The Example 5–21 example shows the syntax of a name-server (NS) resource record.
domainname [optional TTL] class NS name-server-name |
The name-server record lists by name a server responsible for a given domain. The name field lists the domain that is serviced by the listed name server. If no name field is listed, then it defaults to the last name listed. One NS record should exist for each master and slave server for the domain. Example 5–22 is a sample NS resource record.
;domainname [TTL] class NS nameserver doc.com 90000 IN NS sirius.doc.com. |
