server. Thereafter, the client can create the PPPoE tunnel over the DSL modem and run PPP.
The PPPoE client relates to the access server in the traditional client-server model. The PPPoE tunnel is not a dial-up link, but the tunnel is configured and operated in much the same manner.
The commands and files that set up a PPPoE client include the following:
The /usr/lib/inet/pppoec utility is responsible for negotiating the client side of a PPPoE tunnel. pppoec is similar to the Solaris PPP 4.0 chat utility. You do not invoke pppoec directly. Rather, you start /usr/lib/inet/pppoec as an argument to the connect option of pppd.
pppoe.so is the PPPoE shared object that must be loaded by PPPoE to provide PPPoE capability to access servers and clients. The pppoe.soshared object limits MTU and MRU to 1492, filters packets from the driver, and handles runtime PPPoE messages.
On the client side, pppd loads pppoe.so when the user specifies the plugin pppoe.so option.
When you define an access server to be discovered by pppoec, you use options that apply to both pppoec and the pppd daemon. A /etc/ppp/peers/peer-name file for an access server requires the following parameters:
sppptun – Name for the serial device that is used by the PPPoE tunnel
plugin pppoe.so – Instructs pppd to load the pppoe.so shared object
connect "/usr/lib/inet/pppoec device" – Starts a connection. connect then invokes the pppoec utility over device, the interface that is plumbed for PPPoE
The following example is introduced in How to Define a PPPoE Access Server Peer.
# vi /etc/ppp/peers/dslserve sppptun plugin pppoe.so connect "/usr/lib/inet/pppoec hme0" noccp noauth user Red password redsecret noipdefault defaultroute |
This file defines parameters to be used when setting up a PPPoE tunnel and PPP link to access server dslserve. The options that are included are as follows.
Option |
Description |
sppptun | |
plugin pppoe.so | |
connect "/usr/lib/inet/pppoec hme0" |
Runs pppoec and designates hme0 as the interface for the PPPoE tunnel and PPP link. |
noccp |
Turns off CCP compression on the link. Note – Many ISPs use only proprietary compression algorithms. Turning off the publicly available CCP algorithm saves negotiation time and avoids very occasional interoperability problems. |
noauth |
Stops pppd from demanding authentication credentials from the access server. Most ISPs do not provide authentication credentials to customers. |
user Red |
Sets the name Red as the user name for the client, which is required for PAP authentication by the access server. |
password redsecret |
Defines redsecret as the password to be provided to the access server for PAP authentication. |
noipdefault |
Assigns 0.0.0.0 as the initial IP address. |
defaultroute |
Tells pppd to install a default IPv4 route after IPCP negotiation. You should include defaultroute in /etc/ppp/peers/peer-name when the link is the system's link to the Internet, which is true for a PPPoE client. |
Earlier versions of the Solaris operating system included a different PPP implementation, Asynchronous Solaris PPP (asppp). If you want to convert peers that run asppp to the newer PPP 4.0, you need to run a conversion script. This chapter covers the following topics in PPP conversion:
The chapter uses a sample asppp configuration to explain how to accomplish PPP conversion. For a description of the differences between Solaris PPP 4.0 and asppp, go to Which Version of Solaris PPP to Use.
You can use the conversion script /usr/sbin/asppp2pppd to convert the files that compose a standard asppp configuration:
/etc/asppp.cf – Asynchronous PPP configuration file
/etc/uucp/Systems – UUCP file that describes the characteristics of the remote peer
/etc/uucp/Devices – UUCP file that describes the modem on the local machine
/etc/uucp/Dialers – UUCP file that contains the login sequence to be used by the modem that is described in the /etc/uucp/Devices file
For more information about asppp, see the Solaris 8 System Administration Collection, Volume 3, available from http://www.docs.sun.com.
The procedure that is shown in How to Convert From asppp to Solaris PPP 4.0 uses the following /etc/asppp.cf file.
# ifconfig ipdptp0 plumb mojave gobi up path inactivity_timeout 120 # Approx. 2 minutes interface ipdptp0 peer_system_name Pgobi # The name we log in with (also in # /etc/uucp/Systems |
The file contains the following parameters.
Runs the ifconfig command to configure a link from PPP interface ipdptp0 on the local machine mojave to the remote peer gobi
Terminates the line after two minutes of inactivity
Configures the interface ipdptp0 on the dial-out machine for asynchronous PPP
Gives the name of the remote peer, Pgobi
The procedure that is shown in How to Convert From asppp to Solaris PPP 4.0 uses the following /etc/uucp/Systems file.
#ident "@(#)Systems 1.5 92/07/14 SMI" /* from SVR4 bnu:Systems 2.4 */ # # . # . Pgobi Any ACU 38400 15551212 in:--in: mojave word: sand |
The file contains the following parameters:
Uses Pgobi as the host name of the remote peer.
Tells the modem on the dial-out machine mojave to establish a link with a modem on Pgobi at any time of the day. Any ACU means “look for ACU in the /etc/uucp/Devices file.”
Sets 38400 as the maximum speed of the link.
Gives the telephone number of Pgobi.
Defines the login script that is required by Pgobi to authenticate dial-out machine mojave.
The procedure that is shown in How to Convert From asppp to Solaris PPP 4.0 uses the following /etc/uucp/Devices file.
#ident "@(#)Devices 1.6 92/07/14 SMI" /* from SVR4 bnu:Devices 2.7 */ . . # TCP,et - - Any TCP - . . # ACU cua/b - Any hayes # 0-7 are on a Magma 8 port card Direct cua/0 - Any direct Direct cua/1 - Any direct Direct cua/2 - Any direct Direct cua/3 - Any direct Direct cua/4 - Any direct Direct cua/5 - Any direct Direct cua/6 - Any direct Direct cua/7 - Any direct # a is the console port (aka "tip" line) Direct cua/a - Any direct # b is the aux port on the motherboard Direct cua/b - Any direct # c and d are high speed sync/async ports Direct cua/c - Any direct Direct cua/d - Any direct |
The file supports any Hayes modem that is connected to serial port cua/b.
The procedure that is shown in How to Convert From asppp to Solaris PPP 4.0 uses the following /etc/uucp/Dialers file.
# #<Much information about modems supported by Solaris UUCP> penril =W-P "" \d > Q\c : \d- > s\p9\c )-W\p\r\ds\p9\c-) y\c : \E\TP > 9\c OK ventel =&-% "" \r\p\r\c $ k\c ONLINE! vadic =K-K "" \005\p *-\005\p-*\005\p-* D\p BER? \E\T\e \r\c LINE develcon "" "" \pr\ps\c est:\007 \E\D\e \n\007 micom "" "" \s\c NAME? \D\r\c GO direct # # # # Hayes Smartmodem -- modem should be set with the configuration # switches as follows: # # S1 - UP S2 - UP S3 - DOWN S4 - UP # S5 - UP S6 - DOWN S7 - ? S8 - DOWN # hayes =,-, "" \dA\pTE1V1X1Q0S2=255S12=255\r\c OK\r \EATDT\T\r\c CONNECT <much more information about modems supported by Solaris UUCP> |
This file contains the chat scripts for all types of modems, including the Hayes modems that are supported in the /etc/uucp/Dialers file.
The /usr/sbin/asppp2pppd script copies the PPP information in /etc/asppp.cf and PPP-related UUCP files to appropriate locations in the Solaris PPP 4.0 files.
Before doing the next task, you should have done the following:
Installed the Solaris 9 operating environment on the machine that also has the asppp and UUCP configuration files
Become superuser on the machine with the PPP files, for example, the machine mojave
Start the conversion script.
# /usr/sbin/asppp2pppd |
The conversion process starts and gives you the following screen output.
This script provides only a suggested translation for your existing aspppd configuration. You will need to evaluate for yourself whether the translation is appropriate for your operating environment. Continue [Yn]? |
Type Y to continue. You receive the following output.
Chat cannot do echo checking; requests for this removed. Adding 'noauth' to /etc/ppp/options Preparing to write out translated configuration: 1 chat file: 1. /etc/ppp/chat.Pgobi.hayes 2 option files: 2. /etc/ppp/peers/Pgobi 3. /etc/ppp/options 1 script file: 4. /etc/ppp/demand |
The new Solaris PPP 4.0 files have been generated.
You can view the Solaris PPP 4.0 files that were created by the /usr/sbin/asppp2pppd conversion script at the end of the conversion process. The script displays the following list of options.
Enter option number: 1 - view contents of file on standard output 2 - view contents of file using /usr/bin/less 3 - edit contents of file using /usr/bin/vi 4 - delete/undelete file from list 5 - rename file in list 6 - show file list again 7 - escape to shell (or "!") 8 - abort without saving anything 9 - save all files and exit (default) Option: |
Type 1 to view the contents of the files on the screen.
The script requests the number of the file you want to view.
File number (1 .. 4): |
The numbers refer to the translated files that are listed during the conversion process, as shown in the previous Step 2.
Type 1 to view the chat file /etc/ppp/chat.Pgobi.hayes.
File number (1 .. 4): 1 "" \d\dA\p\pTE1V1X1Q0S2=255S12=255\r\c OK\r ATDT\T\r\c CONNECT \c in:--in: mojave word: sand |
The chat script contains the modem “chat” information that appears on the hayes line in the sample /etc/uucp/Dialers file. /etc/ppp/chat.Pgobi.hayes also contains the login sequence for Pgobi that appears in the sample /etc/uucp/Systems file. The chat script is now in the /etc/ppp/chat.Pgobi.hayes file.
Type 2 to view the peers file, /etc/ppp/peers/Pgobi.
File number (1 .. 4): 2 /dev/cua/b 38400 demand idle 120 connect "/usr/bin/chat -f /etc/ppp/chat.Pgobi.hayes -T '15551212'" user NeverAuthenticate mojave:gobi |
The serial port information (/dev/cua/b) is from the /etc/uucp/Devices file. The link speed, idle time, authentication information, and peer names are from the /etc/asppp.cf file. “demand” refers to the “demand” script, to be called when the dial-out machine tries to connect to peer Pgobi.
Type 3 to view the /etc/ppp/options file that are created for dial-out machine mojave.
File number (1 .. 4): 3 #lock noauth |
The information in /etc/ppp/options is from the /etc/asppp.cf file.
Type 4 to view the contents of the demand script.
File number (1 .. 4): 4 /usr/bin/pppd file /etc/ppp/peers/Pgobi |
This script, when invoked, runs the pppd command, which then reads the /etc/ppp/peers/Pgobi to initiate the link between mojave and Pgobi.
Type 9 to save the created files. Then exit the conversion script.
This chapter introduces the UNIX-to-UNIX Copy Program (UUCP) and daemons. The following topics are covered:
UUCP enables computers to transfer files and exchange mail with each other. The program also enables computers to participate in large networks such as Usenet.
