“Soft” limit on file descriptors that a single process can have open. A process might adjust its file descriptor limit to any value up to the “hard” limit defined by rlim_fd_max by using the setrlimit() call or issuing the limit command in whatever shell it is running. You do not require superuser privilege to adjust the limit to any value less than or equal to the hard limit.
Signed integer
64
1 to MAXINT
File descriptors
No. Loaded into rlimits structure.
Compared to rlim_fd_max and if rlim_fd_cur is greater than rlim_fd_max, rlim_fd_cur is reset to rlim_fd_max.
When the default number of open files for a process is not enough. Increasing this value means only that it is possibly not necessary for a program to use setrlimit(2) to increase the maximum number of file descriptors available to it.
Unstable
“Hard” limit on file descriptors that a single process might have open. To override this limit requires superuser privilege.
Signed integer
1024
1 to MAXINT
File descriptors
No
None
When the maximum number of open files for a process is not enough. Note that other limitations in system facilities can mean that a larger number of file descriptors is not as useful as it might be:
A 32-bit program using standard I/O is limited to 256 file descriptors. A 64-bit program using standard I/O can use up to 2 billion descriptors.
select(3C) is by default limited to 1024 descriptors per fd_set. Starting with the Solaris 7 release, 32-bit application code can be recompiled with a larger fd_set size (less than or equal to 65,536). A 64-bit application sees an fd_set size of 65,536, which cannot be changed.
An alternative to changing this on a system wide basis is to use the plimit(1) command. If a parent process has its limits changed by plimit, all children inherit the increased limit. This is useful for daemons such as inetd.
Unstable
