Use the sar -y command to monitor terminal device activities.
$ sar -y 00:00:00 rawch/s canch/s outch/s rcvin/s xmtin/s mdmin/s 01:00:00 0 0 0 0 0 0 |
If you have a lot of terminal I/O, you can use this report to determine if there are any bad lines. The activities recorded are defined in the following table.
Table 24–20 Output From the sar -y Command|
Field Name |
Description |
rawch/s |
Input characters (raw queue), per second |
canch/s |
Input characters that are processed by canon (canonical queue), per second |
outch/s |
Output characters (output queue) per second |
rcvin/s |
Receiver hardware interrupts per second |
xmtin/s |
Transmitter hardware interrupts per second |
mdmin/s |
Modem interrupts per second |
The number of modem interrupts per second (mdmin/s) should be close to zero. The receive and transmit interrupts per second (xmtin/s and rcvin/s) should be less than or equal to the number of incoming or outgoing characters, respectively. If not, check for bad lines.
The following example shows output from the sar -y command.
$ sar -y SunOS touchstone 5.9 Generic sun4u 03/04/2003 00:00:00 rawch/s canch/s outch/s rcvin/s xmtin/s mdmin/s 01:00:00 0 0 0 0 0 0 02:00:00 0 0 0 0 0 0 03:00:00 0 0 0 0 0 0 04:00:00 0 0 0 0 0 0 05:00:00 0 0 0 0 0 0 06:00:00 0 0 0 0 0 0 07:00:00 0 0 0 0 0 0 08:00:00 0 0 0 0 0 0 08:20:01 0 0 0 0 0 0 08:40:00 0 0 0 0 0 0 09:00:00 0 0 0 0 0 0 09:20:01 0 0 6 0 0 0 09:40:01 0 0 0 0 0 0 10:00:02 0 0 1 0 0 0 10:20:03 0 0 6 0 0 0 10:40:01 0 0 15 0 0 0 11:00:01 0 0 20 0 0 0 11:20:01 0 0 4 0 0 0 11:40:00 0 0 4 0 0 0 12:00:01 0 0 0 0 0 0 Average 0 0 2 0 0 0 |