The Solaris environment provides the Basic Network Utilities (BNU) version of UUCP, also known as HoneyDanBer UUCP. The term UUCP denotes the complete range of files and utilities that compose the system, of which the program uucp is only a part. The UUCP utilities range from those utilities that are used to copy files between computers (uucp and uuto) to those utilities that are used for remote login and command execution (cu and uux).
UUCP supports the following hardware configurations:
You can create a direct link to another computer by running RS-232 cables between serial ports on the two machines. Direct links are useful when two computers communicate regularly and are physically close—within 50 feet of each other. You can use a limited-distance modem to increase this distance somewhat.
Using an automatic call unit (ACU), such as a high-speed modem, your machine can communicate with other computers over standard phone lines. The modem dials the telephone number that is requested by UUCP. The recipient machine must have a modem capable of answering incoming calls.
UUCP can also communicate over a network that runs TCP/IP or an other protocol family. After your computer has been established as a host on a network, it can contact any other host that is connected to the network.
This chapter assumes that your UUCP hardware has already been assembled and configured. If you need to set up a modem, refer to System Administration Guide: Basic Administration and the manuals that accompanied the modem for assistance.
The UUCP software is automatically included when you run the Solaris installation program and select the entire distribution. Alternatively, you can add it by using pkgadd. The UUCP programs can be divided into three categories: daemons, administrative programs, and user programs.
The UUCP system has four daemons: uucico, uuxqt, uusched, and in.uucpd. These daemons handle UUCP file transfers and command executions. You can also run them manually from the shell, if necessary.
Selects the device that is used for the link, establishes the link to the remote computer, and performs the required login sequence and permission checks. Also, uucico transfers data and execute files, logs results, and notifies the user by mail of transfer completions. uucico acts as the “login shell” for UUCP login accounts. When the local uucico daemon calls a remote machine, it communicates directly with the remote uucico daemon during the session.
After all the required files have been created, uucp, uuto, and uux programs execute the uucico daemon to contact the remote computer. uusched and Uutry all execute uucico. See the uucico(1M) man page for details.
Executes remote execution requests. This daemon searches the spool directory for execute files (always named X.file) that have been sent from a remote computer. When an X.file file is found, uuxqt opens it to get the list of data files that are required for the execution. uuxqt then checks to see if the required data files are available and accessible. If the files are available, uuxqt checks the Permissions file to verify that it has permission to execute the requested command. The uuxqt daemon is executed by the uudemon.hour shell script, which is started by cron. See the uuxqt(1M) man page for details.
Schedules the queued work in the spool directory. uusched is initially run at boot time by the uudemon.hour shell script, which is started by cron. See the uusched(1M) man page for details. Before starting the uucico daemon, uusched randomizes the order in which remote computers are called.
Supports UUCP connections over networks. The inetd on the remote host invokes in.uucpd whenever a UUCP connection is established. uucpd then prompts for a login name. uucico on the calling host must respond with a login name. in.uucpd then prompts for a password, unless one is not required. See the in.uucpd(1M) man page for details.
Most UUCP administrative programs are in /usr/lib/uucp. Most basic database files are in /etc/uucp. The only exception is uulog, which is in /usr/bin. The home directory of the uucp login ID is /usr/lib/uucp. When running the administrative programs through su or login, use the uucp user ID. The user ID owns the programs and spooled data files.
Displays the contents of a specified computer's log files. Log files are created for each remote computer with which your machine communicates. The log files record each use of uucp, uuto, and uux. See the uucp(1C) man page for details.
Cleans up the spool directory. uucleanup is normally executed from the uudemon.cleanup shell script, which is started by cron. See the uucleanup(1M) man page for details.
Tests call-processing capabilities and does moderate debugging. Uutry invokes the uucico daemon to establish a communication link between your machine and the remote computer you specify. See the Uutry(1M) man page for details.
Checks for the presence of UUCP directories, programs, and support files. uucheck can also check certain parts of the /etc/uucp/Permissions file for obvious syntactic errors. See the uucheck(1M) man page for details.
The UUCP user programs are in /usr/bin. You do not need special permission to use these programs.
Connects your machine to a remote computer so that you can log in to both machines at the same time. cu enables you to transfer files or execute commands on either machine without dropping the initial link. See the cu(1C) man page for details.
Lets you copy a file from one machine to another. uucp creates work files and data files, queues the job for transfer, and calls the uucico daemon, which in turn attempts to contact the remote computer. See the uucp(1C) man page for details.
Copies files from the local machine to the public spool directory /var/spool/uucppublic/receive on the remote machine. Unlike uucp, which lets you copy a file to any accessible directory on the remote machine, uuto places the file in an appropriate spool directory and tells the remote user to pick it up with uupick. See the uuto(1C) man page for details.
Retrieves files in /var/spool/uucppublic/receive when files are transferred to a computer by using uuto. See the uuto(1C) man page.
Creates the work, data, and execute files that are needed to execute commands on a remote machine. See the uux(1C) man page for details.
Displays the status of requested transfers (uucp, uuto, or uux). uustat also provides a means of controlling queued transfers. See the uustat(1C) man page for details.
A major part of UUCP setup is the configuration of the files that compose the UUCP database. These files are in the /etc/uucp directory. You need to edit these files to set up UUCP or asppp on your machine. The files include the following:
Contains a list of variable parameters. You can manually set these parameters to configure the network.
Contains dial-code abbreviations that can be used in the phone number field of Systems file entries. Though not required, Dialcodes can be used by asppp as well as UUCP.
Contains character strings that are required to negotiate with modems to establish connections with remote computers. Dialers is used by asppp as well as UUCP.
Defines job grades, and the permissions that are associated with each job grade, which users can specify to queue jobs to a remote computer.
Defines the maximum number of simultaneous uucicos, uuxqts, and uuscheds that are permitted on your machine.
Defines the level of access that is granted to remote hosts that attempt to transfer files or execute commands on your machine.
Defines machines that are to be polled by your system and when they are polled.
Assigns different or multiple files to be used by uucico and cu as Systems, Devices, and Dialers files.
Enables you to define a unique UUCP name for a machine, in addition to its TCP/IP host name.
Contains information that is needed by the uucico daemon, cu, and asppp to establish a link to a remote computer. This information includes the name of the remote host, the name of the connecting device associated with the remote host, time when the host can be reached, telephone number, login ID, and password.
Several other files can be considered part of the supporting database but are not directly involved in establishing a link and transferring files.
The UUCP database consists of the files that are shown in UUCP Database Files. However, basic UUCP configuration involves only the following critical files:
/etc/uucp/Systems
/etc/uucp/Devices
/etc/uucp/Dialers
Because asppp uses some of the UUCP databases, you should understand at minimum these critical database files if you plan to configure asppp. After these databases are configured, UUCP administration is fairly straightforward. Typically, you edit the Systems file first, then edit the Devices file. You can usually use the default /etc/uucp/Dialers file, unless you plan to add dialers that aren't in the default file. In addition, you might also want to use the following files for basic UUCP and asppp configuration:
/etc/uucp/Sysfiles
/etc/uucp/Dialcodes
/etc/uucp/Sysname
Because these files work closely with one another, you should understand all their contents before you change any one of them. A change to an entry in one file might require a change to a related entry in another file. The remaining files that are listed in UUCP Database Files are not as critically intertwined.
asppp uses only the files that are described in this section. asppp does not use the other UUCP database files.
This chapter explains how to start UUCP operations after you have modified the database file relevant to your machines. The chapter contains procedures and troubleshooting information for setting up and maintaining UUCP on machines that run the Solaris environment, such as the following:
The following table provides pointers to the procedures that are covered in this chapter, in addition to a short description of each procedure.
Table 35–1 Task Map: UUCP Administration
Task |
Description |
For Instructions |
Allow remote machines to have access to your system |
Edit the /etc/passwd file to add entries to identify the machines that are permitted to access your system. | |
Start UUCP |
Use the supplied shell scripts to start UUCP. | |
Enable UUCP to work with TCP/IP |
Edit /etc/inetd.conf and /etc/uucp/Systems files to activate UUCP for TCP/IP. | |
Troubleshoot some common UUCP problems |
Diagnostic steps to use to check for faulty modems or ACUs. Diagnostic steps to use for debugging transmissions. |
For incoming UUCP (uucico) requests from remote machines to be handled properly, each machine has to have a login on your system.
To allow a remote machine to access your system, you need to add an entry to the /etc/passwd file as follows:
Edit the /etc/passwd file and add the entry to identify the machine that is permitted to access your system.
A typical entry that you might put into the /etc/passwd file for a remote machine that is permitted to access your system with a UUCP connection would be as follows:
Ugobi:*:5:5:gobi:/var/spool/uucppublic:/usr/lib/uucp/uucico |
By convention, the login name of a remote machine is the machine name preceded by the uppercase letter U. Note that the name should not exceed eight characters, so that in some situations you might have to truncate or abbreviate it.
The previous entry shows that a login request by Ugobi is answered by /usr/lib/uucp/uucico. The home directory is /var/spool/uucppublic. The password is obtained from the /etc/shadow file. You must coordinate the password and the login name with the UUCP administrator of the remote machine. The remote administrator must then add an appropriate entry, with login name and unencrypted password, in the remote machine's Systems file.
Coordinate your machine name with the UUCP administrators on other systems.
Similarly, you must coordinate your machine's name and password with the UUCP administrators of all machines that you want to reach through UUCP.
UUCP includes four shell scripts that poll remote machines, reschedule transmissions, and clean up old log files and unsuccessful transmissions. The scripts are as follows:
uudemon.poll
uudemon.hour
uudemon.admin
uudemon.cleanup
These shell scripts should execute regularly to ensure that UUCP runs smoothly. The crontab file to run the scripts is automatically created in /usr/lib/uucp/uudemon.crontab as part of the Solaris installation process, if you select the full installation. Otherwise, the file is created when you install the UUCP package.
You can also run the UUCP shell scripts manually. The following is the prototype uudemon.crontab file that you can tailor for a particular machine:
# #ident "@(#)uudemon.crontab 1.5 97/12/09 SMI" # # This crontab is provided as a sample. For systems # running UUCP edit the time schedule to suit, uncomment # the following lines, and use crontab(1) to activate the # new schedule. # #48 8,12,16 * * * /usr/lib/uucp/uudemon.admin #20 3 * * * /usr/lib/uucp/uudemon.cleanup #0 * * * * /usr/lib/uucp/uudemon.poll #11,41 * * * * /usr/lib/uucp/uudemon.hour |
By default, UUCP operations are disabled. To enable UUCP, edit the time schedule and uncomment the appropriate lines in the uudemon.crontab file.
