Solaris のシステム管理 (ネーミングとディレクトリサービス : DNS、NIS、LDAP 編)
デフォルトスイッチテンプレートファイル
Solaris オペレーティング環境で用意されている 4 つのスイッチファイルは、次のとおりです。
例 2–1 NIS+ スイッチファイルテンプレート (nsswitch.nisplus)
# /etc/nsswitch.nisplus:
# An example file that could be copied over to /etc/nsswitch.conf;
# it uses NIS+ (NIS Version 3) in conjunction with files.
# "hosts:" and "services:" in this file are used only if the
# /etc/netconfig file has a "-" for nametoaddr_libs of "inet"
# transports.
# the following two lines obviate the "+" entry in /etc/passwd
# and /etc/group.
passwd: files nisplus
group: files nisplus
# consult /etc "files" only if nisplus is down.
hosts: nisplus [NOTFOUND=return] files
# Uncomment the following line, and comment out the above, to use
# both DNS and NIS+. You must also set up the /etc/resolv.conf
# file for DNS name server lookup. See resolv.conf(4).
# hosts: nisplus dns [NOTFOUND=return] files
services: nisplus [NOTFOUND=return] files
networks: nisplus [NOTFOUND=return] files
protocols: nisplus [NOTFOUND=return] files
rpc: nisplus [NOTFOUND=return] files
ethers: nisplus [NOTFOUND=return] files
netmasks: nisplus [NOTFOUND=return] files
bootparams: nisplus [NOTFOUND=return] files
publickey: nisplus
netgroup: nisplus
automount: files nisplus
aliases: files nisplus
sendmailvars: files nisplus
例 2–2 NIS スイッチファイルテンプレート
# /etc/nsswitch.nis:
# it uses NIS (YP) in conjunction with files.
# transports.
# and /etc/group.
passwd: files nis
group: files nis
# consult /etc "files" only if nis is down.
hosts: nis [NOTFOUND=return] files
networks: nis [NOTFOUND=return] files
protocols: nis [NOTFOUND=return] files
rpc: nis [NOTFOUND=return] files
ethers: nis [NOTFOUND=return] files
netmasks: nis [NOTFOUND=return] files
bootparams: nis [NOTFOUND=return] files
publickey: nis [NOTFOUND=return] files
netgroup: nis
aliases: files nis
# for efficient getservbyname() avoid nis
services: files nis
sendmailvars: files
例 2–3 Files スイッチファイルテンプレート
# /etc/nsswitch.files:
# it does not use any naming service.
# transports.
passwd: files
group: files
hosts: files
networks: files
protocols: files
rpc: files
ethers: files
netmasks: files
bootparams: files
publickey: files
# At present there isn't a 'files' backend for netgroup;
# the system will figure it out pretty quickly, and will notuse
# netgroups at all.
netgroup: files
automount: files
aliases: files
services: files
sendmailvars: files
例 2–4 LDAP スイッチファイルテンプレート
# /etc/nsswitch.ldap:
# An example file that could be copied over to /etc/nsswitch.conf; it
# uses LDAP in conjunction with files.
# /etc/netconfig file has a "-" for nametoaddr_libs of "inet" transports.
and /etc/group.
passwd:     files ldap
group:      files ldap
hosts:      ldap [NOTFOUND=return] files
networks:   ldap [NOTFOUND=return] files
protocols:  ldap [NOTFOUND=return] files
rpc:        ldap [NOTFOUND=return] files
ethers:     ldap [NOTFOUND=return] files
netmasks:   ldap [NOTFOUND=return] files
bootparams: ldap [NOTFOUND=return] files
publickey:  ldap [NOTFOUND=return] files
netgroup:   ldap
automount:  files ldap
aliases:    files ldap
# for efficient getservbyname() avoid ldap
services:   files ldap
sendmailvars:   files
