Use the sar -w command to report swapping and switching activity.
$ sar -w 00:00:00 swpin/s bswin/s swpot/s bswot/s pswch/s 01:00:00 0.00 0.0 0.00 0.0 22 |
The following table describes target values and observations.
Table 24–19 Output From the sar -w Command|
Field Name |
Description |
swpin/s |
The number of LWP transfers into memory per second. |
bswin/s |
The average number of processes that are swapped out of memory per second. If the number is greater than 1, you might need to increase memory. |
swpot/s |
bswot/s |
The number of blocks that are transferred for swap-outs per second. |
pswch/s |
The number of kernel thread switches, per second. |
All process swap-ins include process initialization.
The following example shows output from the sar -w command.
$ sar -w SunOS touchstone 5.9 Generic sun4u 03/04/2003 00:00:00 swpin/s bswin/s swpot/s bswot/s pswch/s 01:00:00 0.00 0.0 0.00 0.0 63 02:00:00 0.00 0.0 0.00 0.0 60 03:00:00 0.00 0.0 0.00 0.0 62 04:00:00 0.00 0.0 0.00 0.0 63 05:00:00 0.00 0.0 0.00 0.0 63 06:00:00 0.00 0.0 0.00 0.0 61 07:00:00 0.00 0.0 0.00 0.0 60 08:00:00 0.00 0.0 0.00 0.0 61 08:20:01 0.00 0.0 0.00 0.0 63 08:40:00 0.00 0.0 0.00 0.0 63 09:00:00 0.00 0.0 0.00 0.0 63 09:20:01 0.00 0.0 0.00 0.0 132 09:40:01 0.00 0.0 0.00 0.0 187 10:00:02 0.00 0.0 0.00 0.0 185 10:20:03 0.00 0.0 0.00 0.0 258 10:40:01 0.00 0.0 0.00 0.0 161 11:00:01 0.00 0.0 0.00 0.0 128 11:20:01 0.00 0.0 0.00 0.0 117 11:40:00 0.00 0.0 0.00 0.0 171 12:00:01 0.00 0.0 0.00 0.0 94 12:20:01 0.00 0.0 0.00 0.0 95 12:40:01 0.00 0.0 0.00 0.0 95 13:00:01 0.00 0.0 0.00 0.0 95 13:20:01 0.00 0.0 0.00 0.0 96 13:40:01 0.00 0.0 0.00 0.0 98 14:00:01 0.00 0.0 0.00 0.0 96 14:20:00 0.00 0.0 0.00 0.0 91 14:40:01 0.00 0.0 0.00 0.0 92 15:00:01 0.00 0.0 0.00 0.0 103 Average 0.00 0.0 0.00 0.0 88 |