To activate the uudemon.crontab file, do the following:
Become superuser.
Edit the /usr/lib/uucp/uudemon.crontab file and change entries as required.
Activate the uudemon.crontab file by issuing the following command:
crontab < /usr/lib/uucp/uudemon.crontab |
The default uudemon.poll shell script reads the /etc/uucp/Poll file once an hour. If any machines in the Poll file are scheduled to be polled, a work file (C.sysnxxxx) is placed in the /var/spool/uucp/nodename directory, where nodename represents the UUCP node name of the machine.
The shell script is scheduled to run once an hour, before uudemon.hour, so that the work files are in place when uudemon.hour is called.
The default uudemon.hour shell script does the following:
Calls the uusched program to search the spool directories for work files (C.) that have not been processed. The script then schedules these files for transfer to a remote machine.
Calls the uuxqt daemon to search the spool directories for execute files (X.) that have been transferred to your computer and were not processed at the time they were transferred.
By default, uudemon.hour runs twice an hour. You might want it to run more often if you expect high failure rates of calls to remote machines.
The default uudemon.admin shell script does the following:
Runs the uustat command with p and q options. The q reports on the status of work files (C.), data files (D.), and execute files (X.) that are queued. The p prints process information for networking processes that are listed in the lock files (/var/spool/locks).
Sends resulting status information to the uucp administrative login by using mail.
The default uudemon.cleanup shell script does the following:
Collects log files for individual machines from the /var/uucp/.Log directory, merges them, and places them in the /var/uucp/.Old directory with other old log information
Removes work files (C.) seven days old or older, data files (D.) seven days old or older, and execute files (X.) two days old or older from the spool files
Returns mail that cannot be delivered to the sender
Mails a summary of the status information that was gathered during the current day to the UUCP administrative login (uucp)
To run UUCP on a TCP/IP network, you need to make a few modifications, as described in this section.
Edit the /etc/inetd.conf file and ensure that the following entry is not preceded by a comment mark (#):
uucp stream tcp nowait root /usr/sbin/in.uucpd in.uucpd |
Edit the /etc/uucp/Systems file to ensure that the entries have the following fields :
System-Name Time TCP Port networkname Standard-Login-Chat
A typical entry would resemble the following:
rochester Any TCP - ur-seneca login: Umachine password: xxx |
Notice that the networkname field permits you to specify explicitly the TCP/IP host name. This is important for some sites. In the previous example, the site has the UUCP node name rochester, which is different from its TCP/IP host name ur-seneca. Moreover, a completely different machine could easily run UUCP and have the TCP/IP host name of rochester.
The Port field in the Systems file should have the entry -. This syntax is equivalent to listing the entry as uucp. In almost every situation, the networkname is the same as the system name, and the Port field is -, which says to use the standard uucp port from the services database. The in.uucpd daemon expects the remote machine to send its login and password for authentication, and in.uucpd prompts for them, much as getty and login do.
Edit the /etc/inet/services file to set up a port for UUCP:
uucp 540/tcp uucpd # uucp daemon |
You should not have to change the entry. However, if your machine runs NIS or NIS+ as its name service, you should change the /etc/nsswitch.conf entry for /etc/services to check files first, then check nis or nisplus.
After you have set up UUCP, maintenance is straightforward. This section explains ongoing UUCP tasks that relate to security, maintenance, and troubleshooting.
The default /etc/uucp/Permissions file provides the maximum amount of security for your UUCP links. The default Permissions file contains no entries.
You can set additional parameters for each remote machine to define the following:
Ways the remote machine can receive files from your machine
Directories for which the remote machine has read and write permission
Commands the remote machine can use for remote execution
A typical Permissions entry follows:
MACHINE=datsun LOGNAME=Udatsun VALIDATE=datsun COMMANDS=rmail REQUEST=yes SENDFILES=yes |
This entry allows files to be sent and received to and from the “normal” UUCP directories, not from anywhere in the system. The entry also causes the UUCP user name to be validated at login time.
UUCP does not require much maintenance. Except for ensuring that the crontab file is in place, as described in the section How to Start UUCP, your concern should be the growth of mail files and the public directory.
All email messages that are generated by the UUCP programs and scripts are sent to the user ID uucp. If you do not log in frequently as that user, you might not realize that mail is accumulating (and consuming disk space). To solve this problem, create an alias in /etc/mail/aliases and redirect that email either to root or to yourself and others responsible for maintaining UUCP. Remember to run the newaliases command after modifying the aliases file.
The directory /var/spool/uucppublic is the one place in every system to which UUCP by default is able to copy files. Every user has permission to change to /var/spool/uucppublic and read and write files in it. However, its sticky bit is set, so its mode is 01777. As a result, users cannot remove files that have been copied to it and that belong to uucp. Only you, as UUCP administrator logged in as root or uucp, can remove files from this directory. To prevent the uncontrolled accumulation of files in this directory, you should ensure that you remove files from it periodically.
If this maintenance is inconvenient for users, encourage them to use uuto and uupick rather than removing the sticky bit, which is set for security reasons. See the uuto(1C) man page for instructions for using uuto and uupick. You can also restrict the mode of the directory to only one group of people. If you do not want to run the risk of someone filling your disk, you can even deny UUCP access to it.
These procedures describe how to solve common UUCP problems.
You can check if the modems or other ACUs are not working properly in several ways.
Obtain counts and reasons for contact failure by running the following command:
# uustat -q |
Call over a particular line and print debugging information on the attempt.
The line must be defined as direct in the /etc/uucp/Devices file. (You must add a telephone number to the end of the command line if the line is connected to an autodialer or the device must be set up as direct.) Type:
# cu -d -lline |
line is /dev/cua/a.
If you cannot contact a particular machine, you can check out communications to that machine with Uutry and uucp.
# /usr/lib/uucp/Uutry -r machine |
Replace machine with the host name of the machine you are having problems contacting. This command does the following:
Starts the transfer daemon (uucico) with debugging. You can get more debugging information if you are root.
Directs the debugging output to /tmp/machine.
Prints the debugging output to your terminal by issuing the following command:
# tail -f |
Press Control-c to end output. You can copy the output from /tmp/machine if you want to save it.
If Uutry doesn't isolate the problem, try to queue a job:
# uucp -r file machine\!/dir/file |
Replace file by the file you want to transfer, machine by the machine you want to copy to, and /dir/file where the file will be placed on the other machine. The r option queues a job but does not start the transfer.
Issue the following command:
# Uutry |
If you still cannot solve the problem, you might need to call your local support representative. Save the debugging output. It can help diagnose the problem.
You might also decrease or increase the level of debugging that is provided by Uutry through the -x n option. n indicates the debug level. The default debug level for Uutry is 5.
Debug level 3 provides basic information about when and how the connection is established, but not much information about the transmission itself. Debug level 9, however, provides exhaustive information about the transmission process. Be aware that debugging occurs at both ends of the transmission. If you intend to use a level higher than 5 on a moderately large text, contact the administrator of the other site and agree on a time for doing so.
Verify that you have up-to-date information in your Systems file if you are having trouble contacting a particular machine. Some information that might be out of date for a machine are the following:
UUCP has two types of error messages: ASSERT and STATUS.
When a process is aborted, ASSERT error messages are recorded in /var/uucp/.Admin/errors. These messages include the file name, sccsid, line number, and text. These messages usually result from system problems.
STATUS error messages are stored in the /var/uucp/.Status directory. The directory contains a separate file for each remote machine your computer attempts to communicate with. These files contain status information on the attempted communication and whether it was successful.
Several commands are available for checking basic networking information:
Use the uuname command to list those machines your machine can contact.
Use the uulog command to display the contents of the log directories for particular hosts.
Use the uucheck -v command to check for the presence of files and directories that are needed by uucp. This command also checks the Permissions file and outputs information on the permissions you have set up.
This chapter provides reference information for working with UUCP. The following topics are covered:
The /etc/uucp/Systems file contains the information that is needed by the uucico daemon to establish a communication link to a remote computer. /etc/uucp/Systems is the first file you need to edit to configure UUCP.
Each entry in the Systems file represents a remote computer with which your host communicates. A particular host can have more than one entry. The additional entries represent alternative communication paths that are tried in sequential order. In addition, by default UUCP prevents any computer that does not appear in /etc/uucp/Systems from logging in to your host.
Using the Sysfiles file, you can define several files to be used as Systems files. See UUCP /etc/uucp/Sysfiles File for a description of Sysfiles.
Each entry in the Systems file has the following format:
System-Name |
Time |
Type |
Speed |
Phone |
Chat Script |
The following example shows the fields of the Systems file.
System-Name Time Type Speed Phone Chat Script Arabian Any ACUEC 38400 111222 Login: Puucp ssword:beledi |
This field contains the node name of the remote computer. On TCP/IP networks, this name can be the machine's host name or a name that is created specifically for UUCP communications through the /etc/uucp/Sysname file. See UUCP /etc/uucp/Systems File. In Example 36–1, the System-Name field contains an entry for remote host arabian.
This field specifies the day of week and time of day when the remote computer can be called. The format of the Time field follows:
daytime[;retry]
The day portion can be a list that contains some of the following entries.
Table 36–1 Day Field
For individual days. |
For any weekday. |
For any day. |
Your host never initiates a call to the remote computer. The call must be initiated by the remote computer. Your host is then operating in passive mode. |
Example 36–1 shows Any in the Time field, which indicates that host arabian can be called at any time.
The time portion should be a range of times that are specified in 24-hour notation, for example, 0800-1230 for 8:30 a.m. to 12:30 p.m. If no time portion is specified, any time of day is assumed to be allowed for the call.
A time range that spans 0000 is permitted. For example, 0800-0600 means all times are allowed other than times between 6 a.m. and 8 a.m.
The Retry subfield enables you to specify the minimum time (in minutes) before a retry, following a failed attempt. The default wait is 60 minutes. The subfield separator is a semicolon (;). For example, Any;9 is interpreted as call any time, but wait at least 9 minutes before retrying after a failure occurs.
If you do not specify a retry entry, an exponential back-off algorithm is used. This means that UUCP starts with a default wait time that grows larger as the number of failed attempts increases. For example, suppose the initial retry time is 5 minutes. If no response occurs, the next retry is 10 minutes later. The next retry is 20 minutes later, and so on until the maximum retry time of 23 hours is reached. If retry is specified, that is always the retry time. Otherwise, the back-off algorithm is used.
This field contains the device type that should be used to establish the communication link to the remote computer. The keyword that is used in this field is matched against the first field of Devices file entries.
File Name System-Name Time Type Speed Phone Chat Script Systems arabian Any ACUEC, g 38400 1112222 ogin: Puucp ssword:beledi |
You can define the protocol that is used to contact the system by adding it on to the Type field. The previous example shows how to attach the protocol g to the device type ACUEC. For information on protocols, see UUCP Protocol Definitions in the Devices File.
