System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Address (A)
The Example 5–23 example shows the syntax of an address (A) resource record.
Example 5–23 Address Record Format
machinename	[optional TTL] class A	address
The A record lists the address for a given machine. The name field is the host name, and the address is the IP address. One A record should exist for each address of the machine (in other words, routers, or gateways require at least two entries, a separate entry including the IP address assigned to each network interface).
Example 5–24 Sample Address Record
;machinename	[TTL]	class	A	address
sirius		IN		A	123.45.6.1
