Application Packaging Developer's Guide
Defining a Package Instance
The same package can have different versions, be compatible with different architectures, or both. Each variation of a package is known as a package instance. A package instance is determined by combining the definitions of the PKG, ARCH, and VERSION parameters in the pkginfo file.
The pkgadd command assigns a package identifier to each package instance at installation time. The package identifier is the package abbreviation with a numerical suffix, for example SUNWadm.2. This identifier distinguishes a package instance from any other package, including instances of the same package.
Defining a Package Abbreviation (PKG)
A package abbreviation is a short name for a package that is defined via the PKG parameter in the pkginfo file, and must:
Specifying a Package Architecture (ARCH)
The ARCH parameter in the pkginfo file identifies which architectures are associated with the package. The architecture name has a maximum length of 16 alphanumeric characters. If a package is associated with more than one architecture, specify them in a comma-separated list.
For example, a package architecture specification in a pkginfo file might be:
Specifying a Package Instruction Set Architecture (SUNW_ISA)
The SUNW_ISA parameter in the pkginfo file identifies which instruction set architecture is associated with a Sun Microsystems package. The values are:
For example, the SUNW_ISA value in a pkginfo file for a package containing 64–bit objects would be:
If SUNW_ISA is not set, the default instruction set architecture of the package is set to the value of the ARCH parameter.
Specifying a Package Version (VERSION)
The VERSION parameter in the pkginfo file identifies the version of the package. The version has a maximum length of 256 ASCII characters, and cannot begin with a left parenthesis.
An example version specification in a pkginfo file might be:
VERSION=release 1.0