This field (also known as the Class field) specifies the transfer speed of the device that is used in establishing the communication link. The UUCP speed field can contain a letter and speed (for example, C1200, D1200) to differentiate between classes of dialers (refer to UUCP Class Field).
Some devices can be used at any speed, so the keyword Any can be used. This field must match the Class field in the associated Devices file entry.
File Name System-Name Time Type Speed Phone Chat Script Systems eagle Any ACU, g D1200 NY3251 ogin: nuucp ssword: Oakgrass |
If information is not required for this field, use a dash (-) as a placeholder for the field.
This field enables you to specify the telephone number (token) of the remote computer for automatic dialers (port selectors). The telephone number consists of an optional alphabetic abbreviation and a numeric part. If an abbreviation is used, it must be one that is listed in the Dialcodes file.
File Name System-Name Time Type Speed Phone Chat Script Systems nubian Any ACU 2400 NY5551212 ogin: Puucp ssword:Passuan |
In the System-Name string, an equals sign (=) tells the ACU to wait for a secondary dial tone before dialing the remaining digits. A dash (-) in the string instructs the ACU to pause four seconds before dialing the next digit.
If your computer is connected to a port selector, you can access other computers that are connected to that selector. The Systems file entries for these remote machines should not have a telephone number in the Phone field. Instead, this field should contain the token to be passed on to the switch. In this way, the port selector knows the remote machine with which your host wants to communicate, usually just the system name. The associated Devices file entry should have a \D at the end of the entry to ensure that this field is not translated by using the Dialcodes file.
This field (also called the Login field) contains a string of characters that is called a chat-script. The chat-script contains the characters the local and remote machines must pass to each other in their initial conversation. Chat-scripts have the following format:
expect send [expect send] ....
expect represents the string that the local host expects to receive from the remote host to initiate conversation. send is the string the local host sends after it receives the expect string from the remote host. A chat-script can have more than one expect-send sequence.
A basic chat-script might contain the following:
Login prompt that the local host expects to receive from the remote machine
Login name that the local host sends to the remote machine in order to log in
Password prompt that the local host expects to receive from the remote machine
Password that the local host sends to the remote machine
The expect field can be composed of subfields of the following form:
expect[-send-expect]...
send is sent if the prior expect is not successfully read, and the -expect that follows the send is the next expected string.
For example, with strings login--login, the UUCP on the local host expects login. If UUCP receives login from the remote machine, it goes to the next field. If it does not receive login, it sends a carriage return, then looks for login again. If the local computer initially does not expect any characters, use the characters "" (NULL string) in the expect field. All send fields are sent with a carriage return appended unless the send string is terminated with a \c.
Here is an example of a Systems file entry that uses an expect-send string:
System-Name Time Type Speed Phone Chat Script sonora Any ACUEC 9600 2223333 "" \r \r ogin:-BREAK-ogin: Puucpx ssword: xyzzy |
This example tells UUCP on the local host to send two carriage returns and wait for ogin: (for Login:). If ogin: is not received, send a BREAK. When you do receive ogin: send the login name Puucpx. When you receive ssword: (for Password:), send the password xyzzy.
The following table lists some useful escape characters.
Table 36–2 Escape Characters Used in Systems File Chat ScriptEscape Character | Meaning |
Sends or expects a backspace character. |
If at the end of a string, suppresses the carriage return that is normally sent. Ignored otherwise. |
Delays 1–3 seconds before sending more characters. |
Starts echo checking. From this point on, whenever a character is transmitted, UUCP waits for the character to be received before continuing its checks. |
Echoes check-off. |
Ignores one hangup. Use this option for dialback modems. |
Sends a BREAK character. |
Turns on CLOCAL flag. |
Turns off CLOCAL flag. |
Sends or expects a newline character. |
Sends a NULL character (ASCII NUL). |
Pauses for approximately 1/4 to 1/2 second. |
Sends or expects a carriage return. |
Sends or expects a space character. |
Sends or expects a tab character. |
Sends an EOT, followed by newline twice. |
Sends a break character. |
Sends or expects the character that is represented by the octal digits (ddd). |
Some companies set up dial-in servers to handle calls from remote computers. For example, your company might have a dial-in server with a dialback modem that employees can call from their home computers. After the dial-in server identifies the remote machine, it disconnects the link to the remote machine and then calls back the remote machine. The communications link is then reestablished.
You can facilitate dialback by using the \H option in the Systems file chat-script at the place where dialback should occur. Include the \H as part of an expect string at the place where the dial-in server is expected to hang up.
For example, suppose the chat-script that calls a dial-in server contains the following string:
INITIATED\Hogin: |
The UUCP dialing facility on the local machine expects to receive the characters INITIATED from the dial-in server. After the INITIATED characters have been matched, the dialing facility flushes any subsequent characters it receives until the dial-in server hangs up. The local dialing facility then waits until it receives the next part of the expect string, the characters ogin:, from the dial-in server. When it receives the ogin:, the dialing facility then continues through the chat-script.
You need not to have a string of characters directly preceding or following the \H, as shown in the previous sample string.
You can also use the pseudo-send STTY=value string to set modem characteristics. For instance, STTY=crtscts enables hardware flow control. STTY accepts all stty modes. See the stty(1) and termio(7I) man pages for complete details.
The following example would enable hardware flow control in a Systems file entry:
System-Name Time Type Speed Phone Chat Script unix Any ACU 2400 12015551212 "" \r login:-\r-login:-\r-login: nuucp password: xxx "" \ STTY=crtscts |
This pseudo-send string can also be used in entries in the Dialers file.
In some situations, you have to reset the parity because the system that you are calling checks port parity and drops the line if it is wrong. The expect-send couplet "" P_ZERO sets the high-order bit (parity bit) to 0. For example:
System-Name Time Type Speed Phone Chat Script unix Any ACU 2400 12015551212 "" P_ZERO "" \r login:-\r-login:-\r-login: nuucp password: xxx |
In the same manner, P_EVEN sets parity to even (the default), P_ODD sets odd parity, and P_ONE sets the parity bit to 1.
The parity couplet can be inserted anywhere in the chat-script. The couplet applies to all information in the chat-script that follows the "" P_ZERO. The couplet can also be used in entries in the Dialers file.
The /etc/uucp/Devices file contains information for all the devices that can be used to establish a link to a remote computer. These devices include ACUs—which includes modern, high-speed modems—direct links, and network connections.
Here is an entry in /etc/uucp/Devices for a US Robotics V.32bis modem that is attached to port A and running at 38,400 bps.
Type Line Line2 Class Dialer-Token-Pairs ACUEC cua/a - 38400 usrv32bis-ec |
Each field is described in the next section.
This field describes the type of link that the device establishes. The UUCP Type field can contain one of the keywords that is described in the sections that follow.
The Direct keyword appears mainly in entries for cu connections. This keyword indicates that the link is a direct link to another computer or a port selector. Create a separate entry for each line that you want to reference through the -l option of cu.
The ACU keyword indicates that the link to a remote computer (whether through cu, UUCP, asppp, or Solaris PPP 4.0) is made through a modem. This modem can be connected either directly to your computer or indirectly through a port selector.
This is a variable that is replaced in the Type field by the name of a port selector. Port selectors are devices that are attached to a network that prompts for the name of a calling modem, then grant access. The file /etc/uucp/Dialers contains caller scripts only for the micom and develcon port selectors. You can add your own port selector entries to the Dialers file. See UUCP /etc/uucp/Dialers File for more information.
This variable is replaced by the name of a machine in the Type field, indicating that the link is a direct link to this particular computer. This naming scheme is used to associate the line in this Devices entry with an entry in /etc/uucp/Systems for the computer Sys-Name.
Example 36–5 shows a comparison between the fields in /etc/uucp/Devices and fields in /etc/uucp/Systems. The titles of each column apply only to fields in the Devices file.
The keyword that is used in the Type field of the Devices file is matched against the third field of the Systems file entries. In the Devices file, the Type field has the entry ACUEC, indicating an automatic call unit, in this instance a V.32bis modem. This value is matched against the third field in the Systems file, which also contains the entry ACUEC. See UUCP /etc/uucp/Systems File for more information.
File Name Type Line Line2 Class Dialer-Token-Pairs Devices ACUEC cua/a - 38400 usrv32bis-ec System nubian Any ACUEC 38400 9998888 ““ \d\d\r\n\c-ogin-\r\n\c-ogin....... |
This field contains the device name of the line (port) that is associated with the Devices entry. If the modem that is associated with a particular entry were attached to the /dev/cua/a device (serial port A), the name that is entered in this field would be cua/a. An optional modem control flag, M, can be used in the Line field to indicate that the device should be opened without waiting for a carrier. For example:
cua/a,M |
This field is a placeholder. Always use a dash (-) here. 801–type dialers, which are not supported in the Solaris environment, use the Line2 field. Non-801 dialers do not normally use this configuration, but still require a hyphen in this field.
The Class field contains the speed of the device, if the keyword ACU or Direct is used in the Type field. However, the Class field can contain a letter and a speed (for example, C1200, D1200) to differentiate between classes of dialers (Centrex or Dimension PBX).
This differentiation is necessary because many larger offices can have more than one type of telephone network: one network might be dedicated to serving only internal office communications while another handles the external communications. In such a situation, you must distinguish which line(s) should be used for internal communications and which should be used for external communications.
The keyword that is used in the Class field of the Devices file is matched against the Speed field of Systems file.
File Name Type Line Line2 Class Dialer-Token-Pairs Devices ACU cua/a - D2400 hayes |
Some devices can be used at any speed, so the keyword Any can be used in the Class field. If Any is used, the line matches any speed that is requested in the Speed field of the Systems file. If this field is Any and the Systems file Speed field is Any, the speed defaults to 2400 bps.
The Dialer-Token-Pairs (DTP) field contains the name of a dialer and the token to pass it. The DTP field has this syntax:
dialer token [dialer token]
The dialer portion can be the name of a modem, a port monitor, or it can be direct or uudirect for a direct-link device. You can have any number of dialer-token pairs. If the dialer portion is not present, it is taken from a related entry in the Systems file. The token portion can be supplied immediately after the dialer portion.
The last dialer-token pair might not be present, depending on the associated dialer. In most situations, the last pair contains only a dialer portion. The token portion is retrieved from the Phone field of the associated Systems file entry.
A valid entry in the dialer portion can be defined in the Dialers file or can be one of several special dialer types. These special dialer types are compiled into the software and are therefore available without having entries in the Dialers file. The following table shows the special dialer types.
