This parameter was moved to the General Parameters section of Chapter 2, Solaris Kernel Tunables and was updated. For more information, see segkpsize.
Specify the amount of kernel pageable memory available. This memory is used primarily for kernel thread stacks. Increasing this number allows either larger stacks for the same number of threads or more threads. This parameter can only be set on systems running 64–bit kernels. Systems running 64-bit kernels use a default stack size of 24 Kbytes.
Unsigned long
64–bit kernels, 2 Gbytes
32–bit kernels, 512 Mbytes
64–bit kernels, 512 Mbytes - 24 Gbytes
32-bit kernels, 512 Mbytes
Mbytes
No
Value is compared to minimum and maximum sizes (512 Mbytes and 24 Gbytes for 64-bit systems) and if smaller than the minimum or larger than the maximum, it is reset to 2 Gbytes and a message to that effect is displayed.
The actual size used in creation of the cache is the lesser of the value specified in segkpsize after the constraints checking and 50% of physical memory.
This is one of the steps necessary to support large numbers of processes on a system. The default size of 2 Gbytes, assuming at least 1 Gbyte of physical memory is present, allows creation of 24–Kbyte stacks for more than 87,000 kernel threads. The size of a stack in a 64-bit kernel is the same whether the process is a 32-bit process or a 64-bit process. If more than this number is needed, segkpsize can be increased assuming sufficient physical memory exists.
Unstable
For information, see segkpsize (Pre-Solaris 7 and the Solaris 7 Release).
Specify the amount of kernel pageable memory available. This memory is used primarily for kernel thread stacks. Increasing this number allows either larger stacks for the same number of threads or more threads. This parameter can only be set on 64–bit kernels. 64-bit kernels use a default stack size of 24 Kbytes.
Available for the Solaris 7 release with patch 106541-04 or the Solaris 7 5/99 and Solaris 8 releases.
Unsigned long
Mbytes
No
None
Increase when more threads are desired.
Unstable
