To enhance your simple configuration, create a processor set named batch and a pool named batch. Then join them with an association. Note that you must quote subcommand arguments that contain white space.
Become superuser.
Create processor set batch.
# poolcfg -c 'create pset batch (uint pset.min = 2; uint pset.max = 10)' |
Create pool batch.
# poolcfg -c 'create pool batch' |
Join with an association.
# poolcfg -c 'associate pool batch (pset batch)' |
Display the edited configuration.
# poolcfg -c info
system tester
int system.version 1
boolean system.bind-default true
string system.comment
pool batch
boolean pool.default false
boolean pool.active true
int pool.importance 1
string pool.comment
pset batch
pset batch
int pset.sys_id -2
string pset.units population
boolean pset.default true
uint pset.max 10
uint pset.min 2
string pset.comment
boolean pset.escapable false
uint pset.load 0
uint pset.size 0
