Se si cerca di aggiungere il servizio diskless Sun4UTM su un server x86, viene visualizzato il seguente errore:
Jun 12 17:02:48 s12-9 WBEM_Logging_Service[1810]: Failed to create clone area /export/root/clone/Solaris_9/sun4u. Failed to create clone area /export/root/clone/Solaris_9/sun4u. The wbem_log had the following error: strings /var/sadm/wbem/log/wbem_log | grep SUNWidecr Solaris_OsService@#@0@#@0@#@root@#@s12-9@#@s12-9@#@1054856467079@#@System command return value.@#@System command, /usr/sbin/pkgadd -S -n -R /export/root/clone/Solaris_9/sun4u -a /tmp/admin.Qwayvg -d /export/root/templates/Solaris_9/SUNWidecr_4.1, REV=2001.03.02.13.55_sparc.sun4u all, returned value of: /export/root/clone/Solaris_9/sun4u/var/sadm/pkg/SUNWidecr/install/postinstall: test: argument expected Installation of SUNWidecr failed. |
I client diskless Sun4U possono essere invece aggiunti ai server SPARC.
Soluzione: nessuna.
