“Soft” limit on file descriptors that a single process can have open. A process might adjust its file descriptor limit to any value up to the “hard” limit defined by rlim_fd_max by using the setrlimit() call or issuing the limit command in whatever shell it is running. You do not require superuser privilege to adjust the limit to any value less than or equal to the hard limit.
Signed integer
64
1 to MAXINT
File descriptors
No. Loaded into rlimits structure.
Compared to rlim_fd_max and if rlim_fd_cur is greater than rlim_fd_max, rlim_fd_cur is reset to rlim_fd_max.
When the default number of open files for a process is not enough. Increasing this value means only that it is possibly not necessary for a program to use setrlimit(2) to increase the maximum number of file descriptors available to it.
Unstable