Table 36–3 Dialer-Token Pairs
TCP/IP network |
Transport Level Interface Network (without STREAMS) |
Transport Level Interface Network (with STREAMS) |
See UUCP Protocol Definitions in the Devices File for more information.
The DTP field can be structured four different ways, depending on the device that is associated with the entry:
Directly connected modem
If a modem is connected directly to a port on your computer, the DTP field of the associated Devices file entry has only one pair. This pair would normally be the name of the modem. This name is used to match the particular Devices file entry with an entry in the Dialers file. Therefore, the Dialer field must match the first field of a Dialers file entry.
Dialers hayes =,-, "" \\dA\pTE1V1X1Q0S2=255S12=255\r\c \EATDT\T\r\c CONNECT |
Notice that only the dialer portion (hayes) is present in the DTP field of the Devices file entry. This means that the token to be passed on to the dialer (in this instance, the phone number) is taken from the Phone field of a Systems file entry. (\T is implied, as described in Example 36–9.)
Direct link – For a direct link to a particular computer, the DTP field of the associated entry would contain the keyword direct. This is true for both types of direct-link entries, Direct and Sys-Name (refer to UUCP Type Field).
Computers on the same port selector – If a computer with which you intend to communicate is on the same port selector switch as your computer, your computer must first access the switch. The switch then makes the connection to the other computer. This type of entry has only one pair. The dialer portion is used to match a Dialers file entry.
Dialers develcon ,"" "" \pr\ps\c est:\007 \E\D\e \007 |
As shown, the token portion is left blank. This designation indicates that it is retrieved from the Systems file. The Systems file entry for this computer contains the token in the Phone field, which is normally reserved for the phone number of the computer. Refer to UUCP /etc/uucp/Systems File for details. This type of DTP contains an escape character (\D), which ensures that the contents of the Phone field are not interpreted as a valid entry in the Dialcodes file.
Modems that are connected to port selector – If a high-speed modem is connected to a port selector, your computer must first access the port selector switch. The switch makes the connection to the modem. This type of entry requires two dialer-token-pairs. The dialer portion of each pair (fifth and seventh fields of entry) is used to match entries in the Dialers file, as shown below.
Dialers develcon "" "" \pr\ps\c est:\007 \E\D\e \007 Dialers ventel =&-% t"" \r\p\r\c $ <K\T%\r>\c ONLINE! |
In the first pair, develcon is the dialer and vent is the token that is passed to the Develcon switch to tell it which device (such as Ventel modem) to connect to your computer. This token is unique for each port selector, as each switch can be set up differently. After the Ventel modem has been connected, the second pair is accessed. Ventel is the dialer and the token is retrieved from the Systems file.
Two escape characters can appear in a DTP field:
\T – Indicates that the Phone (token) field should be translated by using the /etc/uucp/Dialcodes file. This escape character is normally placed in the /etc/uucp/Dialers file for each caller script that is associated with a modem (Hayes, US Robotics, and so on). Therefore, the translation does not occur until the caller script is accessed.
\D – Indicates that the Phone (token) field should not be translated by using the /etc/uucp/Dialcodes file. If no escape character is specified at the end of a Devices entry, the \D is assumed (default). A \D is also used in the /etc/uucp/Dialers file with entries that are associated with network switches (develcon and micom).
You can define the protocol to use with each device in /etc/uucp/Devices. This specification is usually unnecessary because you can use the default or define the protocol with the particular system you are calling. Refer to UUCP /etc/uucp/Systems File for details. If you do specify the protocol, you must use the following form:
Type,Protocol [parameters]
For example, you can use TCP,te to specify the TCP/IP protocol.
The following table shows the available protocols for the Devices file.
Table 36–4 Protocols Used in /etc/uucp/Devices
Protocol |
Description |
This protocol is commonly used for transmissions over TCP/IP and other reliable connections. t assumes error-free transmissions. |
This protocol is UUCP's native protocol. It is slow, reliable, and good for transmission over noisy telephone lines. |
This protocol assumes transmission over error-free channels that are message oriented (as opposed to byte-stream oriented, such as TCP/IP). |
This protocol is used for transmission over X.25 connections. f relies on flow control of the data stream, and is meant for working over links that can (almost) be guaranteed to be error-free, specifically X.25/PAD links. A checksum is enacted over a whole file only. If a transport fails, the receiver can request retransmission(s). |
Here is an example that shows a protocol designation for a device entry:
TCP,te - - Any TCP - |
This example indicates that, for device TCP, you should try to use the t protocol. If the other end refuses, use the e protocol.
Neither e nor t is appropriate for use over modems. Even if the modem assures error-free transmission, data can still be dropped between the modem and the CPU.
The /etc/uucp/Dialers file contains dialing instructions for many commonly used modems. You probably do not need to change or add entries to this file unless you plan to use a nonstandard modem or plan to customize your UUCP environment. Nevertheless, you should understand what is in the file and how it relates to the Systems and Devices file.
The text specifies the initial conversation that must occur on a line before it can be made available for transferring data. This conversation, often referred to as a chat-script, is usually a sequence of ASCII strings that is transmitted and expected, and it is often used to dial a phone number.
As shown in the examples in UUCP /etc/uucp/Devices File, the fifth field in a Devices file entry is an index into the Dialers file or a special dialer type (TCP, TLI, or TLIS). The uucico daemon attempts to match the fifth field in the Devices file with the first field of each Dialers file entry. In addition, each odd-numbered Devices field, starting with the seventh position, is used as an index into the Dialers file. If the match succeeds, the Dialers entry is interpreted to perform the dialer conversation.
Each entry in the Dialers file has the following format:
dialer |
substitutions |
expect-send |
The following example shows the entry for a US Robotics V.32bis modem.
Dialer Substitution Expect-Send usrv32bis-e =,-, "" dA\pT&FE1V1X1Q0S2=255S12=255&A1&H1&M5&B2&W\r\c OK\r \EATDT\T\r\c CONNECT\s14400/ARQ STTY=crtscts |
The Dialer field matches the fifth and additional odd-numbered fields in the Devices file. The Substitutions field is a translate string: the first of each pair of characters is mapped to the second character in the pair. This mapping is usually used to translate = and - into whatever the dialer requires for “wait for dial tone” and “pause.”
The remaining expect-send fields are character strings.
The following example shows some sample entries in the Dialers file, as distributed when you install UUCP as part of the Solaris installation program.
penril =W-P "" \d > Q\c : \d- > s\p9\c )-W\p\r\ds\p9\c-) y\c : \E\TP > 9\c OK ventel =&-% "" \r\p\r\c $ <K\T%%\r>\c ONLINE! vadic =K-K "" \005\p *-\005\p-*\005\p-* D\p BER? \E\T\e \r\c LINE develcon "" "" \pr\ps\c est:\007 \E\D\e \n\007 micom "" "" \s\c NAME? \D\r\c GO hayes =,-, "" \dA\pTE1V1X1Q0S2=255S12=255\r\c OK\r \EATDT\T\r\c CONNECT # Telebit TrailBlazer tb1200 =W-, "" \dA\pA\pA\pTE1V1X1Q0S2=255S12=255S50=2\r\c OK\r \EATDT\T\r\c CONNECT\s1200 tb2400 =W-, "" \dA\pA\pA\pTE1V1X1Q0S2=255S12=255S50=3\r\c OK\r \EATDT\T\r\c CONNECT\s2400 tbfast =W-, "" \dA\pA\pA\pTE1V1X1Q0S2=255S12=255S50=255\r\c OK\r \EATDT\T\r\c CONNECT\sFAST # USrobotics, Codes, and DSI modems dsi-ec =,-, "" \dA\pTE1V1X5Q0S2=255S12=255*E1*F3*M1*S1\r\c OK\r \EATDT\T\r\c CONNECT\sEC STTY=crtscts,crtsxoff dsi-nec =,-, "" \dA\pTE1V1X5Q0S2=255S12=255*E0*F3*M1*S1\r\c OK\r \EATDT\T\r\c CONNECT STTY=crtscts,crtsxoff usrv32bis-ec =,-, "" \dA\pT&FE1V1X1Q0S2=255S12=255&A1&H1&M5&B2&W\r\c OK\r \EATDT\T\r\c CONNECT\s14400/ARQ STTY=crtscts,crtsxoff usrv32-nec =,-, "" \dA\pT&FE1V1X1Q0S2=255S12=255&A0&H1&M0&B0&W\r\c OK\r \EATDT\T\r\c CONNECT STTY=crtscts,crtsxoff codex-fast =,-, "" \dA\pT&C1&D2*MF0*AA1&R1&S1*DE15*FL3S2=255S7=40S10=40*TT5&W\r\c OK\r \EATDT\T\r\c CONNECT\s38400 STTY=crtscts,crtsxoff tb9600-ec =W-, "" \dA\pA\pA\pTE1V1X1Q0S2=255S12=255S50=6\r\c OK\r \EATDT\T\r\cCONNECT\s9600 STTY=crtscts,crtsxoff tb9600-nec =W-, "" \dA\pA\pA\pTE1V1X1Q0S2=255S12=255S50=6S180=0\r\c OK\r \EATDT\T\r\c CONNECT\s9600 STTY=crtscts,crtsxoff |
The following table lists escape characters that are commonly used in the send strings in the Dialers file.
Table 36–5 Backslash Characters for /etc/uucp/Dialers
Character |
Description |
No newline or carriage return. |
Delays (approximately 2 seconds). |
\D |
Phone number or token without Dialcodes translation. |
Disables echo checking. |
Enables echo checking (for slow devices). |
Inserts a Break character. |
Sends newline. |
Sends octal number. Additional escape characters that can be used are listed in the section UUCP /etc/uucp/Systems File. |
Sends or expects a NULL character (ASCII NUL). |
Pauses (approximately 12–14 seconds). |
Returns. |
Phone number or token with Dialcodes translation. |
Here is a penril entry in the Dialers file:
penril =W-P "" \d > Q\c : \d- > s\p9\c )-W\p\r\ds\p9\c-) y\c : \E\TP > 9\c OK |
First, the substitution mechanism for the phone number argument is established so that any = is replaced with a W (wait for dial tone) and any - with a P (pause).
The handshake that is given by the remainder of the line works as listed:
"" – Waits for nothing (that is, proceed to the next step).
\d – Delays 2 seconds, then sends a carriage return.
> – Waits for a >.
Q\c – Sends a Q without a carriage return.
: – Expects a :.
\d- – Delays 2 seconds, sends a - and a carriage return.
> – Waits for a >.
s\p9\c – Sends an s, pauses, sends a 9 with no carriage return.
)-W\p\r\ds\p9\c-) – Waits for a ). If ) is not received, processes the string between the - characters as follows. Sends a W, pauses, sends a carriage return, delays, sends an s, pauses, sends a 9 without a carriage return, then waits for the ).
y\c – Sends a y with no carriage return.
