Display system call statistics by using the sar -c command.
$ sar -c 00:00:00 scall/s sread/s swrit/s fork/s exec/s rchar/s wchar/s 01:00:00 38 2 2 0.00 0.00 149 120 |
The following table describes the system call categories that are reported by the -c option. Typically, reads and writes account for about half of the total system calls, although the percentage varies greatly with the activities that are being performed by the system.
Table 24–9 Output From the sar -c Command|
Field Name |
Description |
scall/s |
All types of system calls per second, which is generally about 30 per second on a system with 4 to 6 users. |
sread/s |
read system calls per second. |
swrit/s |
write system calls per second. |
fork/s |
fork system calls per second, which is about 0.5 per second on a system with 4 to 6 users. This number will increase if shell scripts are running. |
exec/s |
exec system calls per second. If exec/s divided by fork/s is greater than three, look for inefficient PATH variables. |
rchar/s |
Characters (bytes) transferred by read system calls per second. |
wchar/s |
Characters (bytes) transferred by write system calls per second. |
The following example shows output from the sar -c command.
$ sar -c SunOS touchstone 5.9 Generic sun4u 03/04/2003 00:00:00 scall/s sread/s swrit/s fork/s exec/s rchar/s wchar/s 01:00:00 118 14 9 0.00 0.00 3360 2506 02:00:00 118 14 9 0.00 0.00 3360 2505 03:00:00 118 14 9 0.00 0.00 3361 2506 04:00:00 118 14 9 0.01 0.00 3363 2506 05:00:00 118 14 9 0.00 0.00 3360 2505 06:00:00 118 14 9 0.00 0.00 3360 2505 07:00:00 118 14 9 0.00 0.00 3360 2505 08:00:00 118 14 9 0.00 0.00 3360 2505 08:20:01 120 14 9 0.00 0.00 3394 2522 08:40:00 119 14 9 0.01 0.01 3357 2502 09:00:00 119 14 9 0.01 0.00 3356 2500 09:20:01 437 76 48 0.04 0.04 19606 6531 09:40:01 585 117 73 0.00 0.00 12962 10119 10:00:02 564 97 60 0.03 0.03 16354 6196 Average 159 22 14 0.01 0.01 4657 3017 |
