You can associate a pool with a scheduling class so that all processes bound to the pool use this scheduler. To do this, set the pool.scheduler property to the name of the scheduler class. This example shows how to associate the pool batch with the FSS.
Become superuser.
Modify pool batch to be associated with the FSS.
# poolcfg -c 'modify pool batch (string pool.scheduler="FSS")' |
Display the edited configuration.
# poolcfg -c info
system tester
int system.version 1
boolean system.bind-default true
string system.comment
pool batch
boolean pool.default false
boolean pool.active true
int pool.importance 1
string pool.comment
string pool.scheduler FSS
pset batch
pset batch
int pset.sys_id -2
string pset.units population
boolean pset.default true
uint pset.max 10
uint pset.min 2
string pset.comment
boolean pset.escapable false
uint pset.load 0
uint pset.size 0