: – Waits for a :.
\E\TP – Enables echo checking. From this point on, whenever a character is transmitted, UUCP waits for the character to be received before proceeding, and then, sends the phone number. The \T means to take the phone number that is passed as an argument. The \T applies the Dialcodes translation and the modem function translation that is specified by field 2 of this entry. Then sends a P and a carriage return.
> – Waits for a >.
9\c – Sends a 9 without a newline.
OK – Waits for the string OK.
You can also use the pseudo-send STTY=value string to set modem characteristics. For instance, STTY=crtscts enables outbound hardware flow control. STTY=crtsxoff enables inbound hardware flow control. STTY=crtscts,crtsxoff enables both outbound and inbound hardware flow control.
STTY accepts all the stty modes. See the stty(1) and termio(7I) man pages.
The following example would enable hardware flow control in a Dialers entry:
dsi =,–, "" \dA\pTE1V1X5Q0S2=255S12=255*E1*F3*M1*S1\r\c OK\r \EATDT\T\r\c CONNECT\sEC STTY=crtscts |
This pseudo-send string can also be used in entries in the Systems file.
In some situations, you have to reset the parity because the system that you are calling checks port parity and drops the line if it is wrong. The expect-send couplet P_ZERO sets parity to zero:
foo =,-, "" P_ZERO "" \dA\pTE1V1X1Q0S2=255S12=255\r\c OK\r\EATDT\T\r\c CONNECT |
In the same manner, P_EVEN sets parity to even (the default), P_ODD sets it to odd, and P_ONE sets it to one. This pseudo-send string can also be used in entries in the Systems file.
You can use files in this section in addition to the Systems, Devices, and Dialers file when doing basic UUCP configuration.
The /etc/uucp/Dialcodes file enables you to define dial-code abbreviations that can be used in the Phone field in the /etc/uucp/Systems file. You can use the Dialcodes files to provide additional information about a basic phone number that is used by several systems at the same site.
Each entry has the following format:
abbreviation dial-sequence
abbreviation represents the abbreviation that is used in the Phone field of the Systems file and dial-sequence represents the dial sequence that is passed to the dialer when that particular Systems file entry is accessed. The following table shows the correspondences between the two files.
Table 36–6 Correspondences Between Dialcodes and Systems Files
Field Names |
Dialcodes |
Abbreviation |
Dial-Sequence |
Systems |
System-Name |
Time |
Type |
Speed |
Phone |
Chat Script |
The following table contains sample entries in a Dialcodes file.
Table 36–7 Entries in the Dialcodes File
Abbreviation |
Dial-sequence |
NY |
1=212 |
jt |
9+847 |
In the first row, NY is the abbreviation to appear in the Phone field of the Systems file. For example, the Systems file might have the following entry:
NY5551212
When uucico reads NY in the Systems file, it searches the Dialcodes file for NY and obtains the dialing sequence 1=212. This is the dialing sequence needed for any phone call to New York City. This sequence includes the number 1, an “equal sign” (=) meaning pause and wait for a secondary dial tone, and the area code 212. uucico sends this information to the dialer, then returns to the Systems file for the remainder of the phone number, 5551212.
The entry jt 9=847- would work with a Phone field such as jt7867 in the Systems file. When uucico reads the entry that contains jt7867 in the Systems file, it sends the sequence 9=847-7867 to the dialer, if the token in the dialer-token pair is \T.
The /etc/uucp/Sysfiles file lets you assign different files to be used by uucp and cu as Systems, Devices, and Dialers files. For more information on cu, see the cu(1C) man page. You can use Sysfiles for the following:
Different Systems files so that requests for login services can be made to different addresses than uucp services.
Different Dialers files so that you can assign different handshaking for cu and uucp.
Multiple Systems, Dialers, and Devices files. The Systems file in particular can become large, making it more convenient to split it into several smaller files.
The format of the Sysfiles file is as follows:
service=w systems=x:x dialers=y:y devices=z:z |
w represents uucico, cu, or both commands separated by a colon. x represents one or more files to be used as the Systems file, with each file name separated by a colon and read in the order that is presented. y represents one or more files to be used as the Dialers file. z is one or more files to be used as the Devices file.
Each file name is assumed to be relative to the /etc/uucp directory, unless a full path is given.
The following sample, /etc/uucp/Sysfiles, defines a local Systems file (Local_Systems) in addition to the standard /etc/uucp/Systems file:
service=uucico:cu systems=Systems :Local_Systems |
When this entry is in /etc/uucp/Sysfiles, both uucico and cu first check in the standard /etc/uucp/Systems. If the system they are trying to call doesn't have an entry in that file, or if the entries in the file fail, then both commands check /etc/uucp/Local_Systems.
As specified in the previous entry, cu and uucico share the Dialers and Devices files.
When different Systems files are defined for uucico and cu services, your machine stores two different lists of Systems. You can print the uucico list by using the uuname command or the cu list by using the uuname -C command. The following is another example of the file, which shows that the alternate files are consulted first and the default files are consulted if necessary:
service=uucico systems=Systems.cico:Systems dialers=Dialers.cico:Dialers \ devices=Devices.cico:Devices service=cu systems=Systems.cu:Systems \ dialers=Dialers.cu:Dialers \ devices=Devices.cu:Devices |
Every machine that uses UUCP must have an identifying name, often referred to as the node name. This is the name that appears in the remote machine's /etc/uucp/Systems file, along with the chat-script and other identifying information. Normally, UUCP uses the same node name as is returned by the uname -n command, which is also used by TCP/IP.
You can specify a UUCP node name independent of the TCP/IP host name by creating the /etc/uucp/Sysname file. The file has a one-line entry that contains the UUCP node name for your system.
The /etc/uucp/Permissions file specifies the permissions that remote computers have for login, file access, and command execution. Some options restrict the remote computer's ability to request files and its ability to receive files that are queued by the local machine. Another option is available that specifies the commands that a remote machine can execute on the local computer.
Each entry is a logical line, with physical lines terminated by a backslash (\) to indicate continuation. Entries are composed of options that are delimited by blank space. Each option is a name-value pair in the following format:
name=value
Values can be colon-separated lists. No blank space is allowed within an option assignment.
Comment lines begin with a pound sign (#), and they occupy the entire line up to a newline character. Blank lines are ignored (even within multiple-line entries).
The types of Permissions file entries are as follows:
LOGNAME – Specifies the permissions that become effective when a remote computer logs in to (calls) your computer.
When a remote machine calls you, its identity is questionable unless it has a unique login and verifiable password.
MACHINE – Specifies permissions that become effective when your computer logs in to (calls) a remote computer.
LOGNAME entries contain a LOGNAME option and MACHINE entries contain a MACHINE option. One entry can contain both options.
When using the Permissions file to restrict the level of access that is granted to remote computers, you should consider the following:
All login IDs that are used by remote computers to log in for UUCP communications must appear in one and only one LOGNAME entry.
Any site that is called with a name that does not appear in a MACHINE entry, has the following default permissions or restrictions:
When a remote computer calls your computer and requests to receive a file, this request can be granted or denied. The REQUEST option specifies whether the remote computer can request to set up file transfers from your computer. The string REQUEST=yes specifies that the remote computer can request to transfer files from your computer. The string REQUEST=no specifies that the remote computer cannot request to receive files from your computer. REQUEST=no, the default value, is used if the REQUEST option is not specified. The REQUEST option can appear in either a LOGNAME entry (the remote computer calls you) or a MACHINE entry (you call remote computer).
When a remote computer calls your computer and completes its work, it can attempt to retrieve work your computer has queued for it. The SENDFILES option specifies whether your computer can send the work that is queued for the remote computer.
The string SENDFILES=yes specifies that your computer can send the work that is queued for the remote computer if it is logged in as one of the names in the LOGNAME option. This string is mandatory if you have entered Never in the Time field of /etc/uucp/Systems. This designation sets up your local machine in passive mode, but it is not allowed to initiate a call to this particular remote computer. See UUCP /etc/uucp/Systems File for more information.
The string SENDFILES=call specifies that files that are queued in your computer are sent only when your computer calls the remote computer. The call value is the default for the SENDFILES option. This option is only significant in LOGNAME entries because MACHINE entries apply when calls are sent to remote computers. If the option is used with a MACHINE entry, it is ignored.
This option enables you to designate a unique UUCP node name for your computer in addition to its TCP/IP host name, as returned by the hostname command. For instance, if you have unknowingly given your host the same name as that of some other system, you can set the MYNAME option of the Permissions file. Suppose that you want your organization to be known as widget. If all your modems are connected to a machine with the host name gadget, you can have an entry in gadget's Permissions file that reads as follows:
Now the system world can log in to the machine gadget as if it were logging in to widget. In order for machine world to know you also by the aliased name widget when you call it, you can have an entry that reads as follows:
MACHINE=world MYNAME=widget |
You can also use the MYNAME option for testing purposes, as it allows your machine to call itself. However, because this option could be used to mask the real identity of a machine, you should use the VALIDATE option, as described in UUCP VALIDATE Option.
These options specify the various parts of the file system that uucico can read from or write to. You can designate READ and WRITE options with either MACHINE or LOGNAME entries.
The default for both the READ and WRITE options is the uucppublic directory, as shown in the following strings:
READ=/var/spool/uucppublic WRITE=/var/spool/uucppublic |
The strings READ=/ and WRITE=/ specify permission to access any file that can be accessed by a local user with Other permissions.
The value of these entries is a colon-separated list of path names. The READ option is for requesting files, and the WRITE option is for depositing files. One of the values must be the prefix of any full path name of a file entering or exiting. To grant permission to deposit files in /usr/news as well as the public directory, use the following values with the WRITE option:
WRITE=/var/spool/uucppublic:/usr/news |
If the READ and WRITE options are used, all path names must be specified because the path names are not added to the default list. For instance, if the /usr/news path name were the only path specified in a WRITE option, permission to deposit files in the public directory would be denied.
Be careful which directories you make accessible for reading and writing by remote systems. For example, the /etc directory contains many critical system files. Remote users should not have permission to deposit files in this directory.
The NOREAD and NOWRITE options specify exceptions to the READ and WRITE options or defaults. The following entry permits reading any file except those files in the /etc directory (and its subdirectories—remember, these options are prefixes).
READ=/ NOREAD=/etc WRITE=/var/spool/uucppublic |
This entry permits writing only to the default /var/spool/uucppublic directory. NOWRITE works in the same manner as the NOREAD option. You can use the NOREAD and NOWRITE options in both LOGNAME and MACHINE entries.
You can use the CALLBACK option in LOGNAME entries to specify that no transaction occurs until the calling system is called back. The reasons to set up CALLBACK are as follows:
For security purposes – If you call back a machine, you can be sure it is the right machine.
