The following sections changed.
Maximum of the triplet (200, tune_t_minarmem + 100, [10% of memory available at boot time])
to:
The greater of (tune_t_minarmem + 100 and [4% of memory available at boot time + 4 Mbytes])
Default value to no more than 20% of physical memory. The systems does no enforcement of this range other than that described in the Validation section.
to:
Minimum value enforced by the system is tune_t_minarmem + 100. The system does not enforce a maximum value.
Yes, unless dynamic reconfiguration operations that add or delete memory occur. At that point, the value is reset to whatever was provided in the /etc/system file or was calculated.
Maximum of the quadruplet (200, tune_t_minarmem + 100, [10% of memory available], and the value from /etc/system). No message is displayed if the value from /etc/system is increased. Done only at boot time.
to:
If the value specified in the /etc/system file or the calculated default is less than tune_t_minarmem + 100, the value is reset to tune_t_minarmem + 100.
No message is displayed if the value from the /etc/system file is increased. Done only at boot time, and during dynamic reconfiguration operations that involve adding or deleting memory.
When memory locking requests or attaching to a shared memory segment with the SHARE_MMU flag fails, yet the amount of memory available seems to be sufficient. Keeping 10% of memory free on a 32-Gbyte system might be excessive.
Excessively large values can cause memory locking requests to fail unnecessarily.
to:
