To view the framework configuration, type:
# pooladm
system host
int system.version 1
boolean system.bind-default true
string system.comment
pool default_pool
boolean pool.default true
boolean pool.active true
int pool.importance 1
string pool.comment
string pool.scheduler TS
pset default_pset
pool dev_pool
boolean pool.default false
string pool.comment
string pool.scheduler IA
pset dev_pset
pool appserver_pool
string pool.comment
pset app_pset
pool db_pool
string pool.comment
string pool.scheduler FSS
pset db_pset
pool tp_pool
string pool.comment
pset tp_pset
pset default_pset
int pset.sys_id -1
string pset.units population
boolean pset.default true
uint pset.max 4294967295
uint pset.min 1
string pset.comment
boolean pset.escapable false
uint pset.load 0
uint pset.size 0
pset dev_pset
int pset.sys_id 1
boolean pset.default false
uint pset.max 2
uint pset.min 0
string pset.comment
uint pset.load 0
uint pset.size 0
pset tp_pset
int pset.sys_id 2
uint pset.min 2
string pset.comment
uint pset.load 0
uint pset.size 0
pset db_pset
int pset.sys_id 3
uint pset.max 6
uint pset.min 4
string pset.comment
uint pset.load 0
uint pset.size 0
pset app_pset
int pset.sys_id 4
uint pset.max 2
uint pset.min 1
string pset.comment
uint pset.load 0
uint pset.size 0
A graphic representation of the framework follows.
In the db_pool, the standalone database instance is guaranteed 75 percent of the CPU resource.