For accounting purposes – If you are doing long data transmissions, you can choose the machine that is billed for the longer call.
The string CALLBACK=yes specifies that your computer must call back the remote computer before any file transfers can occur.
The default for the CALLBACK option is CALLBACK=no. If you set CALLBACK to yes, the permissions that affect the rest of the conversation must be specified in the MACHINE entry that corresponds to the caller. Do not specify these permissions in the LOGNAME, or in the LOGNAME entry that the remote machine might have set for your host.
If two sites have the CALLBACK option set for each other, a conversation never is started.
The COMMANDS option can compromise the security of your system. Use it with extreme care.
You can use the COMMANDS option in MACHINE entries to specify the commands that a remote computer can execute on your machine. The uux program generates remote execution requests and queues them to be transferred to the remote computer. Files and commands are sent to the target computer for remote execution. This is an exception to the rule that MACHINE entries apply only when your system calls out.
Note that COMMANDS is not used in a LOGNAME entry. COMMANDS in MACHINE entries defines command permissions, whether you call the remote system or it calls you.
The string COMMANDS=rmail specifies the default commands that a remote computer can execute on your computer. If a command string is used in a MACHINE entry, the default commands are overridden. For instance, the following entry overrides the COMMAND default so that the computers that are named owl, raven, hawk, and dove can now execute rmail, rnews, and lp on your computer.
MACHINE=owl:raven:hawk:dove COMMANDS=rmail:rnews:lp |
In addition to the names as just specified,you can have full path names of commands. For example, the following entry specifies that command rmail uses the default search path.
COMMANDS=rmail:/usr/local/rnews:/usr/local/lp |
The default search path for UUCP is /bin and /usr/bin. When the remote computer specifies rnews or /usr/local/rnews for the command to be executed, /usr/local/rnews is executed regardless of the default path. Likewise, /usr/local/lp is the lp command that is executed.
Including the ALL value in the list means that any command from the remote computers that are specified in the entry is executed. If you use this value, you give the remote computers full access to your machine.
This value allows far more access than normal users have. You should use this value only when both machines are at the same site, are closely connected, and the users are trusted.
Here is the string with the ALL value added:
COMMANDS=/usr/local/rnews:ALL:/usr/local/lp |
This string illustrates two points:
The path names that are specified for rnews and lp are used (instead of the default) if the requested command does not contain the full path names for rnews or lp.
You should use the VALIDATE option whenever you specify potentially dangerous commands, such as cat and uucp with the COMMANDS option. Any command that reads or writes files is potentially dangerous to local security when it is executed by the UUCP remote execution daemon (uuxqt).
Use the VALIDATE option in conjunction with the COMMANDS option whenever you specify commands that are potentially dangerous to your machine's security. VALIDATE is merely an added level of security on top of the COMMANDS option, though it is a more secure way to open command access than ALL.
VALIDATE provides a certain degree of verification of the caller's identity by cross-checking the host name of a calling machine against the login name it uses. The following string ensures that if any machine other than widget or gadget tries to log in as Uwidget, the connection is refused.
LOGNAME=Uwidget VALIDATE=widget:gadget |
The VALIDATE option requires privileged computers to have a unique login and password for UUCP transactions. An important aspect of this validation is that the login and password that are associated with this entry are protected. If an outsider obtains that information, that particular VALIDATE option can no longer be considered secure.
Carefully consider which remote computers you are granting privileged logins and passwords for UUCP transactions. Giving a remote computer a special login and password with file access and remote execution capability is like giving anyone on that computer a normal login and password on your computer. Therefore, if you cannot trust someone on the remote computer, do not provide that computer with a privileged login and password.
The following LOGNAME entry specifies that if one of the remote computers that claims to be eagle, owl, or hawk logs in on your computer, it must have used the login uucpfriend:
LOGNAME=uucpfriend VALIDATE=eagle:owl:hawk |
If an outsider obtains the uucpfriend login and password, masquerading is easy.
But what does this entry have to do with the COMMANDS option, which appears only in MACHINE entries? This entry links the MACHINE entry (and COMMANDS option) with a LOGNAME entry that is associated with a privileged login. This link is needed because the execution daemon is not running while the remote computer is logged in. Actually, the link is an asynchronous process that does not know which computer sent the execution request. Therefore, the real question is, how does your computer know where the execution files came from?
Each remote computer has its own spool directory on your local machine. These spool directories have write permission that is given only to the UUCP programs. The execution files from the remote computer are put in its spool directory after being transferred to your computer. When the uuxqt daemon runs, it can use the spool directory name to find the MACHINE entry in the Permissions file and get the COMMANDS list. Or, if the computer name does not appear in the Permissions file, the default list is used.
This example shows the relationship between the MACHINE and LOGNAME entries:
MACHINE=eagle:owl:hawk REQUEST=yes \ COMMANDS=rmail:/usr/local/rnews \ READ=/ WRITE=/ LOGNAME=uucpz VALIDATE=eagle:owl:hawk \ REQUEST=yes SENDFILES=yes \ READ=/ WRITE=/ |
The value in the COMMANDS option means that remote users can execute rmail and /usr/local/rnews.
In the first entry, you must assume that when you want to call one of the computers that is listed, you are really calling either eagle, owl, or hawk. Therefore, any files that are put into one of the eagle, owl, or hawk spool directories is put there by one of those computers. If a remote computer logs in and says that it is one of these three computers, its execution files are also put in the privileged spool directory. You therefore have to validate that the computer has the privileged login uucpz.
You might want to specify different option values for remote machines that are not mentioned in specific MACHINE entries. The need might arise when many computers are calling your host, and the command set changes from time to time. The name OTHER for the computer name is used for this entry as shown in this example:
MACHINE=OTHER \ COMMANDS=rmail:rnews:/usr/local/Photo:/usr/local/xp |
All other options available for the MACHINE entry can also be set for the computers that are not mentioned in other MACHINE entries.
You can combine MACHINE and LOGNAME entries into a single entry when the common options are the same. For example, the two sets of entries that follow share the same REQUEST, READ, and WRITE options:
MACHINE=eagle:owl:hawk REQUEST=yes \ READ=/ WRITE=/ |
and
LOGNAME=uupz REQUEST=yes SENDFILES=yes \ READ=/ WRITE=/ |
You can merge these entries, as shown:
MACHINE=eagle:owl:hawk REQUEST=yes \ logname=uucpz SENDFILES-yes \ READ=/ WRITE=/ |
Combining MACHINE and LOGNAME entries makes the Permissions file more manageable and efficient.
When sending files through a series of machines, the intermediary machines must have the command uucp among their COMMANDS options. If you type the following command, the forwarding operation works only if machine willow permits machine oak to execute the uucp program.
% uucp sample.txt oak\!willow\!pine\!/usr/spool/uucppublic |
The machine oak also must permit your machine to execute the uucp program. The machine pine, as the last machine designated, does not have to permit theuucp command because it is not doing any forwarding operations. Machines are not normally set up this way.
The /etc/uucp/Poll file contains information for polling remote computers. Each entry in the Poll file contains the name of a remote computer to call, followed by a tab character or a space, and finally the hours the computer should be called. The format of entries in the Poll file are:
sys-name hour ...
For example, the entry
eagle 0 4 8 12 16 20 |
provides polling of computer eagle every four hours.
The uudemon.poll script processes the Poll file but does not actually perform the poll. The script merely sets up a polling work file (always named C.file) in the spool directory. The uudemon.poll script starts the scheduler, and the scheduler examines all work files in the spool directory.
The /etc/uucp/Config file enables you to override certain parameters manually. Each entry in the Config file has this format:
parameter=value
See the Config file that is provided with your system for a complete list of configurable parameter names.
The following Config entry sets the default protocol ordering to Gge and changes the G protocol defaults to 7 windows and 512-byte packets.
Protocol=G(7,512)ge |
The /etc/uucp/Grades file contains the definitions for the job grades that can be used to queue jobs to a remote computer. This file also contains the permissions for each job grade. Each entry in this file represents a definition of an administrator-defined job grade that lets users queue jobs.
Each entry in the Grades file has the following format:
User-job-grade System-job-grade Job-size Permit-type ID-list
Each entry contains fields that are separated by blank space. The last field in the entry is composed of subfields that are also separated by spaces. If an entry occupies more than one physical line, you can use a backslash to continue the entry onto the following line. Comment lines begin with a pound sign (#) and occupy the entire line. Blank lines are always ignored.
This field contains an administrative-defined user job grade name of up to 64 characters.
This field contains a single-character job grade to which User-job-grade is mapped. The valid list of characters is A–Z, a–z, with A having the highest priority and z the lowest.
The user job grade can be bound to more than one system job grade. Note that the Grades file is searched sequentially for occurrences of a user job grade. Therefore, any multiple occurrences of a system job grade should be listed in compliance with the restriction on the maximum job size.
While no maximum number exists for the user job grades, the maximum number of system job grades that are allowed is 52. The reason is that more than one User-job-grade can be mapped to a System-job-grade, but each User-job-grade must be on a separate line in the file. Here is an example:
mail N Any User Any netnews N Any User Any |
If this configuration is in a Grades file, these two User-job-grade fields share the same System-job-grade. Because the permissions for a Job-grade are associated with a User-job-grade and not a System-job-grade, two User-job-grades can share the same System-job-grades and have two different sets of permissions.
You can define the binding of a default User-job-grade to a system job grade. You must use the keyword default as user job grade in the User-job-grade field of the Grades file and the system job grade that it is bound to. The Restrictions and ID fields should be defined as Any so that any user and any size job can be queued to this grade. Here is an example:
default a Any User Any |
If you do not define the default user job grade, the built-in default grade Z is used. Because the restriction field default is Any, multiple occurrences of the default grade are not checked.
This field specifies the maximum job size that can be entered in the queue. Job-size is measured in bytes and can be a list of the options that are listed in the following table.
Table 36–8 Job-size Field
nnnn |
Integer that specifies the maximum job size for this job grade |
nK |
Decimal number that represents the number of kilobytes (K is an abbreviation for kilobyte) |
nM |
Decimal number that represents the number of megabytes (M is an abbreviation for megabyte) |
Keyword that specifies that no maximum job size exists |
Here are some examples:
5000 represents 5000 bytes
10K represents 10 Kbytes
2M represents 2 Mbytes
This field contains a keyword that denotes how to interpret the ID list. The following table lists the keywords and their meanings.
Table 36–9 Permit-type Field
Keyword |
ID List Contents |
Login names of users who are permitted to use this job grade |
Login names of users who are not permitted to use this job grade |
Group names whose members are permitted to use this group |
Group names whose members are not permitted to use this job grade |
This field contains a list of login names or group names that are to be permitted or denied queuing to this job grade. The list of names are separated by a blank space and terminated by a newline character. The keyword Any is used to denote that anyone is permitted to queue to this job grade.
