Solaris 9 12/03 Installation Guide
Activate the Inactive Boot Environment
The c0t15d0s0 boot environment is made bootable. The system is then rebooted and c0t15d0s0 becomes the active boot environment. The c0t4d0s0 boot environment is now inactive.
  1. From the main menu, select Activate.
    Name of Boot Environment: c0t15d0s0
    Do you want to force a Live Upgrade sync operations: no
  2. Press F3.
  3. Press Return.
  4. Type:
    # init 6
If a fallback is necessary, use the command-line procedures in the previous example: Fall Back to the Source Boot Environment.
