The following sections changed.
Maximum size of system V shared memory segment that can be created. This parameter is an upper limit that is checked before the system sees if it actually has the physical resources to create the requested memory segment.
to:
Attempts to create a shared memory section whose size is zero or whose size is larger than the specified value will fail with an EINVAL error.
1,048,576
to:
8,388,608
The following sections changed in the Solaris 9 8/03 release.
to
Maximum size of system V shared memory segment that can be created. This parameter is an upper limit that is checked before the application sees if it actually has the physical resources to create the requested memory segment.
This parameter specifies only the largest value the operating system can accept for the size of a shared memory segment. Whether the segment can be created depends entirely on the amount of swap space available on the system and, for a 32-bit process, whether there is enough space available in the process's address space for the segment to be attached.
0 - MAXINT on 32-bit systems, 0 – MAXINT64 on 64-bit systems
to
0 - MAXUINT32 on 32-bit systems, MAXUINT64 on 64-bit systems