This section describes three less-frequently modified files that impact the use of UUCP facilities.
The /etc/uucp/Devconfig file enables you to configure devices by service—uucp or cu. Devconfig entries define the STREAMS modules that are used for a particular device. They have the following format:
service=x device=y push=z[:z...]
x can be cu, uucico, or both services separated by a colon. y is the name of a network and must match an entry in the Devices file. z is replaced by the names of STREAMS modules in the order that they are to be pushed onto the Stream. Different modules and devices can be defined for cu and uucp services.
The following entries are for a STARLAN network and would most commonly be used in the file:
service=cu device=STARLAN push=ntty:tirdwr service=uucico device=STARLAN push=ntty:tirdwr |
This example pushes ntty, then tirdwr.
The /etc/uucp/Limits file controls the maximum number of simultaneous uucicos, uuxqts, and uuscheds that are running in the uucp networking. In most situations, the default values are acceptable and no changes are needed. If you want to change them, however, use any text editor.
The format of the Limits file is as follows:
service=x max=y:
x can be uucico, uuxqt or uusched, and y is the limit that is permitted for that service. The fields can be in any order and in lowercase.
The following entries should most commonly be used in the Limits file:
service=uucico max=5 service=uuxqt max=5 service=uusched max=2 |
The example allows five uucicos, five uuxqts, and two uuscheds running on your machine.
The other file that affects the use of communication facilities is the remote.unknown file. This file is a binary program that executes when a machine that is not found in any of the Systems files starts a conversation. This program logs the conversation attempt and drops the connection.
If you change the permissions of the remote.unknown file so that it cannot execute, your system accepts connections from any system.
This program executes when a machine that is not in any of the Systems starts a conversation. The program logs the conversation attempt but fails to make a connection. If you change the permissions of this file so that it cannot execute (chmod 000 remote.unknown), your system accepts any conversation requests. This is not a trivial change, and you should have good reasons for making it.
The UUCP administrative files are described next. These files are created in spool directories to lock devices, hold temporary data, or keep information about remote transfers or executions.
Temporary data files (TM) – These data files are created by UUCP processes under the spool directory /var/spool/uucp/x when a file is received from another computer. The directory x has the same name as the remote computer that is sending the file. The names of the temporary data files have the following format:
TM.pid.ddd
pid is a process ID and ddd is a sequential three-digit number that starts at 0.
When the entire file is received, the TM.pid.ddd file is moved to the path name that is specified in the C.sysnxxxx file (discussed subsequently) that caused the transmission. If processing is abnormally terminated, the TM.pid.ddd file can remain in the x directory. These files should be automatically removed by uucleanup.
Lock files (LCK) – Lock files are created in the /var/spool/locks directory for each device in use. Lock files prevent duplicate conversations and multiple attempts to use the same calling device. The following table shows the different types of UUCP lock files.
File Name |
Description |
LCK..sys |
sys represents the name of the computer that is using the file |
LCK.dev |
dev represents the name of a device that is using the file |
LCK.LOG |
LOG represents a locked UUCP log file |
These files can remain in the spool directory if the communications link is unexpectedly dropped (usually on computer crashes). The lock file is ignored (removed) after the parent process is no longer active. The lock file contains the process ID of the process that created the lock.
Work file (C.) – Work files are created in a spool directory when work (file transfers or remote command executions) has been queued for a remote computer. The names of work files have the following format:
C.sysnxxxx
sys is the name of the remote computer, n is the ASCII character that represents the grade (priority) of the work, and xxxx is the four-digit job sequence number that is assigned by UUCP. Work files contain the following information:
Full path name of the file to be sent or requested.
Full path name of the destination or user or file name.
User login name.
List of options.
Name of associated data files in the spool directory. If the uucp -C or uuto -p option was specified, a dummy name (D.0) is used.
Mode bits of the source file.
Remote user's login name to be notified on completion of the transfer.
Data file(D.) – Data files are created when you specify on the command line to copy the source file to the spool directory. The names of data files have the following format:
D.systmxxxxyyy – systm is the first five characters in the name of the remote computer, xxxx is a four-digit job sequence number assigned by uucp. The four–digit job sequence number can be followed by a subsequence number. yyy is used when several D. files are created for a work (C.) file.
X. (execute file) – Execute files are created in the spool directory prior to remote command executions. The names of execute files have the following format:
X.sysnxxxx
sys is the name of the remote computer. n is the character that represents the grade (priority) of the work. xxxx is a four-digit sequence number that is assigned by UUCP. Execute files contain the following information:
This section lists the error messages that are associated with UUCP.
The following table lists ASSERT error messages.
Table 36–11 ASSERT Error Messages
Error Message |
Description or Action |
An open() or fopen() failed. |
A write(), fwrite(), fprint(), or similar command, failed. |
A read(), fgets(), or similar command failed. |
A creat() call failed. |
A dynamic allocation failed. |
An attempt to make a LCK (lock) file failed. In some situations, this is a fatal error. |
A stat() call failed. |
A chmod() call failed. |
A link() call failed. |
A chdir() call failed. |
An unlink() call failed. |
This is an internal logic problem. |
An attempt to move some bad C. or X. files to the /var/spool/uucp/.Corrupt directory failed. The directory is probably missing or has wrong modes or owner. |
A close() or fclose() call failed. |
The creation of a C. or D. file is attempted, but the file exists. This error occurs when a problem arises with the sequence file access. Usually indicates a software error. |
A TCP/IP call is attempted, but no entry is in /etc/services for UUCP. |
The user ID is not in the password database. Check name service configuration. |
Same as previous description. |
A bad line is in the Devices file. Not enough arguments on one or more lines. |
An internal table in gename.c overflowed. A single job attempted to talk to more than 30 systems. |
An ioctl(2), which should never fail, failed. A system driver problem has occurred. |
A bad line speed appears in the Devices or Systems file (Class or Speed field). |
A bad line or option is in the Permissions file. It must be fixed immediately. |
The remote machine probably hung up. No action need be taken. |
The remote machine aborted in a nonrecoverable way. This error can usually be ignored. |
An internal problem has occurred. Contact your system vendor. |
A problem with some file or directory has occurred. The spool directory is the probable cause, as the modes of the destinations were supposed to be checked before this process was attempted. |
An attempt to make a fork and exec failed. The current job should not be lost but will be attempted later (uuxqt). No action is needed. |
The following table is a list of the most common STATUS error messages.
Table 36–12 UUCP STATUS Messages
Error Message |
Description/Action |
Status is okay. |
Currently no device is available for the call. Check whether a valid device is in the Devices file for the particular system. Check the Systems file for the device to be used to call the system. |
A call was placed to the system at a time other than what is specified in the Systems file. |
Self-explanatory. |
The login for the particular machine failed. The cause could be a wrong login or password, wrong number, a slow machine, or failure in executing the Dialer-Token-Pairs script. |
The conversation failed after successful startup. This error usually means that one side went down, the program aborted, or the line (link) was dropped. |
The remote machine never answered. The cause could be a bad dialer or the wrong phone number. |
The machine called with a login/machine name that does not agree with the Permissions file. This error could be an attempt to masquerade. |
The calling device to be used is currently locked and in use by another process. |
An ASSERT error occurred. Check the /var/uucp/.Admin/errors file for the error message and refer to the section UUCP ASSERT Error Messages. |
The system is not in the Systems file. |
The device tried does not exist or the modes are wrong. Check the appropriate entries in the Systems and Devices files. |
The device could not be opened. |
The called machine is reporting a different name than expected. |
The called machine requires that it call your machine. |
The remote machine has a LCK file for your machine. The remote machine could be trying to call your machine. If it has an older version of UUCP, the process that was talking to your machine might have failed, leaving the LCK file. If the remote machine has the new version of UUCP and is not communicating with your machine, the process that has a LCK file is hung. |
The remote machine does not have the node name of your machine in its Systems file. |
The login that was used by your machine to log in does not agree with what the remote machine was expecting. |
The remote machine rejected the communication with your machine for an unknown reason. The remote machine might not be running a standard version of UUCP. |
Login succeeded, but initial handshake failed. |
This error is usually the same as DIAL FAILED. However, if this error occurs often, suspect the caller script in the Dialers file. Use Uutry to check. |
The following table lists the exit code numbers of error status messages that are produced by the /usr/include/sysexits.h file. Not all are currently used by uucp.
Table 36–13 UUCP Error Messages by Number
Message Number |
Description |
Meaning |
64 |
Base Value for Error Messages |
Error messages begin at this value. |
64 |
Command–Line Usage Error |
The command was used incorrectly, for example, with the wrong number of arguments, a bad flag, or a bad syntax. |
65 |
Data Format Error |
The input data was incorrect in some way. This data format should only be used for user's data and not system files. |
66 |
Cannot Open Input |
An input file (not a system file) did not exist, or was not readable. This problem could also include errors like “No message” to a mailer. |
67 |
Address Unknown |
The user that was specified did not exist. This error might be used for mail addresses or remote logins. |
68 |
Host Name Unknown |
The host did not exist. This error is used in mail addresses or network requests. |
69 |
Service Unavailable |
A service is unavailable. This error can occur if a support program or file does not exist. This message also can be a catchall message when something doesn't work and you don't know why. |
70 |
Internal Software Error |
An internal software error has been detected. This error should be limited to non-operating system-related errors, if possible. |
71 |
System Error |
An operating system error has been detected. This error is intended to be used for conditions like “cannot fork”, “cannot create pipe.” For instance, this error includes a getuid return of a user who does not exist in the passwd file. |
72 |
Critical OS File Missing |
Some system file such as /etc/passwd or /var/admin/utmpx does not exist, cannot be opened, or has some error such as syntax error. |
73 |
Can't Create Output File |
A user–specified output file cannot be created. |
74 |
Input/Output Error |
An error occurred while doing I/O on some file. |
75 |
Temporary Failure. User is invited to retry |
Temporary failure, indicating something that is not really an error. In sendmail, this means that a mailer, for example, could not create a connection, and the request should be reattempted later. |
76 |
Remote Error in Protocol |
The remote system returned something that was “not possible” during a protocol exchange. |
77 |
Permission Denied |
You do not have sufficient permission to perform the operation. This message is not intended for file system problems, which should use NOINPUT or CANTCREAT, but rather for higher-level permissions. For example, kre uses this message to restrict students who can send mail to. |
78 |
Configuration Error |
The system detected an error in the configuration. |
79 |
Entry Not Found |
Entry not found. |
79 |
Maximum Listed Value |
Highest value for error messages. |
